błędy po wyminie gateway-a
Cześć, wymieniałem gatewaya i pozostały mi takie błędy - moge prosić o pomoc w diagnozowaniu ich i usunięciu?
Mileage: 192990km-119918miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (------CDHA)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8K1 907 115 C    HW: 8K1 907 115
   Component: 1.8l R4/4V TF H10 0003
   Revision: A5H10---
   Coding: 0104000C18070058
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM18TFS8K1907115C A01004
   ROD: EV_ECM18TFS_AU48.rod
   VCID: 2E5364DE71D66F3202-807A
1 Fault Found:
2886 - Catalyst System; Bank 1
          P0420 00 [096] - Efficiency Below Threshold
          Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 BT    HW: 8K0 907 379 BT
   Component: ESP8 front    H04 0010
   Revision: --------    Serial number: --------------
   Coding: 010D00
   VCID: 0C17CE56AF8A7D22CC-8058
No fault code found.
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 BC    HW: 8K0 907 064 C
   Component: BCM2 1.1      H80 0249
   Revision: 00002001
   Coding: 030100
   VCID: 72EBB0AEAD6E0BD2A6-8026
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H37 0060
   Serial number: 0509000048933001
   Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Component: J764 ELV MLB  H37 0042
   Serial number: 0209000064844009
Address 08: Auto HVAC (J255)       Labels: Redir Fail!
   Part No SW: 8T1 820 043 AM    HW: 8T1 820 043 AM
   Component: KLIMA 1 ZONE  H08 0171
   Revision: A0000000    Serial number: 01090920090237
   Coding: 64000000
   VCID: 7CF79E96FF2A4DA2FC-8028
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 K    HW: 8K0 907 063 K
   Component: BCM1 1.0      H25 0380
   Revision: 06025001    Serial number: 00000000344186
   Coding: 690000B1013400010001000000005F5F001C020800000001000000
   Shop #: WSC 06325 123 12345
   VCID: 377D41BA868CAEFA51-8062
   Subsystem 1 - Part No SW: 8K1 955 119 A    HW: 8T1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 140909  H06 0070
   Serial number: SWF09090145683
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000809091653
Address 10: Park/Steer Assist
Cannot be reached
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EFD05HD93
   Coding: 30343435363030303030554A304C384B3053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003010
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 41892F62D048E04AEF-8014
   Crash sensor for side airbag: driver side:
   Serial number: 6334MSME4A12197EL
   Crash sensor for side airbag: front passenger side:
   Serial number: 6344MSME4B412C67L
   Crash sensor for side airbag: rear: driver side:
   Serial number: 6352QSME483A2714G
   Crash sensor for side airbag: rear: passenger side:
   Serial number: 6362QSME6C3A4012G
   Crash sensor for front airbag: driver side:
   Serial number: 63732SME54371F26%
   Crash sensor for front airbag: front passenger side:
   Serial number: 63832SME32382B36
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
   Part No SW: 8K0 953 568 D    HW: 8K0 953 568 D
   Component: Lenks.Modul   H16 0014
   Revision: --------    Serial number: 90319IHK00013
   Coding: 000002
   VCID: 3B755D8ABAA48A9AB5-806E
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 900 B    HW: 8K0 920 900 B
   Component: KOMBIINSTR.   H20 0255
   Revision: 00000000    Serial number: CIJ25T799
   Coding: 0F05080003000008010000
   VCID: 295997C24038080AD7-807C
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
   Part No SW: 8T0 907 468 S    HW: 8T0 907 468 J
   Component: GW-BEM 6CAN   H06 0105
   Revision: HB600050    Serial number: 5000H09B058044
   Coding: 00C300
   Shop #: WSC 06335 123 12345
   VCID: 51A91F22082810CA7F-8004
3 Faults Found:
03041 - Energy Management Active
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 121
                    Mileage: 192996 km
                    Time Indication: 0
                    Date: 2017.08.06
                    Time: 12:46:24
             Freeze Frame:
                    Bin. Bits:    10111
                    Voltage: 11.60 V
                    Count: 6
01771 - Control Module for Headlight Range (J431)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 161
                    Mileage: 192996 km
                    Time Indication: 0
                    Date: 2017.08.06
                    Time: 12:46:25
             Freeze Frame:
                    Bin. Bits:    10111
                    Voltage: 11.60 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
01327 - Control Module for Parking Aid (J446)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 121
                    Mileage: 192996 km
                    Time Indication: 0
                    Date: 2017.08.06
                    Time: 12:46:25
             Freeze Frame:
                    Bin. Bits:    10111
                    Voltage: 11.60 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 J    HW: 8K0 959 793 E
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000101863547
   Coding: 011002204000410001
   VCID: 479D317AF66CDE7A21-8012
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0117605705
   Coding: 011E0620003900400330010000000000
   Subsystem 1 - Part No: 8K0 951 177
   Component: DWA-Sensor  H02 0040
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
   Part No SW: 8K0 959 792 J    HW: 8K0 959 792 E
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000101857830
   Coding: 001002204C00410001
   VCID: 46833C7EF166C772DA-8012
1 Fault Found:
01042 - Control Module; Not Coded
            000 -  -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 20
                    Mileage: 191007 km
                    Time Indication: 0
                    Date: 2017.06.24
                    Time: 20:46:09
Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
   Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
   Component: EPB Audi B8   H09 0100
   Revision: 00000003    Serial number: 00000000445733
   Shop #: WSC 00000 000 00000
   VCID: 346776B697FA45E274-8060
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
   Component: Concert3      H05 0310
   Revision: 00000008    Serial number: AUZ5Z6I1308714
   Coding: 000204000101000D0179070003
   VCID: 44872676C75AF562C4-8010
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
1 Fault Found:
00463 - Control Module for Digital Sound Package (J525)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 121
                    Mileage: 192996 km
                    Time Indication: 0
                    Date: 2017.08.06
                    Time: 12:51:39
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000101835656
   Coding: 010002204000210001
   VCID: 428B206EDD4EFB52F6-8016
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000101834133
End-------------------------(Elapsed Time: 02:42)--------------------------
W LIŚCIE INSTALACYJNEJ TRZEBA WYKODOWAC
Czyli adres 55 xenon oraz 10 PDC
Dodatkowo masz słaby AKU
Ale gdzie mam znaleść listę instalacyjną?
w sterowniku gateway 19
