Pablowsky Opublikowano 17 Września 2018 Opublikowano 17 Września 2018 Witam. Czy ktoś będzie w stanie mi pomóc i przeczytać mój VIN ? Chciałbym znać oznaczenie silnika i czy moje auto ma pasek czy łańcuch rozrządu czy jest dwumas itp. Nie wiem tylko czy w dobrym dziale to napisałem. Silnik to 2.0 fsi. Mój VIN WAUZZZ8EX4A125862 Dziękuję.
sitar Opublikowano 17 Września 2018 Opublikowano 17 Września 2018 Resztę zaraz podam Brand AUDI Model AUDI A4 AV. 2.0 VIN WAUZZZ8EX4A125862 Check digit Не используется (Not used) Sales id 8E50M4 Permanent link https://carinfo.kiev.ua/cars/vin/audi/vin_check?su=3bmzma2a80hd Production date 2003-10-21 Model year 2004 Engine code AWA (FSI) Engine volume, L 2.00 Number of cylinders 4 Power, KW 110 Power, PS 150 Colour of body P7 (MORO BLUE: moro blue pearl effect) Colour of roof P7 (MORO BLUE: moro blue pearl effect) Trim LA Gearbox code GFU (5S) Country of sale 000 () Custom options Parameter Value E0A Special editions: No special edition 1PA Lockable wheel bolts: Standard wheel bolts 0CS Vehicle class differentiation units/platform components: Vehicle class differentiation 8E0 0GG Emissions standard: Emission standard EU4 1D0 Trailer hitch: Without trailer hitch 4UE Airbag: Air bag for driver and front seat passenger 0W1 Label for central electric: Label for central electric German-speaking countries QE0 Storage compartment package: Without tray areas package/box 6XC Exterior mirror setting: Exterior mirrors: electrically adjustable 5SL Left exterior mirror: Left exterior mirror: aspherical 5RU Right exterior mirror: Right exterior mirror: convex (large viewing field) 1X0 Drive layout: Front wheel drive A8S Equipment levels: Standard equipment 1KD Brake type in rear: Disc brakes, rear J1L Batteries: Battery 280 A (60 Ah) 1LB Brake type, front: Disc brakes, front 6FB Components with special surface appearance: Body-colored exterior mirror housings B0A Component part sets with country-specific design requirements: Component parts set without country-specific design requirement 0VC Owner's manuals: Information kit in German 9T0 Heated washer nozzles: Without heated washer nozzles 7QB CD ROM/DVD/SD card: CD ROM (Germany) 7A0 CD changer/CD player: Without CD changer/CD player C09 General operating permit, alterations: Operating permit, alteration 1BA Shock absorption/suspension, chassis: Standard suspension/shock absorption 3S1 Roof rails/roof load rack: Bright roof rails 2T0 Double-size standard radio/dual-view display: Without double-sized standard (DIN) 3FA Roof insert/convertible top: Without roof insert (standard roof) 3X0 Ski bag: Without load-through provision 2G1 Insert for the filling up of unleaded fuel/fuel type: Insert for the filling up of unleaded fuel 7AA Theft protection system: Electronic vehicle immobilization device 5TD Inserts: Decorative aluminum inserts 7M0 Scuff plates: Plastic scuff plates in door apertures 7X1 Park distance control: Park distance control 0FA Manufacturing sequence differentiation: Standard manufacturing sequence 9NX Tachograph/logbook: Without electronic logbook 4R5 Window regulator: Power windows with comfort operation and circuit breaker, mechanical window regulators rear 5NF Hood and trunk stay: Interstop gas prop for tailgate 8K0 Headlight control: Without special headlight activation 2V1 Fresh air intake for passenger compartment (with particulate filter): Dust and pollen filter 1C1 Antifreeze: Antifreeze up to -25 degree celsius tolerance up to -30 degree C F0A Vehicle specifications: No special purpose