l.e.s.t.e.r 27 Opublikowano 10 Maja 2016 Udostępnij Opublikowano 10 Maja 2016 (edytowane) Cześć, Wymieniłem przekładnie na Servotronic, niestety po zakodowaniu nie działa, dodatkowo wali strasznie błędami. Proszę o jakieś wskazówki. Tuesday,10,May,2016,15:48:15:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: Release 12.12.0 (x64) Data version: 20130910 VIN: WAUZZZ8K69A217614 License Plate: Mileage: 189170km-117544mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8K (8T0) Scan: 01 03 05 07 08 09 0E 10 15 16 17 19 37 42 46 47 52 53 56 62 72 VIN: WAUZZZ8K69A217614 Mileage: 189170km/117544miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAGB) Labels: None Part No SW: 03L 906 022 ML HW: 03L 906 022 B Component: R4 2,0L EDC X01 4376 Revision: 11X01--- Coding: 0104002C18072118 Shop #: WSC 92521 052 00000 ASAM Dataset: EV_ECM20TDI03L906022ML A01004 ROD: EV_ECM20TDI03L906022.rod VCID: 7BF51167F210BBC6C11-802E No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb Part No SW: 8K0 907 379 AE HW: 8K0 907 379 AE Component: ESP8 front H04 0240 Revision: -------- Serial number: -------------- Coding: 160500 Shop #: WSC 06325 000 00000 VCID: 7CF7127BFF1EBCFEC8B-8029 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 N HW: 8K0 907 064 N Component: BCM2 1.1 H80 0145 Revision: 00002001 Coding: 030200 Shop #: WSC 06325 000 00000 VCID: 3B75D167BA907BC6811-806E Subsystem 1 - Part No SW: 8K0 959 754 D HW: 8K0 959 754 D Component: FBSAUDIB8 IDG H71 0083 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H36 0041 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb Part No SW: 8T0 035 729 N HW: 4E0 035 729 Component: Interfacebox H43 5150 Revision: 00000000 Serial number: 329C1097639975 Coding: 0040013 Shop #: WSC 00000 000 08192 VCID: 4487AA9B076E043EF0B-8011 Subsystem 1 - Part No: 8T0 919 609 Component: E0380 BedienteilH08 0100 Subsystem 2 - Serial number: 00000000244800 Subsystem 3 - Serial number: 0121.02.090000000100010376ÿ Subsystem 4 - Serial number: 010376ÿ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA Component: KLIMA 1 ZONE H06 0150 Revision: A1000000 Serial number: 01120320091706 Coding: 34000000 Shop #: WSC 06325 000 00000 VCID: 70EF364BA356C89E643-8025 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 D HW: 8K0 907 063 D Component: BCM1 1.0 H21 0253 Revision: 05021001 Serial number: 00000000121120 Coding: 260010B10134AF300001000300001D0D001C060800000101000000 Shop #: WSC 12345 123 12345 VCID: 306FF64B63D6889E243-8065 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 130309 H06 0070 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 0031 2 Faults Found: 03110 - Active Steering Control Module (J792) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 155 Mileage: 189176 km Time Indication: 0 Date: 2016.05.10 Time: 15:43:00 03207 - Charisma Switch Module 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 155 Mileage: 189176 km Time Indication: 0 Date: 2016.05.10 Time: 15:43:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 8T1 035 110 C HW: 8T1 035 110 C Component: MP3-Changer H43 0390 Revision: 00043003 Serial number: AUZ5ZBI8762529 Shop #: WSC 00000 000 00000 VCID: 2A5BE423850AF24EEA7-807F No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb Part No SW: 8K0 919 475 F HW: 8K0 919 475 Component: PARKHILFE 4K H06 0040 Revision: 11001001 Serial number: 40140907104230 Coding: 100003 Shop #: WSC 06325 123 12345 VCID: 3C77D27BBF9E7CFE88B-8069 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H27 0410 Serial number: 0038JD1ER447 Coding: 30343435363030303030554A304C384B3053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 3C77D27BB79E7CFE88B-8069 Crash sensor for side airbag; driver side: Serial number: 6334MSME41056233/ Crash sensor for side airbag; passenger side: Serial number: 6344MSME45242143% Crash sensor for side airbag; rear driver side: Serial number: 6352QSME541A1918G Crash sensor for side airbag; rear passenger side: Serial number: 6362QSME151B24046 Crash sensor for front airbag; driver side: Serial number: 63732SME6C1B1A085 Crash sensor for front airbag; passenger side: Serial number: 63832SME6C1B4E3CK No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H16 0014 Revision: -------- Serial number: 90304ICB0002T Coding: 000017 Shop #: WSC 06325 000 00000 VCID: 3D71DF7FA48475F6BF5-8068 Component: E221 - MFL H06 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 930 C HW: 8K0 920 930 C Component: KOMBIINSTR. H18 0224 Revision: 00200000 Serial number: 9E227A239 Coding: 0D0D100002000008010000 Shop #: WSC 06325 123 12345 VCID: 2D51EF3F74E4E5760F5-8078 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 P HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0095 Revision: