pakotomasz 0 Opublikowano 17 Stycznia 2017 Udostępnij Opublikowano 17 Stycznia 2017 Witam kolegów Dziś podpiąłem kompa pod kumpla Audi A3 8L w celu sprawdzenia tylko błędów. Wyskoczyło trochę tego w 2 blokach: Chassis Type: 8L - Audi A3/S3 Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76 VIN: WAUHF78P48A132452 Mileage: 68690km/42681miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.lbl Part No SW: 8P0 907 115 P HW: 8P0 907 115 B Component: 2.0l R4/4V TFSI 0010 Revision: 5BH16--- Serial number: AUX7Z0H0FN2006 Coding: 0103010A18070160 Shop #: WSC 06314 000 00000 VCID: 3F8947CF15BD 6 Faults Found: 000768 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - Upper Limit Exceeded - Intermittent - MIL ON Freeze Frame: Fault Status: 10100001 Fault Priority: 2 Fault Frequency: 4 Mileage: 68258 km Time Indication: 0 Date: 2017.01.10 Time: 15:03:04 Freeze Frame: RPM: 973 /min Load: 57.6 % Speed: 0.0 km/h Temperature: 3.0°C Temperature: 4.0°C Absolute Pres.: 970.0 mbar Voltage: 14.351 V 000769 - Cylinder 1: Misfire Detected P0301 - 001 - Upper Limit Exceeded - Intermittent - MIL ON Freeze Frame: Fault Status: 10100001 Fault Priority: 2 Fault Frequency: 4 Mileage: 68258 km Time Indication: 0 Date: 2017.01.10 Time: 15:03:46 Freeze Frame: RPM: 1142 /min Load: 41.2 % Speed: 0.0 km/h Temperature: 3.0°C Temperature: 4.0°C Absolute Pres.: 970.0 mbar Voltage: 14.224 V 000772 - Cylinder 4: Misfire Detected P0304 - 001 - Upper Limit Exceeded - Intermittent - MIL ON Freeze Frame: Fault Status: 10100001 Fault Priority: 2 Fault Frequency: 3 Mileage: 68360 km Time Indication: 0 Date: 2017.01.12 Time: 15:35:06 Freeze Frame: RPM: 1142 /min Load: 41.2 % Speed: 0.0 km/h Temperature: 3.0°C Temperature: 4.0°C Absolute Pres.: 970.0 mbar Voltage: 14.224 V 005634 - Power Supply Terminal 30: Voltage too Low P1602 - 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: -40.0°C Temperature: -40.0°C Absolute Pres.: 0.0 mbar Voltage: 0.000 V 008518 - Supply Voltage for Fuel Injector Group A: Open Circuit P2146 - 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Mileage: 68381 km Time Indication: 0 Date: 2017.01.13 Time: 00:04:01 Freeze Frame: RPM: 1199 /min Load: 29.0 % Speed: 0.0 km/h Temperature: 27.0°C Temperature: 25.0°C Absolute Pres.: 960.0 mbar Voltage: 11.557 V 008518 - Supply Voltage for Fuel Injector Group A: Open Circuit P2146 - 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Mileage: 68381 km Time Indication: 0 Date: 2017.01.13 Time: 00:04:01 Freeze Frame: RPM: 697 /min Load: 37.6 % Speed: 0.0 km/h Temperature: 27.0°C Temperature: 25.0°C Absolute Pres.: 960.0 mbar Voltage: 10.668 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG Component: KlimavollautomatH19 0430 Revision: 233871 Serial number: 8P0820043AG Shop #: WSC 00000 000 00000 VCID: 71EDD1F71369 2 Faults Found: 01592 - Air Quality Sensor (G238) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 133 Mileage: 67070 km Time Indication: 0 Date: 2016.12.01 Time: 18:25:46 Freeze Frame: Temperature: -50.0°C 01592 - Air Quality Sensor (G238) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 133 Mileage: 67244 km Time Indication: 0 Date: 2016.12.09 Time: 14:06:08 Freeze Frame: Temperature: -50.0°C Możecie pomóz i podpowiedzieć co one mogą oznaczać? Jeśli chodzi o jazdę samochodem to praktycznie nic nie czuć, żeby się działo. Samochód jeździ, rozpędza się tak jak należy. Jedynie co to na wskaźnikach świeci się "Check engine: i "EPC". Skasowałem wszystkie błędy, te 2 komunikaty na desce zniknęły jednak po kilkunastu km znowu się pojawiły. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
zwonko 11 Opublikowano 19 Stycznia 2017 Udostępnij Opublikowano 19 Stycznia 2017 Od tego zacznij:http://wiki.ross-tech.com/wiki/index.php/18010/P1602/005634 bo problemy z zasilaniem mogą powodować to:http://wiki.ross-tech.com/wiki/index.php/P2146/008518 a problemy z zasilaniem wtrysków pewnie robią missfire Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
