[B5 AEB] Prośba o analizę logów
Witam,
pierwszy raz robilem logi.
Nie wiem czy dobrze ale jesli zobaczycie cos blednie zrobionego to pls o opinie i sugestie, logi robione w "miejscu"
jak mozna odrazu o sugestie jak zrobic logi "dynamiczne"
,Group A:,'001,,,,Group B:,'003,,,,Group C:,'005
,,Engine speed,Engine load,Throttle body angle,Ignition angle,,Engine speed,ECU Voltage,Coolant temp,Intake air temp,,Engine speed,Idle speed spec.,Idle regulation,Air mass drawn
,TIME,760-960 rpm,0.5-1.5 ms,0-5 deg,9-15 deg BTDC,TIME,760-960 rpm,12-14.5 V,80-105 deg C,-45-108.5 deg C,TIME,760-960 rpm,normal 860 rpm,-10 - 10 %,1.8-4.0 g/s
MARKER,STAMP, /min, ms,°,°,STAMP, /min, V,°C,°C,STAMP, /min, /min,%, g/s
,0.90,840,1.00,5.2,-12.0,0.01,840,13.580,78.0,36.0,0.46,860,860,1.6,2.84
,2.30,840,1.00,5.2,-12.0,1.37,840,13.580,78.0,36.0,1.84,860,860,1.6,2.84
1,3.70,840,1.00,5.2,-12.0,2.75,840,13.650,78.0,36.0,3.26,860,860,1.6,2.78
,5.04,840,1.05,5.2,-12.0,4.14,840,13.580,78.0,36.0,4.59,860,860,1.6,2.84
2,6.33,840,1.00,5.2,-12.0,5.47,840,13.650,78.0,36.0,5.92,860,860,1.6,2.78
,7.71,840,1.05,5.2,-12.0,6.78,840,13.580,78.0,36.0,7.25,860,860,1.6,2.92
,9.04,840,1.05,5.2,-12.0,8.17,840,13.580,78.0,36.0,8.62,860,860,1.6,2.84
3,10.40,840,1.00,5.2,-12.0,9.47,840,13.650,78.0,36.0,9.92,860,860,1.6,2.78
,11.73,840,1.05,5.2,-12.0,10.84,840,13.650,78.0,36.0,11.29,860,860,1.6,2.84
,54.74,840,1.05,5.2,-12.0,55.17,840,13.650,78.0,36.0,55.64,860,860,3.1,2.84
,56.07,840,1.05,5.2,-12.0,56.50,1040,13.580,78.0,36.0,56.98,2550,2280,-4.7,14.93
,57.43,2920,1.45,14.3,-33.8,57.88,3040,13.650,78.0,34.5,58.32,2550,2280,-4.7,12.43
,58.76,3120,1.25,13.5,-30.8,59.22,3160,13.650,78.0,34.5,59.68,2550,2280,-4.7,12.57
,60.15,3200,1.25,13.9,-31.5,60.60,3200,13.650,76.5,34.5,61.04,2550,2280,-4.7,13.12
,61.49,3240,1.25,13.9,-31.5,61.91,3280,13.650,76.5,34.5,62.34,2550,2280,-4.7,13.26
,62.77,3280,1.25,14.3,-31.5,63.23,3320,13.650,76.5,34.5,63.67,2550,2280,-4.7,13.89
,64.16,3360,1.30,14.8,-33.0,64.58,3400,13.580,76.5,34.5,65.03,2550,2280,-4.7,14.37
,65.46,3520,1.85,19.1,-36.8,65.91,4040,13.650,75.0,34.5,66.35,2550,2280,-4.7,25.69
,66.80,4800,1.70,20.0,-41.3,67.27,5040,13.650,75.0,34.5,67.71,2550,2280,-4.7,26.46
,68.18,5360,1.50,20.0,-39.8,68.63,5480,13.650,75.0,34.5,69.09,2550,2280,-4.7,25.97
,69.54,5560,1.45,19.5,-39.0,69.99,5600,13.580,73.5,34.5,70.45,2550,2280,-4.7,14.31
,70.88,4280,0.90,13.9,-37.5,71.33,3600,13.650,73.5,34.5,71.78,2550,2280,-3.1,10.07
,72.21,2400,1.05,10.0,-28.5,72.66,1840,13.650,73.5,34.5,73.09,1400,1420,8.6,6.94
,73.54,1200,1.25,5.6,6.0,73.98,960,13.720,72.0,34.5,74.42,940,900,-1.6,2.84
,74.88,880,0.95,4.8,-11.3,75.33,840,13.650,72.0,34.5,75.81,870,860,-0.8,2.64
,76.29,840,0.95,4.8,-12.0,76.73,840,13.650,72.0,34.5,77.17,850,860,-0.8,2.64
,77.63,840,1.00,4.8,-12.0,78.10,840,13.650,72.0,36.0,78.54,860,860,-0.8,2.78
,78.98,840,1.00,4.8,-12.0,79.46,840,13.720,72.0,36.0,79.92,860,860,-0.8,2.71
,89.87,840,1.05,5.2,-12.0,90.32,840,13.580,73.5,36.0,89.43,860,860,0.0,2.84
5,91.21,840,1.00,5.2,-12.0,91.66,840,13.650,75.0,36.0,90.76,870,860,0.0,2.78
10,92.54,840,1.00,5.2,-12.0,92.99,840,13.650,75.0,36.0,92.11,860,860,0.0,2.84
Sunday,30,January,2011,18:07:09
8D0 907 557 T ,,1.8L R4/5VT MOTR HS D05,
dziekuje za pomoc
Kolego wszystko masz w dziale diagnostyka vag jakie logi masz zrobić. I jak zrobić. Dynamiczne robisz na 3 biegu od 1500-4500 obr z gazem na max. A co do logów to uporządkuj je. Otwórz w exelu zaznacz pierwszą całą kolumne wejdz w zakładke DANE>Teskt jako kolumny zaznacz rozdzielany daj dalej zaznacz tylko tabulator dalej i zakończ. Kazda kolumna będzie osobno.
