ookon 0 Opublikowano 7 Października 2007 Udostępnij Opublikowano 7 Października 2007 witam wszystkich,po lilku dniach walki z podłączeniem vag-coma dzis udało mi sie w koncu połączyc:)miałem problem z falowaniem obrotów ale po adaptacji i skasowaniu błędów jak ręką odjął.pozostało mi tylko cos takiego:moze ktos wie co one oznaczają?? VAG-COM Version: Release 311.2-N Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 Address 01 ------------------------------------------------------- Controller: 8D0 907 557 S Component: 1,8L R4/5V MOTR HS D03 Coding: 04001 Shop #: WSC 06335 No fault code found. Address 03 ------------------------------------------------------- Controller: 8E0 614 111 Component: ABS 5.3 FRONT D11 Coding: 0273004132 Shop #: BB 24303 No fault code found. Address 08 ------------------------------------------------------- Controller: 8L0 820 043 B Component: A4 KLIMAVOLLAUTOMAT_D72 Coding: 04140 Shop #: WSC 06335 No fault code found. Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 8D0 919 034 F Component: B5-KOMBIINSTRUMENT__D12 Coding: 00042 Shop #: WSC 00000 No fault code found. Address 25 ------------------------------------------------------- Controller: 4A0 953 234 Component: IMMO AUZ9Z0W5254039 D77 Coding: 00000 Shop #: WSC 76619 1 Fault Found: 01176 - Key 07-10 - Signal to Low - Intermittent Address 35 ------------------------------------------------------- Controller: 8LO 862 257 E Component: ZV-Pumpe Coding: 00000 Shop #: WSC 65535 16 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01373 - Alarm triggered by Radio Ground Contact 35-00 - - 01366 - Opened Due to Crash Signal 35-00 - - 01361 - Switch for Anti-Theft Alarm: Close 29-00 - Short to Ground 01360 - Switch for Anti-Theft Alarm: Open 29-00 - Short to Ground 01362 - Close Switch for Tailgate/Trunk (F124) 29-00 - Short to Ground 01363 - Switch for Central Locking: Driver's Door (F59) 27-00 - Implausible Signal 01364 - Switch for Central Locking: Passenger Door (F114) 27-00 - Implausible Signal 01365 - Lock/Unlock Switch: Interior 29-00 - Short to Ground 01365 - Lock/Unlock Switch: Interior 28-00 - Short to B+ End ------------------------------------------------------- Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Gość spedyt Opublikowano 7 Października 2007 Udostępnij Opublikowano 7 Października 2007 Address 25 ------------------------------------------------------- Controller: 4A0 953 234 Component: IMMO AUZ9Z0W5254039 D77 Coding: 00000 Shop #: WSC 76619 1 Fault Found: 01176 - Key Problem z immobilizerem, trzeba sprawdzić połączenie kabelków czytnika klucza i modułu Opis w Warsztacie. Pozostałe są od centralnego i alarmu Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
