[B5 ANB] Proszę o analizę błędów
Witka
Przed chwilka zrobilem autoscana:
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 4B0 906 018 K
Component: 1.8L R4 5VT 0005
Coding: 05001
Shop #: WSC 00000
7 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit
P1118 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
17743 - Engine Torque Monitor 2: Control Limit Exceeded
P1335 - 35-10 - - - Intermittent
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-00 - -
Readiness: 0010 1001
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 B
Component: ABS/EDS 5.3 FRONT D10
Coding: 0273004283
Shop #: BB 24332
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 N
Component: A4 KLIMAAUTOMAT D54
Coding: 00040
Shop #: WSC 06325
Address 15 -------------------------------------------------------
Controller: 8D0 959 655 J
Component: Airbag Front+Seite 0001
Coding: 00106
Shop #: WSC 06325
Address 17 -------------------------------------------------------
Controller: 8D0 919 861 H
Component: B5-KOMBIINSTR. VDO D15
Coding: 01042
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0X1113428
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 B
Component: ZV-Pumpe, Funk D12
Coding: 12865
Shop #: WSC 06325
3 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 E
Component: Radio 0001
Coding: 00201
Shop #: WSC 00000
2 Faults Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
01044 - Control Module Incorrectly Coded
35-00 - -
End -------------------------------------------------------
po skasowaniu bledow:
Coding: 05001
Shop #: WSC 00000
Coding: 0273004283
Shop #: BB 24332
Coding: 00040
Shop #: WSC 06325
Coding: 01042
Shop #: WSC 00000
No Faults Found
Coding: 12865
Shop #: WSC 06325
3 Faults Found:
35-00 - -
00955 - Key 1
00956 - Key 2
Coding: 00201
Shop #: WSC 00000
2 Faults Found:
35-00 - -
Po skasowaniu auto ledwo odpalalo, musialem przycisnac sporo gazu
Efekt jest taki, ze autem szarpie powyzej 4 tys obr ale juz rzadko
Natomiast odczuwam sporego "mula"
Zniknal gdzies ten "kop", ktory byl nawet przed czipem
Wczoraj wymienilem przeplywke
Pierwsza sonda jest nowa, ma z 2 miesiace
hilfe...
Witam
Najprawdopodobniej Sonda za katalizatorem do wymiany. (17526,16524,17521,16518,17522)
17526
http://www.a4-klub.pl/smf/empty-t31576.0.html;highlight=17526
16518
http://www.a4-klub.pl/smf/empty-t14107.0.html;highlight=16518
16487
http://www.a4-klub.pl/smf/empty-t44609.0.html;highlight=16487
http://www.a4-klub.pl/smf/empty-t25583.0.html;highlight=00852
01367
http://www.a4-klub.pl/smf/empty-t49673.0.html;highlight=01367
:slina::szukaj:
Większość błedów które Ci sie pojawiły były już wyjaśnione na forum.
______________
Rafał
rav
sonda za katem jest napewno do wymiany, ale jej praca nie wplywa na szarpanie silnikiem
problemem jest prawdopodobnie pierwsza sonda (choc wczesniej nie mozna bylo wykasowac jej bledow a teraz tak)
stad moje watpliwosci
Witam
Po za bledami sondy lambdy są też inne błędy np: 16487 - Brak masy na przeplywomierzu, zwarcie do plusa, lub uszkodzony przepływomierz.
________________
Rafał
