[ALL TDI PD] Zmiana wartości zapełnienia DPF po wymianie.
Poczytaj tu: https://www.a6klub.pl/-a6-c6-wypalanie-dpf-vt33680,75.htm#793978 , może coś znajdziesz...
Ewentualnie:
Adaptation of Carbon Mass (after DPF Replacement)
Prerequisites:
  • Ignition ON
  • Engine OFF
[Security Access -16]
Enter the code shown in the VCDS pop-up balloon for "Adaptation Enabling"
[Do It!]
[Adaptation - 10]
From the pulldown menu, select the entry for "Carbon Mass (DPF Replacement)" or "Particle filter initialization".
Save a new value of 1 to reset the learned Carbon Mass. It's normal for that value to automatically change to 0 after it has been successfully saved. Check and clear fault codes to make sure none are present.
Edytowane przez kamil-vag
