Bex 2003 - problem ABS ESP
Problem polega na pojawiającym się problemie ABS ESP. Może na podstawie logów ktoś coś podpowie co może być przyczyną.
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04475
Shop #: WSC 00000
VCID: 2649EED8C219CC2ECEF-5072
3 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
30-10 - Open or Short to Plus - Intermittent
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 63251
VCID: 346D049004C5AEBE40B-4A9C
2 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
57-00 - Electric Circuit Failure
01312 - Powertrain Data Bus
79-10 - Please Check Fault Codes - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 03001
Shop #: WSC 00000
VCID: 2D5B11F4E7EFFF760F5-5000
WAUZZZ8E83A396871 AUZ6Z0C0175027
1 Fault Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BA
Component: Komfortgerát TA7 1310
Coding: 07008
Shop #: WSC 21148
VCID: 71E3CD843B57DB966BD-4A9C
Subsystem 1 - Part No: 8E1959801B
Component: Tőrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802B
Component: Tőrsteuer.BF BRM 0003
2 Faults Found:
00955 - Key 1
01559 - Drivers Door
59-10 - Can't Unlock - Intermittent
End ---------------------------------------------------------------------
Problem rozwiązany padł sterownik abs - wymiana + adaptacja.
