Kody błędów a a4 b8
Panowie, co oznaczają te kody błędów:
Address 01: Engine (J623-CAGC) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 019 AL HW: 03L 906 019 AL
Component: R4 2,0L EDC H22 9097
Revision: 25H22---
Coding: 0A194012232403080000
Shop #: WSC 04301 202 86974
ASAM Dataset: EV_ECM20TDI03L906019AL A02008
ROD: EV_ECM20TDI03L906019AL.rod
VCID: 75EA56BED41620B6AC3
3 Faults Found
5262 - Diesel Particle Filter; Differential Pressure Sensor
P2454 00 [168] - Short to GND
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 254
Mileage: 155864 km
Date: 2016.08.23
Time: 13:32:59
5162 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [237] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 156110 km
Date: 2016.09.10
Time: 06:45:38
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 00 [104] - Incorrect Correlation
Freeze Frame:
Fault Priority: 2
Mileage: 153529 km
Date: 2016.06.12
Time: 15:08:22
Readiness: 1 2 0 0 0
Dzięki za informację.
Wymieniłem czujnik DPF i dalej problem, wywaliło następujące błędy:
Revision: 25H22---
4 Faults Found
5253 - Diesel Particle Filter; Differential Pressure Sensor
P2452 00 [032] - Elect. Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 157227 km
Date: 2000.00.00
Time: 00:00:00
P2454 00 [040] - Short to GND
Freeze Frame:
Fault Priority: 2
Mileage: 155864 km
Date: 2016.08.23
Time: 13:32:59
P2453 00 [104] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Mileage: 156110 km
Date: 2016.09.10
Time: 06:45:38
P0016 00 [108] - Incorrect Correlation
Freeze Frame:
Fault Priority: 2
Mileage: 153529 km
Date: 2016.06.12
Time: 15:08:22
poradźcie co z tym dalej robić
Edytowane przez alex09-70
