Engine power lost
My car Audi A4. (2002) 1.9 TDI (130 kW). in the fleeting moment that reaches 100 or 120 km / h engine power loss. to function must be switched off and the engine.
can you tell me what is a problem.
Sent from my SM-G930P using Tapatalk
It's probably a problem with your turbo charger - overboost, Pressure is too high and the ECU is switching to Emergency mode.
Connect VCDS cable to your car and search for errors in the "Engine" module.
You thing ECU is not working.
What you thing for turbo charger.
ECU is working, but in "SAFE mode". It's because your Turbo charger is probably overboosting. You have to read error numbers first, without them, there is nothing more to say..
Thanks my frend.
