Czy ktoś może wyczytać coś z tych logów???
Adaptation Channel 001:
Stored value
ERROR:
Channel 01
Not
Available
Saturday,24,March,2012,07:52:51:10074
VCDS Version: Release 10.6.4
Data version: 20110418
Address 01: Engine Labels: 038-906-019-AVF.lbl
Control Module Part Number: 038 906 019 FP
Component and/or Version: 1,9l R4 EDC 0000SG 1467
Software Coding: 00002
Work Shop Code: WSC 63351
Additional Info: WAUZZZ8EX2A129634 AUZ6Z0A0198173
VCID: 6ADFC69B3CEF
3 Faults Found:
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
P1156 - 35-00 - -
17569 - Manifold Temp Sensor (G72): Open or Short to Plus
P1161 - 35-00 - -
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
Readiness: 0 0 X X X
Address 01: DTCs clearedSaturday,24,March,2012,07:57:58:10074
Address 01: Engine (038 906 019 FP)
07:57:54 Group 013: Idle Speed Smooth Running Control
-1.39 mg/str Cyl 1 -2.8 to +2.8 mg/H
1.74 mg/str Cyl 2 -2.8 to +2.8 mg/H
0.94 mg/str Cyl 3 -2.8 to +2.8 mg/H
-1.32 mg/str Cyl 4 -2.8 to +2.8 mg/H
Saturday,24,March,2012,07:59:56:10074
07:59:53 Group 023
6.0 (no units)
7.0 (no units)
12.0 (no units)
4.0 (no units)
Saturday,24,March,2012,08:06:57:10074
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Control Module Part Number: 8E0 614 517
Component and/or Version: ABS/ESP front 1726
Software Coding: 04255
Work Shop Code: WSC 06435
VCID: E5C535A755F1
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Saturday,24,March,2012,17:42:15:10074
17:42:12 Group 004: Unit Injectors valves command
882 /min Engine speed 790-870
-0.0 °ATDC Spec start of inj. 4BTDC-2ATDC
6.6°KW Spec inj. duration 3-8 °Ck.
0.6°KW Synchro. angle -3..+3°Ck.
17:42:12 Group 005: Starting conditions
882 /min Engine speed rpm
16.5 mg/str Start inj quantity
1.0 Start synchro.
67.5°C Coolant temp °C
17:42:12 Group 006: Switch Positions (See label file for #2
0.0 km/h Speed km/h
1 0 0 Brake Pedal F/F47/F36
0.0 % Cruise Control Cl/Br/Re/Ac/on/on
255.0 Cruise System 0
Sunday,25,March,2012,11:34:51:10074
11:34:49 Group 008: Injected Quantity(IQ) limitation (3rd gear - 3000rpm - full load)
3129 /min Engine speed 2850-3150
6.9 mg/str IQ driver's req 65-70
50.8 mg/str IQ via rpm(Torq) 47-51
34.9 mg/str IQ via MAF 47-60
11:34:49 Group 023
4.0 (no units)
-1.0 (no units)
-4.0 (no units)
1.0 (no units)
Tuesday,03,April,2012,11:59:57:10074
11:59:10 Group 010: Air system (3rd gear - 3000rpm - full load)
759.5 mg/str MAF 900-1250
979.2 mbar Atmos. pressure sensor -f96-
1497.6 Intake air press. 2100-2600
33.3 % Throttle 100%
11:59:10 Group 008: Injected Quantity(IQ) limitation (3rd gear - 3000rpm - full load)
1911 /min Engine speed 2850-3150
14.5 mg/str IQ driver's req 65-70
51.9 mg/str IQ via rpm(Torq) 47-51
42.0 mg/str IQ via MAF 47-60
