Prezes870 Opublikowano 2 Maja 2015 Opublikowano 2 Maja 2015 Witam, w mojej atrojce mam brak nawiewu na szybe ;/ klikam na nadmuch na szybe i dmucha na wszystkie po trochu ;/ tak samo auto. Nie ma szans zeby w zaparowanym aucie odparowac szyby. Oto jakie mam bledy01487 - System Function Test 008 - Implausible SignalFreeze Frame:Fault Status: 01101000Fault Priority: 3Fault Frequency: 1Reset counter: 211Mileage: 141511 kmTime Indication: 0Date: 2008.08.25Time: 17:25:50Freeze Frame:00716 - Air recirculation Flap Positioning Motor (V113) 003 - Mechanical FailureFreeze Frame:Fault Status: 01100011Fault Priority: 3Fault Frequency: 254Reset counter: 170Mileage: 180835 kmTime Indication: 0Date: 2014.04.24Time: 17:23:45Freeze Frame:Voltage: 14.30 VTemperature: 28.0°C(no units): 228.0(no units): 207.0Temperature: 21.5°C00710 - Defroster Flap Positioning Motor (V107) 003 - Mechanical FailureFreeze Frame:Fault Status: 01100011Fault Priority: 3Fault Frequency: 1Reset counter: 56Mileage: 100534 kmTime Indication: 0Freeze Frame:Voltage: 11.80 VTemperature: 1.0°C(no units): 192.0(no units): 37.0Temperature: -0.5°C00727 - Potentiometer in Positioning Motor for Defrost Flap (G135) 001 - Upper Limit ExceededFreeze Frame:Fault Status: 01100001Fault Priority: 3Fault Frequency: 1Reset counter: 211Mileage: 141512 kmTime Indication: 0Date: 2008.09.01Time: 17:59:32Freeze Frame:Voltage: 11.60 V(no units): 39.0Temperature: 23.5°C00483 - Control Module for Auxiliary Air Heater 013 - Check DTC MemoryFreeze Frame:Fault Status: 01101101Fault Priority: 3Fault Frequency: 1Reset counter: 166Mileage: 190781 kmTime Indication: 0Freeze Frame:ONBardzo bylbym wdzieczny za pomoc
