[ALL B8] Kody błędów
MultiPanda69
Panowie powie mi ktoś co oznaczają te błędy ? :
Próbowałem usunąć, ale pojawiają sie ponownie.
Z autem nic się nie dzieje, ale jestem ciekawy o co chodzi.
Co do "02635" podejrzewam, że chodzi o nie aktywne radio satelitarne, ale nie mam pewności.
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 L HW: 8T1 035 195 L
Component: Symph3 Sirius H02 0211
Revision: 00000004 Serial number: AUZ5Z4H1050562
Coding: 040304020401870DEFF98F0900
Shop #: WSC 02399 823 56573
VCID: 4084425E2CD9D51C
Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
2 Faults Found
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 27
Mileage: 31515 km
Time Indication: 0
Date: 2011.07.18
Time: 13:30:56
03157 - Functionality limited due to Communications Disruption
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 37368 km
Time Indication: 0
Date: 2011.10.08
Time: 14:08:07
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000001
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000129868
Coding: 26001091073CAF010000080300003D0D0F1C520800010161000000
VCID: 3064129E9C79459C
Part No SW: 8K1 955 119 A HW: 8T1 955 119
Component: WWS 260908 H06 0070
Coding: 00FD11
Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Coding: 025028
Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
1 Fault Found
02258 - Door Opener Transmitter
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 27
Mileage: 31515 km
Time Indication: 0
Date: 2011.07.18
Time: 13:28:00
02258 - chyba związane z pilotem do bramy garażowej
:hi:
Zle kodowanie masz :) Autko pewnie z USA :wink4: i stad ten blad .Tam jest system Sirius z tego co pamietam
02258 - chodzi pewnie o HomeLinka o inna czestotliwosc
Dzięki,
Czyli tak jak myślałem, został tylko ten 03157 : http://www.gerritspeek.nl/vag-com_dtc-03157.html
z tego wynika "To nie jest kod błędu, po prostu obserwacji / komunikacji / detekcja / ostrzeżenie"
więc nie wiem o co chodzi - ale chyba nic co mogłoby niepokoić.
A i fajna stronka z kodami błędów chyba wszystkie, które mogą wystąpić :
http://www.gerritspeek.nl/vag-com_foutcodeslijst-a.html
15 stron z błędami :hi:
też mam ten problem błedu 03157. Może ktoś podpowie jak się go pozbyć raz na zawsze?
a w jakim sterowniku ?
jeśli masz ten błąd w 5F to tu jest opisane jak go usunąć, mnie i koledze Love-Audi udało się
http://a4-klub.pl/index.php?/topic/348609-bledy-w-5f/
dzięki za info zweryfikuj to jutro :)
jednak udało się usunąć błędy i do tej pory nie wróciły. Został tylko ten od radia 02635 - Tuner Not Enabled/Activated , którego podobno nie da się usunąć
