maciucha512 Opublikowano 7 Kwietnia 2013 Opublikowano 7 Kwietnia 2013 Zrobiłem auto - scan i wywaliło mi następujące błędy: Sunday,07,April,2013,10:38:47:10074 VCDS Version: Release 10.6.4 Data version: 20110418 Chassis Type: 8D - Audi A4 B5 Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77 Mileage: 254400km/158076miles ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No: 028 906 021 CE Component: 1.9l R4 EDC 00SG 0803 Coding: 00002 Shop #: WSC 06325 VCID: 54A378638E6B No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl Part No: 8E0 614 111 Component: ABS 5.3 FRONT D11 Shop #: BB 24303 VCID: DBB1135F63B5 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl Part No: 8L0 820 043 B Component: A4 KLIMAVOLLAUTOMAT_D72 Coding: 04143 Shop #: WSC 06325 VCID: 2759FFAFEF7D 3 Faults Found: 00787 - Temperature Sensor in Fresh Air intake duct (G89) 30-10 - Open or Short to Plus - Intermittent 01273 - Fresh Air Blower (V2) 17-10 - Control Difference - Intermittent 01296 - Sensor for Vent Temperature; Center (G191) 30-10 - Open or Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8A0-959-655.lbl Part No: 8A0 959 655 C Component: Airbag V AUDI D00 Coding: 01022 Shop #: WSC 06324 VCID: 33611BFF2BA5 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8D0-919-0xx-17.lbl Part No: 8D0 919 034 E Component: B5-KOMBIINSTRUMENT__D12 Coding: 00140 Shop #: WSC 00186 VCID: 2B51039FF395 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: None Part No: 4A0 953 234 F Component: IMMO AUZ9Z0T7890339 D77 Coding: 00000 Shop #: WSC 00001 VCID: 2545F5A79571 No fault code found. ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8LO 862 257 Component: ZV-Pumpe, DWA, Funk D03 Coding: 10184 Shop #: WSC 65535 VCID: 112DB17771F9 1 Fault Found: 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - End --------------------------------------------------------------------- Dodatkowo zauważyłem błędne wskazania temperatury na FIS(czasami pokazuje prawidłowo) oraz brak oświetlenia w bagażniku po otwarciu klapy (wiąże to z wszechobecną śniedzią na wszystkich stykach w klapie). Czy mógłby ktoś nakierować mnie gdzie szukać przyczyny wyżej wymienionych błędów? Czy dobrze mi się wydaję, że w przypadku złych wartości temperatury na FIS klima może nie wystartować w potrzebie?
lukjar7 Opublikowano 7 Kwietnia 2013 Opublikowano 7 Kwietnia 2013 pierwsza czynnosc w takich przypadkach to skasowanie wszystkich bledow i ponowne odczytanie po kilku dniach ktore wracaja
maciucha512 Opublikowano 10 Kwietnia 2013 Autor Opublikowano 10 Kwietnia 2013 Skasowałem błędy i ponownie przeskanowałem wóz, wychodzą ciągle te same błędy. Ponawiam prośbę o pomoc w zidentyfikowaniu ew źródeł problemów. ---------- Post dopisany 10-04-2013 at 06:57 ---------- Poprzedni post napisany 09-04-2013 at 12:17 ---------- up
