prośba o wytłumaczenie błędów w vcds-autoscan
dzisiaj zrobiłem autoscan w vcds i oto co pokazał
o co chodzi z tymi błędami centralnego? auto było zamknięte w trakcie skanowania
VCDS-Lite Version: Release 1.2
Thursday, 26 February 2015, 15:42:48:0
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 038 906 018 FD
Component: 1,9l R4 EDC 0010SG 2137
Coding: 00002
Shop #: WSC 06335
VCID: 5DCD1A77C429
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
VCID: 5ECF1D7BC92F
Address 08: Auto HVAC Labels: 8E0-614-111-ABS.LBL
Controller: 8D0 820 043 M
Component: A4 KLIMA
VCID: 2A2781ABC5E7
Note: Excessive Comm Errors
Address 15: Airbags Labels: 8D0-959-655-AI8.LBL
Controller: 8D0 959 655 J
Component: Airbag Front+Seite 0001
Coding: 00104
Shop #: WSC 06335
VCID: 3D0DBAF72469
Address 17: Instruments Labels: 8D0-919-xxx-17.LBL
Controller: 8D0 919 861 F
Component: B5-KOMBIINSTR. VDO D15
Coding: 01040
Shop #: WSC 00000
VCID: 341B9FD31723
IMMO-IDENTNR: AUZ7Z0X1078463
Address 25: Immobilizer Labels: None
Controller: Bit teA dre ssu
Component: e 17 eingeben
VCID: CFD1703F1EC5
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Controller: 8D0 862 257 C
Component: ZV-Pumpe D12
Coding: 00065
Shop #: WSC 37303
VCID: 2D2D8AB7F409
4 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01361 - Switch for Anti-Theft Alarm; Close
29-00 - Short to Ground
01389 - Tailgate Open Switch (F124)
00991 - Interior Lights
28-00 - Short to Plus
End --------------------------------------------------------------------------------------------------
dzięki wielkie :)
poniżej wklejam wyniki
centralny działa, klapę też mogę zamknąć i otworzyć (co prawda wszystko z kluczyka, pilot mi nie działa, ale z tego co wiem mój model nie ma obsługi alarmu i pilota mimo że to lift)
1. 01367
(Kody błędów)
Pompka centralnego zamka, przekroczony czas pracy. Możliwe przyczyny : Nieszczelność w układzie pneumatyki centralnego zamka. (przewody lub siłowniki) Uszkodzona pomka centralnego ...
1. 01361
(Kody błędów)
Przełącznik systemu ochrony przeciwkradzieżowej; zamknięty zwarcie z masą
1. 01389
(Kody błędów)
Wyłącznik F124 otwierania tylnej pokrywy. Zwarcie z masą. Usterka zostaje wykazana po naciśnięciu i przytrzymaniu dłużej niż 5 minut.
po przekręceniu kluczyka zamykają się wszystkie drzwi i bagażnik, pompkę słychać jakieś 3-4 sekundy - co mogą w tej sytuacji oznaczać te błędy?