vehicle, standard equipment 8GL Alternators: Alternator 120 A 0G1 Transmission types/gearshift mechanisms: Gearshift lever 1YA Transmission shafts, rear axle: Without transmission shafts f. rear axle 1WG Transmission shafts: Transmission shafts w/ 88 mm in diameter 0YL Weight category rear axle: Weight range 11 installation control only, no requirement forecast 0JG Weight category front axle: Weight category front axle weight range 7 T17 Base engine: 4-cylinder gasoline engine 2.0 L unit 06D.A (aluminum) 6M0 Tie down straps/net/pocket: Without tie down straps/net/pocket 8T0 Cruise control system: Without cruise control system (CCS) VC0 Garage door opener: W/o remote-controlled garage door opener G0C Transmission specifications: 5-speed manual transmission 6PC Hand brake lever handle: Leather hand brake lever handle 6V1 Rear trim panel: Rear trim panel (ECE) 5J0 Rear spoiler: Without rear spoiler 6NJ Molding roof liner: Standard molded headlining 3NZ Rear seats: Rear seat bench unsplit, backrest split folding 9AK Heating and air conditioning system: Climatronic with impact pressure control free of cfc 8ED Headlamps: Bi-functional headlight with gas discharge lamp, for driving on the right FC0 Customized installation: Without customized installation U2A Instrument clusters: Instrument insert with km/h speedometer, radio-controlled clock, tachometer and trip odometer 4N0 Dashboard: Standard dashboard 4L2 Breakaway interior rearview mirror: Dipping breakaway interior rear view mirror K8D Body style: Station Wagon Variant/Avant 6SS Luggage compartment floor covering: Luggage compartment floor covering 4W0 Cassette and CD storage unit: Without cassette and CD storage unit 1W0 Refrigerator: Without refrigerator/glove compartment cooling system 3Q6 Rear head restraints: Three rear headrests 1Z0 Fuel quantity for initial filling: Initial standard fuel filling 0F2 Fuel systems: Fuel system for carburetor gasoline engine 5C0 Body measures: Without special body measures 6W5 Front license plate carrier: Front license plate bracket 5K1 Paint preservative/transit coating: Paint preservative (wax) QQ0 Light package (lighting): Without add. lights (interior lighting) L0L Steering system arrangement: Left-hand drive vehicle 1N1 Steering: Power steering 7P0 Lumbar support: Without lumbar support in seat backrests 1MR Steering wheels: Leather steering wheel 9VD Speaker installation: Speaker (active) 8Q3 Headlight range control: Automatic headlight-range adjustment dynamic (self-adjusting while driving) 6E3 Center armrest: Front center armrest FM0 Versions: Basic equipment variant 9Q4 Multi-function display/trip computer: Multi-function display/on-board computer with check control 8Z5 Engine cooling system: Not hot country D2T Engine specifications: 4-cyl. gasoline engine 2.0 L/110 kW 16V fuel-stratified injection base engine is T58/T17 7Q9 Navigation device: Navigation system 8TC Rear fog lamp: Rear fog light for driving on the right 4P2 Platform module, luggage compartment floor: Rear floor panel module, type 3 FQ0 Quattro GmbH: Standard production wheels CB1 Wheels: LeichtmetallrГ¤der 7J x 16 Alu-4, ET 42 VR0 Impact protection measures: Without impact protection measures 8UD Radios: Radio "concert" 7K0 Direct tire pressure monitoring system: Without tire pressure warning light H6U Tires: Tires 205/55 R16 91W V0A Tire suppliers: Tires w/o specification of tire brand 1G3 Spare wheel/breakdown kit: Alloy spare wheel with original equipment tires P15 four-spoke leather-covered steering wheel PER spare wheel