Audi A4 B5 Quattro bez Quattro
U mnie w papierach też miałem quattro.
1.9 TDI 110 kucy
Wychodziły z q i bez.
Niestety nie mam chodź poprzednie papiery właściciela OC wskazywały na quattro
Ajl jak i bex bylo w q i osce.
No sorry, ale to raczej nie quattro a tylko wymieniona klapa.
4GH WSS Windshield in heat-insulating glass with sunshield
Q1S VOS Reinforced sports seat, front left
1BA DAE Standard suspension/shock absorption
1SA TWU Without additional front underbody guard
5D1 TRF Carrier frequency 433.92 MHz-434.42 Mhz
4K4 TKV Radio remote controlled central locking
3Y0 SSR Without roll-up sun screen
3L3 SIE Manual height adjustment for front seats
6R2 SHV Leather gearshift boot
2K1 SFS Reinforced bumpers
4X1 SAB Side air bag front
7K0 RDK Without tire pressure warning light
CC7 RAD Alloy wheels 7J x 17
7Q9 NAV Navigation system
MJ8 MOT 4-cyl. gasoline engine 1.8 L/132 kW 20V turbo, MVEG 2 base engine is T8B/T8C
8Z5 MKU Not hot country
9Q2 MFA Multi-function display/on-board computerwith check control
8Q1 LWR Headlight-range adjustment
2PV LRA Leather trimmed sports steering wheel
X0A LDA National sales program Germany
U1U INS Instrument insert w/ km/h speedo, clock tachometer, trip odometer, additional instruments with special color trim
8JH HSW Ellipsoidal headlight for driving on the right
3NZ HIS Rear seat bench unsplit, backrest split folding
T8B GMO 4-cylinder gasoline engine 1.8 L unit 058.D
0JE GKV Weight category front axle weight range 5
0YD GKH Weight range 4 installation control only, no requirement forecast
0G1 GES Gearshift lever
8GD GEN Alternator 90A
0L0 GAB Mechanical throttle actuation
F0A FZS No special purpose vehicle, standard equipment
4R3 FEH Power windows with comfort operation
7X0 EPH Without park distance control
5TG EIH Decorative aluminum inserts, dulling
3FA DEI Without roof insert (standard roof)
1BV DAE Sports suspension/shock absorption
1AC BRS Anti-lock brake system (ABS)
1LB BAV Disc brakes, front
J1P BAT Battery 220 A (44 Ah)
1KD BAH Disc brakes, rear
5RQ ASR Right exterior mirror: convex
5SL ASL Left exterior mirror: aspherical
6XD ASE Exterior mirrors: electrically adjustable/heated
4UE AIB Air bag for driver and front seat passenger
E0A AAU No special edition
Jak chcesz sam posprawdzać kody to polecam
http://vag-codes.info/
http://www.audiklub.org/wyposazenie.html
Tylko Vinu sobie nie sprawdzaj bo wychodzi, że diesel :D jakiś głupi dekoder.
Może zaczniemy od tego co napisałeś. Skąd wiesz, że fabrycznie było w Q? Bo kody na to nie wskazują, a klapa to za mało, no i zostaje listwa nad schowkiem, którą nie tak łatwo wymienić jak klapę.
Rozkodowałem wszystkie kody jakie są na naklejce w książce serwisowej (zgadzają się z tą w bagażniku) i nie ma żadnego kodu że ma wyposażenie w Quattro, pozostaje tylko wejść pod samochód :D
W moim Audi nigdy nie było i jednak chyba nigdy nie bedzie quattro :D , więc temat chyba do zamknięcia. Dzięki za pomoc i pozdrawiam :>!
Edytowane przez BorszuG180