EB500046 Serial number: 4600E092248043 Coding: 000303 Shop #: WSC 06325 000 00000 VCID: 4E9388B31922FE6E56F-801B Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E Component: J367-BDM H06 0160 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 M Component: MNS ECE H52 1060 Revision: 00000000 Serial number: 333CZ097649853 Shop #: WSC 06325 000 00000 VCID: 3B75D1677A907BC6811-806E No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 E HW: 8K0 959 793 E Component: TSG FA H11 0250 Revision: Serial number: 0000008548479 Coding: 011002204000410001 Shop #: WSC 06325 000 00000 VCID: 428BAC83DD7A0A0EC27-8017 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 N HW: 8K0 907 064 N Component: BCM2 1.1 H80 0145 Revision: 00002001 Serial number: 0117351890 Coding: 013A062020390040022002 Shop #: WSC 06325 000 00000 VCID: 3B75D167BA907BC6811-806E Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: 8T0-035-223-BAM.clb Part No SW: 8T0 035 223 AE HW: 8T0 035 223 R Component: DSP Basic H08 0300 Revision: S2600000 Coding: 010101 Shop #: WSC 06325 000 00000 VCID: 71E9334FA85CC1966BD-8024 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 E HW: 8K0 959 792 E Component: TSG BF H11 0250 Revision: Serial number: 0000008674364 Coding: 011002204C00410001 Shop #: WSC 06325 123 12345 VCID: 4189A38FD87C1116DBD-8014 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 G HW: 8K0 907 801 G Component: EPB Audi B8 H08 0080 Revision: 00000003 Serial number: 00000000327621 Shop #: WSC 00000 000 00000 VCID: 3365F94792C0B386591-8066 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4F0 035 541 N Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 357CV097525913 Coding: 0000001 Shop #: WSC 06325 000 00000 VCID: 3169F34FA8DC81962BD-8064 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HL H10 0251 Revision: Serial number: 0000008613625 Coding: 010002204000210001 Shop #: WSC 06325 000 00000 VCID: 4487AA9BC76E043EF0B-8011 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HR H10 0251 Revision: Serial number: 0000008618067 Coding: 010002204000210001 Shop #: WSC 06325 000 00000 VCID: 4487AA9BC76E043EF0B-8011 No fault code found. End --------------------------------------------------------------------- Moduł z końcówką D Piny są Edytowane 10 Maja 2016 przez l.e.s.t.e.r Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
edraven 10 Opublikowano 10 Maja 2016 Udostępnij Opublikowano 10 Maja 2016 rozumiem że zmieniłeś samą maglownicę bez kolumny? Z magla pociągnąłes dwa przewody do wtyku zgodnie ze schematem, magiel miał numer 8T1 422 066 B i do czarnej wtyczki 17 pin wpiąłeś przewody na 1 i 12 pin w MCE ? Podeślij kodowanie w MCE. Kodowałeś tylko 7 Bajt, bit 0? czy jeszcze coś? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
l.e.s.t.e.r 27 Opublikowano 10 Maja 2016 Autor Udostępnij Opublikowano 10 Maja 2016 kodowanie MCE Na rysunku w poście wyżej czerwonymi kóleczkami zaznaczyłem piny które są podpięte. Wymieniłem magiel na ten z pierwszego posta w tym temacie, dwa kable od magla do modułu MCE. Jedynie co mi do głowy przychodzi to że coś z tymi pinami jest. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wrclaguna 342 Opublikowano 10 Maja 2016 Udostępnij Opublikowano 10 Maja 2016 A widzisz co wogóle zakodowałes ? Bo ze scanu widac ze nie masz aktywnego ukladu kierowniczego oraz AUDI DRIVE SELECT Tu masz :KODOWANIE SERVOTRONIC :MCE 09 ---> LongCodingHelper ---> Coding 07 ---> BYTE 7 ---> Bit 0 zmiana z 0 na 1 . 1 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
l.e.s.t.e.r 27 Opublikowano 10 Maja 2016 Autor Udostępnij Opublikowano 10 Maja 2016 ło matko jak ja to czytałem Już wszystko pięknie bangla, różnica powalająca. Dzięki za pomoc. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
luki358 0 Opublikowano 12 Sierpnia 2018 Udostępnij Opublikowano 12 Sierpnia 2018 Witam mam też problem z servotronikiem proszę o pomoc w kodowanie vcds po polsku Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
luki358 0 Opublikowano 12 Sierpnia 2018 Udostępnij Opublikowano 12 Sierpnia 2018 W dniu 10.05.2016 o 17:13, wrclaguna napisał: A widzisz co wogóle zakodowałes ? Bo ze scanu widac ze nie masz aktywnego ukladu kierowniczego oraz AUDI DRIVE SELECT Tu masz :KODOWANIE SERVOTRONIC :MCE 09 ---> LongCodingHelper ---> Coding 07 ---> BYTE 7 ---> Bit 0 zmiana z 0 na 1 . Witam mam też problem z servotronikiem proszę o pomoc w kodowanie vcds po polsku Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
wrclaguna 342 Opublikowano 13 Sierpnia 2018 Udostępnij Opublikowano 13 Sierpnia 2018 KODOWANIE SERVOTRONIC :MCE 09 ---> LongCodingHelper ---> Coding 07 ---> BYTE 7 ---> Bit 0 zmiana z 0 na 1 . Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
