[B6 AVF] Prośba w odczytaniu błędów
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 LJ
Component: 1,9l R4 EDC G000SG 4910
Coding: 00002
Shop #: WSC 63351
2 Faults Found:
19561 - Valve for Intake Manifold Flap (N239): Open or Short to Ground
P3105 - 35-10 - - - Intermittent
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04255
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 AA
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63351
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 00041
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 950 M
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00401
Shop #: WSC 00001
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0704
Coding: 00001
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BC
Component: Komfortgerát T3B 1311
Coding: 06859
Shop #: WSC 63351
3 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01560 - Passenger Door
61-10 - Won't De-Safe - Intermittent
Address 56 -------------------------------------------------------
Controller: 8E0 035 186 L
Component: concert II GRO 0001
Coding: 01001
Shop #: WSC 63351
End ----------------------------------------------
w czym p[roblem,bo nic nie napisales,co Cie niepokoi-jakies objawy,poza czujnikiem temperatury,kory moze cos zle pokazywac?
Chodzi mi o te 3 błędy z czego się wzięły co jej spowodowało i czy po usunięciu ponownie się pojawią
Coding: 06859
Shop #: WSC 63351
3 Faults Found:
35-00 - -
35-00 - -
a główny problem to zawór EGR jak skasuje błąd to znów się pojawia a wczoraj po przedmuchaniu tych rurek od zaworu oraz popsikaniu WD40 elektrozaworu tam co idą do niego te rurki pojawiły się następne błędy
2 Faults Found:
P1144 - 35-00 - -
Coding: 06859
Shop #: WSC 63351
3 Faults Found:
35-00 - -
35-00 - -
te bledy zawsze Ci sie pokaza,jesli alarm sie uruchomi w jakis sposob-nie przejmuj sie pierwszymi dwoma-trzeci -01560-oznacza,ze czujnik w drzwiach nie moze sie rozbroic-nota bene tez mam to samo w drzwiach lewych tylnych(01561),ale nie skutkuje to niczym,poza tym bledem na vagu :wink4: trzeba zdjac tapicere i przeczyscic najpierw ,a potem podpiac vaga ponownie...
reszty nie zinterpretujebo nie znam sie na dieslach :wink4:
Ok wielkie dzięki za odpowiedz to tylko pozostaje mi zawór EGR po moich modyfikacjach z oczyszczeniem teraz mam zgryza z tą kontrolką:D
Witam. Jak rozwiązałeś problem z zaworem EGR bo ja też przeczyściłem go dzisiaj i mam 17552 i auto zamulone na amen.
