Prośba o pomoc w usunięciu błędów
Witam serdecznie proszę o pomoc w usunięciu błędów. Podejrzewam że coś namotałem sam /szczególnie 01207 - Control Module for Auxiliary Heater (J364) /
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 56 5F 62 69 72
VIN: WAUZZZ8K3CA018110
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CJCB) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 JR HW: 03L 906 018 DN
Component: R4 2,0L EDC H23 8969
Revision: 45H23---
Coding: 12194012243403080000
Shop #: WSC 00114 211 105553
ASAM Dataset: EV_ECM20TDI01103L906018JR 003006
ROD: EV_ECM20TDI01103L906018JR.rod
VCID: 8305E9870AE04306091-80D6
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BF HW: 8K0 907 379 BF
Component: ESP8 front H04 0030
Revision: -------- Serial number: --------------
Coding: 168504
VCID: 7EF31873E902AEEEE6F-802B
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CN HW: 8K0 907 064 CN
Component: BCM2 2.0 H05 0435
Revision: 00002001
Coding: 030200
Shop #: WSC 06325 123 12345
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AG HW: 8T1 820 043 AG
Component: KLIMA 1 ZONE H08 0180
Revision: A0000000 Serial number: 01220620111122
Coding: 34380000
VCID: 76E30053C132E6AEBEF-8023
1 Fault Found:
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 201174 km
Time Indication: 0
Date: 2016.08.15
Time: 20:54:43
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 K HW: 8K0 907 063 K
Component: BCM1 1.0 H30 0392
Revision: 06030001 Serial number: 00000001115429
Coding: 690080B10134AE000001000000005F5F0018260806000001000000
VCID: 377DCD5786B85FA6659-8062
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 230611 H07 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 AR HW: 8K0 941 531 AR
Component: E1 - LDS H03 0031
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 L HW: 8K0 959 655 L
Component: AirbagVW-AU10 H44 0610
Serial number: 003JMD0CYA3U
Coding: 30513435363030303030554A304C384B3053
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4683B093F952362EEEF-8013
Crash sensor for side airbag; driver side:
Serial number: 6334MSME6072247BC
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME60714F65I
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME4F0B0262H
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME710C3254C
Crash sensor for front airbag; driver side:
Serial number: 63732SME265C4C6EH
Crash sensor for front airbag; passenger side:
Serial number: 63832SME2D5C34545
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
Component: Lenks.Modul H07 0156
Revision: 00000000 Serial number: 20110630000023
Coding: 000017
VCID: 4999BBAFE04CD95603D-801C
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 N HW: 8K0 920 930 N
Component: KOMBIINSTR. H81 0639
Revision: 00000000 Serial number: JUG469N6C
Coding: 037D100002000008010100
VCID: 387FCE6B8BA650DE6C3-806D
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E116010454
Coding: 00CF07
VCID: 8305E98702E04306091-80D6
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 N HW: 8K0 959 793 N
Component: TSG FA H12 0357
Revision: Serial number: 0000006400181
Coding: 011003204000410001
VCID: 4B9581A7EA30CB46311-801E
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0152208766
Coding: 013E063820B904408320023280000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 N HW: 8K0 959 792 N
Component: TSG BF H12 0357
Revision: Serial number: 0000006401725
Coding: 011003204400410001
VCID: 4A9B84A3E54AD24E0A7-801F
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000963411
Shop #: WSC 00000 000 00000
VCID: 3467FA5B97CEB4BE40B-8061
Address 56: Radio ® Labels: Redir Fail!
Part No SW: 4G0 035 056 H HW: 4G0 035 056
Component: Radio U STD H52 0134
Revision: AB001007 Serial number: 469F40B7760259
Coding: 010003020100000001
VCID: 264310135112D62ECEF-8073
1 Fault Found:
02246 - Loudspeaker; Center
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Mileage: 201174 km
Time Indication: 0
Date: 2016.08.15
Time: 20:54:44
Freeze Frame:
Voltage: 12.30 V
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 652 L HW: 8T1 035 652 D
Component: B-BN-EU H61 0188
Revision: -------- Serial number: 323F20B7654698
Coding: 010100010006F7FFFF887F5D000000030001
VCID: 3E73D873A9826EEEA6F-806B
Subsystem 1 - Part No SW: 8T0 919 604 HW: 8T0 919 604
Component: DU6 Basic H42 0098
Subsystem 2 - Part No SW: 8T0 919 609 HW: 8T0 919 609
Component: E0380 Bedient H08 0100
2 Faults Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 12
Reset counter: 1
Mileage: 201174 km
Time Indication: 0
Date: 2016.08.15
Time: 20:55:03
Freeze Frame:
Bin. Bits: 00001101 11000000
Bin. Bits: 01001110 10000001
Bin. Bits: 00000000 00000100
Bin. Bits: 00000000 00000000
03278 - Functionality Limited due to Missing Messages
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 201174 km
Time Indication: 0
Date: 2016.08.15
Time: 20:54:53
Freeze Frame:
Bin. Bits: 00001000 00000000
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
Component: TSG HL H11 0357
Revision: Serial number: 0000006407349
Coding: 010003204000210001
VCID: 4581B79FCC543D36E75-8010
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 HW: 8K0 907 383
Component: Anhaenger H14 0080
Coding: 0100000000000000
VCID: F1E9B34F285C4196EBD-80A4
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0000006407306
End ---------------------------------------------------------------------
Edytowane przez zdzislaw72
Kodowałeś wentylację? Z tym błędem trzeba żyć, chyba że sobie dorzucisz webasto.
Problem z głośnikiem masz, a MMI prawdopodobnie ma zakodowane coś czego nie ma.
