Interpretacja VAG + objawy
Proszę o wypowiedzenie sie na temat poniższego raportu Vag-a gdyż ja jestem w tych sprawach ziolony.
I jeszcze mam pytanie czy ktoryś z tych błedów jest powodem szarpania i dławienia silnika przy gwałtowniejszym dodaniu gazu ( na lpg i benz ).
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 557 C
Component: 1,8L R4/5V MOTR HS D08
Coding: 04001
Shop #: WSC 00000
4 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
00561 - Mixture Adaptation
12-10 - Adaptation Limit (Mul) Exceeded - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 D
Component: ABS BOSCH 5 4174
Coding: 0265108005
Shop #: BB 34174
2 Faults Found:
00597 - Wheel Speed Impulses: Deviation
00283 - Front Left ABS Wheel Speed Sensor (G47)
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04161
Shop #: WSC 06335
7 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
00532 - Supply Voltage B+
07-00 - Signal to Low
01297 - Sensor for Vent Temperature: Footwell (G192)
01296 - Sensor for Vent Temperature: Center (G191)
01206 - Signal for Duration of Ignition: OFF
27-10 - Implausible Signal - Intermittent
01582 - Signal for Coolant Temperature
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 033 C
Component: B5_KOMBIINSTRUMENT D08
Coding: 00142
Shop #: WSC 06313
No fault code found.
Address 25 -------------------------------------------------------
Controller: 4A0 953 234
Component: IMMO AUZ9Z0T5844724 D77
Coding: 00000
Shop #: WSC 04022
3 Faults Found:
01128 - Immobilizer Pickup Coil (D2)
35-00 - -
01176 - Key
00750 - Warning Lamp
End -------------------------------------------------------
Skanowanie: 01,02,03,08,15,17,25,35,45,55,56
Adres 01 ---------- -------------------------------------- -------
Kontroler: 8D0 907 557 C
Komponent: 1,8 L R4/5V MOTR HS D08
Kodowanie: 04001
: WSC 00000
4 Błędy Found:
18010 - Terminal zasilania 30: Zbyt niskie napięcie
P1602 - 35-10 --- Intermittent
00561 - Dostosowanie Mieszanka
10/12 - Limit Adaptacja (Mul) przekroczyła - Przerywany
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction w obwodzie
P0130 - 35-10 --- Intermittent
17978 - Start silnika zablokowany przez immobilisera
P1570 - 35-10 --- Intermittent
Gotowość: N / A
Adres 03 ---------- -------------------------------------- -------
Kontroler: 4D0 907 379 D
Komponent: ABS BOSCH 5 +4.174
Kodowanie: 0265108005
Sklep #: BB 34174
2 Błędy Found:
00597 - impulsy prędkości kół: odchylenie
00283 - Front Left ABS Wheel Czujnik prędkości (G47)
Adres 08 ---------- -------------------------------------- -------
Kontroler: 8L0 820 043 D
Komponent: A4 KLIMAVOLLAUTOMAT_D75
Kodowanie: 04161
: WSC 06335
7 Usterki znaleziono:
30-00 - Open lub krótki do B +
00792 - Przełącznik A / C Ciśnienie (F129)
31-00 - Open lub zwarcie do masy
00532 - Supply Voltage B +
01297 - Czujnik temperatury Vent: nogi (G192)
01296 - Czujnik temperatury Vent: Centrum (G191)
01206 - Sygnał Czas zapłonu: OFF
27-10 - nieprawdopodobne Signal - Intermittent
01582 - Sygnał temperatury płynu
Pomijanie adres 15-poduszek powietrznych
Adres 17 ---------- -------------------------------------- -------
Kontroler: 8D0 919 033 C
Komponent: B5_KOMBIINSTRUMENT D08
Kodowanie: 00142
: WSC 06313
Kod nie znaleziono błędów.
Adres 25 ---------- -------------------------------------- -------
Kontroler: 4A0 953 234
Kodowanie: 00000
: WSC 04022
3 Błędy Found:
01128 - Coil Pickup Immobilizer (D2)
35-00 -
01176 - Klucz
00750 - Lampa ostrzegawcza
Koniec ------------------------------------------------- ------
Wujek google to wyplul po tlumnaczeniu
Moze cos Ci to pomorze
Może szarpać. Prawdopodobnie lambda do wymiany. Usuń błędy i zobacz jakie się pojawią.