with full-size tyre, alloy, 15"/16" PNH navigation system (BNS 4.1) PSV seat heating for front seats PX4 xenon Plus 4X3 Side airbag: Side air bag front with curtain air bag 6Q2 Gearshift knob/handle: Leather gearshift knob/handle A00 Self-collection / special control: No self-collection 2KR Special labels/plates: Labels/plates in English and German 4E0 Lock operation for tailgate/trunk lid: Tailgate/trunk lid unlocking from outside VJ1 Bumper systems: Reinforced bumpers 9P0 Seat belt check: Without seat belt reminder 3C7 Center rear seat belts: 3-point seat belt for center rear seat 6R2 Gearshift boot/cover: Leather gearshift boot N3A Seat trim covers: Fabric seat covering 3L3 Seat adjustment: Manual height adjustment for front seats 4A3 Seat heater: Seat heater for front seats separately controlled 0LW Safety certificate: Special plates/stickers/ safety certificates for Germany QH0 Audio-response system/voice control: Without voice control 4KC Side and rear windows: Side and rear windows in heat-insulating glass 3Y0 Roll-up sun screen for rear and side windows: Without roll-up sun screen 7B2 Socket: 12-volt socket in luggage boot FA0 Handling production and pre-production: Control of standard production 8X1 Headlamp washer system: Headlight washer system 8N4 Windshield wiper intermittent control/ light/rain sensor: Windshield wiper intermittent control with potentiometer (four speeds) 4K4 Door and lid locking system: Radio remote controlled central locking B01 Type approval countries/countries with special requirements: Type approval Germany 5D1 Carrier frequency for radio remote control: Carrier frequency 433.92 MHz-434.42 Mhz NT0 Transit coating: Transit coating (type 1) QV0 TV reception/digital radio reception: W/o TV reception/digital radio reception 1VG Installation parts for engine (engine mount system): Installation parts for four-cylinder engine 1SA Front underbody guard: Without additional front underbody guard 1EX Identification plates: Spezielles Typschild fГјr EG 2Z0 Type sign: Deletion of model designation 1T3 First aid kit / warning triangle: First aid kit with warning triangle Q1A Front seats: Standard front seats 9W0 Telephone / telematics: W/o car phone preparation/installation 4GH Windshield glass type: Windshield in heat-insulating glass with sunshield 2WA Additional tires (snow tires): Without additional tires 0TC Floor mats: Front floor mats 4ZE Decorative trims: Black moldings 3B0 Additional child seat anchors: Without additional child seat anchor 9M0 Auxiliary heater: Without auxiliary/parking heater
luk330 Opublikowano 17 Września 2018 Opublikowano 17 Września 2018 (edytowane) rozrząd na pasku, koło oczywiście dwumasowe. Nr nadwozia WAUZZZ8EX4A125862 model Audi A4 Av. 2,0A4 Data produkcji 21.10.2003 Rok modelowy 2004 typ handlowy 8E50M4 Kod silnika AWA Kod przekładni GFU numer napedu osiowego 5S Wyposazenie LA kolor dachu P7 Kod koloru dywaników kolor zewnetrzny / numer koloru P7 / Z5J Wyposażenie: Wersja specjalna E0A bez wykonania na akcję Zamykane śruby mocujące koło 1PA standardowe śruby kół Rozróżnienie klasy samochodu agregaty / części platformy 0CS Rozróżnienie klas samochodu -8E0- Norma emisji spalin 0GG Norma emisji spalin, EU4 Zaczep do holowania 1D0 bez zaczepu do holowania przyczepy poduszka bezpieczeństwa (airbag) 4UE poduszka bezp.po str.kierowcy i p.pasażera Naklejka centralnego układu elektrycznego 0W1 Naklejka centralnego układu elektrycznego, niemieckojęzyczna Pakiet schowków QE0 Bez pakietu schowków / box Ustawianie lusterek zewnętrznych 