11:59:10 Group 023
-10.0 (no units)
-7.0 (no units)
3.0 (no units)
-5.0 (no units)
i jeszcze drugi wrzuce
Stored value
ERROR:
Channel 01
Not
Available
Saturday;24;March;2012;07:52:51:10074
VCDS Version: Release 10,6,4
Address 01: Engine Labels: 038-906-019-AVF,lbl
Component and/or Version: 1;9l R4 EDC 0000SG 1467
VCID: 6ADFC69B3CEF
3 Faults Found:
P1156 - 35-00 - -
P1161 - 35-00 - -
P1557 - 35-00 - -
Address 01: DTCs clearedSaturday;24;March;2012;07:57:58:10074
-1,39 mg/str Cyl 1 -2,8 to +2,8 mg/H
1,74 mg/str Cyl 2 -2,8 to +2,8 mg/H
0,94 mg/str Cyl 3 -2,8 to +2,8 mg/H
-1,32 mg/str Cyl 4 -2,8 to +2,8 mg/H
Saturday;24;March;2012;07:59:56:10074
07:59:53 Group 023
6,0 (no units)
7,0 (no units)
12,0 (no units)
4,0 (no units)
Saturday;24;March;2012;08:06:57:10074
Address 03: ABS Brakes Labels: 8E0-614-517,lbl
VCID: E5C535A755F1
1 Fault Found:
Saturday;24;March;2012;17:42:15:10074
-0,0 °ATDC Spec start of inj, 4BTDC-2ATDC
6,6°KW Spec inj, duration 3-8 °Ck,
0,6°KW Synchro, angle -3,,+3°Ck,
16,5 mg/str Start inj quantity
1,0 Start synchro,
67,5°C Coolant temp °C
0,0 km/h Speed km/h
0,0 % Cruise Control Cl/Br/Re/Ac/on/on
255,0 Cruise System 0
Sunday;25;March;2012;11:34:51:10074
6,9 mg/str IQ driver's req 65-70
50,8 mg/str IQ via rpm(Torq) 47-51
34,9 mg/str IQ via MAF 47-60
11:34:49 Group 023
4,0 (no units)
-1,0 (no units)
-4,0 (no units)
1,0 (no units)
Tuesday;03;April;2012;11:59:57:10074
759,5 mg/str MAF 900-1250
979,2 mbar Atmos, pressure sensor -f96-
1497,6 Intake air press, 2100-2600
33,3 % Throttle 100%
14,5 mg/str IQ driver's req 65-70
51,9 mg/str IQ via rpm(Torq) 47-51
42,0 mg/str IQ via MAF 47-60
11:59:10 Group 023
-10,0 (no units)
-7,0 (no units)
3,0 (no units)
-5,0 (no units)
Tuesday;03;April;2012;12:02:29:10074
12:02:28 Group 011: Charge pressure control (3rd gear - 3000rpm - full load)
1554 /min Engine speed 2850-3150
1795,2 mbar Spec, intake press, 2200-2400
1567,8 Actual intake press, 2100-2600
28,7 % D,cycle MAP 35-80%
12:02:28 Group 008: Injected Quantity(IQ) limitation (3rd gear - 3000rpm - full load)
1449 /min Engine speed 2850-3150
12,9 mg/str IQ driver's req 65-70
46,1 mg/str IQ via rpm(Torq) 47-51
38,4 mg/str IQ via MAF 47-60
12:02:28 Group 023
-2,0 (no units)
2,0 (no units)
3,0 (no units)
-2,0 (no units)
Jak coś źle zrobione to poprowadźcie jak jak co trzeba zrobić jak należy,problem tkwi z zamuleniem autka i odpalaniem,raz odpala na cykniecie raz po 2 sekundach.Dodam,że EGR zaślepiony.
Po pierwsze to pomyliles dzialy... o ocena logow piszesz w dziale "Diagnostyka VAG"
Po drugie to te logo sa zle zrobione. Zagladnij do dzialu diagnostyka i zobacz jak to ma poprawnie wygladac.
a początek wykasuj błędy, i sprawdz czy się pojawią ponownie.
