[B6 AVF] Prośba o przetłumaczenie kodów wyposażenia
E0A = No special edition - nie specjalna edycja :(
7A0 = Without CD changer/CD player - radio cd
4UE = Air bag for driver and front seat passenger - 2 airbagi z przodu
6XD = Exterior mirrors: electrically adjustable/heated
5SL = Left exterior mirror: aspherical - lewe lusterko asferyczne
5RU = Right exterior mirror: convex (large viewing field)
1KD = Disc brakes, rear - hamulce tarczowe tylnie
J1D = Battery 380 A (72 Ah) - aku 72Ah
1LB = Disc brakes, front - hamulce tarczowe przednie
1BA = Standard suspension/shock absorption
3FA = Without roof insert (standard roof)
5MA = Decorative inserts
7X0 = Without park distance control
4R5 = Power windows with comfort operation andcircuit breaker, mechanical window regulators rear
F0A = No special purpose vehicle, standard equipment
8GU = Alternator 140 A - alternator 140A
0G1 = Gearshift lever
0YK = Weight range 10 installation control only, no requirement forecast
0JJ = Weight category front axle weight range 9
T9J = 4-cylinder diesel engine 1.9 L unit 038.K - silniczek
3NZ = Rear seat bench unsplit, backrest split folding
8JH = Ellipsoidal headlight for driving on the right
U1A = Instrument insert with km/h speedometer,clock, tachometer and trip odometer
X0A = National sales program Germany
1N1 = Power steering
2PG = Steering wheel
8Q1 = Headlight-range adjustment
9Q3 = Multi-function display, without on-boardcomputer and check control
8Z5 = Not hot country - wersja normalna nie na "ciepłe kraje" ???
D3E = 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system Base engine is T9J - silniczek
7Q0 = Without navigation device
CB1 = Alloy wheels 7J x 16 Alu-4, offset 42 - alumy
7K0 = Without tire pressure warning light
4X3 = Side air bag front with curtain air bag - airbag w siedzeniu + kurtyna
VJ1 = Reinforced bumpers
6R1 = Leatherette gearshift boot
3L3 = Manual height adjustment for front seats
4KC = Side and rear windows in heat-insulatingglass
3Y0 = Without roll-up sun screen
4K4 = Radio remote controlled central locking - centralny na pilota
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz - częstotliwość pilota
1SA = Without additional engine guard
0GZ = Emission standard EU3, diesel with EOBD
Q1D = Sports front seats - sportowe siedzenia
4GG = Laminated windshield with metal layer with sunshield, heated
Prosił bym o rozszyfrowanie reszty :)
Już doszedłem :) co i jak kto szuka nie błądzi ;) Proszę o skasowanie tematu :)
zewnętrzne lusterka elektryczne/podgrzewane
prawe lusterko z obszarem powiększenia...
standardowe zawieszenie
standardowy dach (bez szyberdachu)
decory w środku
bez czujników parkowania
elektryczne szyby przód z opcją komfortu (pewnie z pilota się domykają) / ręczne tył
światła dostosowane do jazdy po prawej
kraj sprzedaży Niemcy
regulacja położenia świateł
bez nawigacji
bez czujników ciśnienia opon
skórzany mieszek
ręczne sterowanie fotelami
boczne i tylna szyba atermiczne
bez rolet w tylnych drzwiach
przednia szyba pogrzewana i solarna?!
tyle co się domyślam... :cool1:
Gość
