[B5 AVG] Kody wyposażenia
Witam.
wcześniej kwestje wstawiłem w nie ten dział co trzeba
mam nadzieje że tym razem trafiłem. Ale do rzeczy:
Dzisiaj spisałem kody wyposażenia-
dekoder - tłumaczenie komputerowe
I oto co wyszło (was to pewnie ubawi):
1KD = Disc brakes, rear
3FA = Without roof insert (standard roof)
F4J = Equipment for criminal investigation department vehicles
T1R = 4-cylinder diesel engine 1.9 L unit 028.R
2PG = Steering wheel
7Q0 = Without navigation device
3L1 = Manual height adjustment for left front seat
1SA = Without additional engine guard
J0R = Battery 380 A (80 Ah)
0L2 = Electric throttle actuation
3NZ = Rear seat bench unsplit, backrest split folding
C8N = Alloy wheels 7.5J x 18
4UE = Air bag for driver and front seat passenger
1LB = Disc brakes, front
BGL = code not found :-(
8JH = Ellipsoidal headlight for driving on the right
8Q1 = Headlight-range adjustment
7K0 = Without tire pressure warning light
5MY = Decorative aluminum inserts "stars graphite"
6X6 = code not found :-(
0G1 = Gearshift lever
U2A = Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
9Q0 = Without multi-function display/ on-board computer
4X1 = Side air bag front
3Y0 = Without roll-up sun screen
Q1A = Standard front seats
5SL = Left exterior mirror: aspherical
1AH = Electronic differential lock (EDL)
7X0 = Without park distance control
0YR = Weight range 16 installation control only, no requirement forecast
X0A = National sales program Germany
8Z8 = Engine cooling system, type 4
2K1 = Reinforced bumpers
4K4 = Radio remote controlled central locking
5RQ = Right exterior mirror: convex
1BA = Standard suspension/shock absorption
4R2 = Power windows front, mechanical window regulators rear
0JH = Weight category front axle weight range 8
M6N = 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIwith MVEG 2 base engine is T1R
6R2 = Leather gearshift boot
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
4GH = Windshield in heat-insulating glass with sunshield
1KD = hamulce Dysku, wznosić
3FA = Bez dachu wstaw (standardowy dach)
F4J = Wyposażenie dla zbrodniczych pojazdów działu śledztwa
T1R = 4 - cylinder silnik diesla 1.9 części L 028. R
2PG = kierownica
7Q0 = Bez urządzenia nawigacji
3L1 = Ręczny dostosowanie wzrostu dla lewego przedniego siedzenia
1SA = Bez dodatkowej straży silnika
J0R = Bateria 380 (80 Ach)
0L2 = Naładowany uruchomienie przepustnicy
3NZ = Wznosić unsplit ławki siedzenia, fałd pęknięcia backrest
C8N = koło Stopu 7.5 x 18 juniora
4UE = torba Powietrza dla kierowcy i przedniego pasażera siedzenia
1LB = hamulce Dysku, przód
BGL = kod nie znalazł :-{
8JH = przednie światło Ellipsoidal dla jechania po prawej stronie
8Q1 = Przednie światło długoterminowy dostosowanie
7K0 = Bez światło ostrzegać ciśnienia opony
5MY = Dekoracyjne aluminium wstawia "oznacza gwiazdką grafit"
6X6 = kod nie znalazł :-{
0G1 = dźwignia Gearshift
U2A = wkładka Instrumentu z km / h szybkościomierzem,radiowy - kontrolowanym opanowany zegarem, prędkościomierzem i odometr podróży
9Q0 = wielo - - zadziałaj pokazać / pokładowy komputer
4X1 = przód torby powietrza Strony
3Y0 = Bez lista - w górę ekran słońca
Q1A = Standardowy przedni siedzenie
5SL = Zostawione zewnętrzna strona lustro: aspherical
1AH = Elektroniczny zróżnicowany zamek (EDL)
7X0 = Bez kontroli odległości parku
0YR = zasięg Wagi 16 kontroli instalacji tylko, żadne przewidywanie wymagania
X0A = Narodowy program sprzedaży Niemcy
8Z8 = system chłodzenia Silnika, napisz 4
2K1 = Wzmocniony zderzak
4K4 = Radio odległe skontrolowało centralny blokujący
5RQ = Dobrze zewnętrzna strona lustro: wypukły
1BA = Standardowe zawieszenie / szok absorpcja
4R2 = przód okien Władzy, mechaniczne okienne regulatory wznosić
0JH = zasięg wagi osi przodu kategorii Wagi 8
M6N = 4 - cyl. eng diesla turbo. 1.9 L / 81 kW TDIwith MVEG 2 podły silnik jest T1R
6R2 = but gearshift Skóry
5D1 = częstość Roznosiciela 433.92 MHz -434.42 Mhz
4GH = Przednia szyba w termoizolacyjnym szkle z sunshield
no i ???
wyszły mi bzdury
a chciałem wiedziec czy mam tempomat orginał
czy tylko ktoś zmienił przełocznik bo za ch...e
nie działa