6XC lusterka zewn. elektrycznie regulowane Lewe lusterko zewnętrzne 5SL Lewe lusterko zewnętrzne, asferyczne Prawe lusterko zewnętrzne 5RU prawe lusterko zewnętrzne, wypukłe (duże pole widzenia) Rodzaj napędu 1X0 naped przedni Opcje wyposażenia A8S wyposażenie standardowe Wersja tylnych hamulców 1KD Tylne hamulce tarczowe akumulatory J1L Akumulator 280 A (60 Ah) Wersja przednich hamulców 1LB Przednie hamulce tarczowe Podzespoły o szczególnej powierzchni 6FB obudowa lusterka zewn. w kolorze pojazdu Zestaw podzespołów zgodnie ze specyf. dla danego kraju przepisami budowlanymi B0A zest.elementów bez przepisów montaż.dot.danego kraju Instrukcje obsługi 0VC Książka samochodu w języku niemieckim Ogrzewane dysze układu mycia szyb 9T0 Bez podgrzewanych spryskiwaczy szyby CD-Rom/DVD/karta SD 7QB CD-Rom (Niemcy) Zmieniacz płyt CD / odtwarzacz płyt CD 7A0 bez odtwarzacza CD/instalacji do odtwarzacza płyt CD Uzupełnienia ABE C09 Dopuszczenie do ruchu, uzupełnienie Wytłumienie / amortyzatory, podwozie 1BA Sprężyny / amortyzatory standardowe Reling dachowy / wspornik obciążenia dachu 3S1 reling dachowy, srebrny 2-DIN / wyświetlacz Dual-View 2T0 Bez 2-DIN Zestaw dachu / dach składany 3FA pełny dach System transp.długich przedmiotów/pokrowiec na narty 3X0 bez wyposażenia do przewożenia dł.przedmiotów Wkład do tankowania benzyny bezołowiowej/ rodzaj paliwa 2G1 Wkład do tankowania benzyny bezołowiowej Zabezpieczenie przed kradzieżą 7AA immobilizer elektroniczny Wkładki 5TD Aplikacje dekoracyjne, aluminium Listwy progowe 7M0 wewn.listwy progowe z tworzywa sztucznego czujniki parkowania 7X1 czujniki parkowania Rozróżnienie przebiegu produkcji 0FA Standardowy przebieg produkcji Tachograf / dziennik podróży 9NX Bez elektronicznego dziennika podróży podnosnik szyby 4R5 podnośnik przedniej szyby z przełączaniem w systemie Komfort, elektryczny, z tyłu mechaniczny Blokada wentylacyjna pokrywy przedniej / tylnej 5NF sprężyna gazowa pokrywy tylnej Włączanie świateł mijania 8K0 bez autom. kontroli świateł drogowych Układ zasysania świeżego powietrza wewnątrz (z filtrem cząstek stałych) 2V1 filtr pylkow i kurzu Zabezpieczenie przed zamarzaniem 1C1 Odporność na zamarzanie do -25 stopni Celsjusza tolerancja do -30 stopni Celsjusza Specyfikacje samochodu F0A Nie samochód specjalny, wersja standardowa Alternatory 8GL Alternator 120 A Rodzaje skrzyń biegów / mechanizmów przełączania 0G1 Dźwignia zmiany biegów Wałki kołnierzowe skrzyni biegów, tylna oś 1YA Bez wałków kołnierzowych skrzyni biegów tylnej osi Wałki kołnierzowe skrzyni biegów 1WG Wałki konierzowe skrzyni biegów o średnicy 88 mm Klasa wagowa tylnej osi 0YL Kategoria wagowa 11 tylko sterowanie montażem, brak prognozy zapotrzebowania Klasa wagowa przedniej osi 0JG Klasa wagowa przedniej osi Kategoria wagowa 7 Silnik podstawowy T17 4-cyl. silnik benzynowy 2,0 l 06D.A (ALU) Gumy mocujące bagaż / siatki / kieszenie 6M0 bez gum mocujących bagaż / siatki / kieszeni układ utrzymywania prędkości 8T0 bez układu utrzymywania prędkości pilot do otw. garażu VC0 bez pilota bramy garażu Specyfikacja skrzyni biegów G0C ręczna skrzynia 5-biegowa uchwyt dzwigni hamulca recz. 6PC UCHWYT DZWIGni hamulca recznego (skora) Tylna osłona 6V1 Tylna osłona (ECE) spojler tylny 5J0 Bez tylnego spoilera Wyściółka podsufitki 6NJ Podsufitka standardowa Tylne siedzenia 3NZ Tylna kanapa niedzielona, oparcie dzielone składane Ogrzewanie-układ klimatyzacji 9AK Climatronic z kontrolą recyrkulacji sterowaną czujnikiem jakości powietrza" Nie zawiera freonu. Reflektor główny 8ED Dwufunkcyjny reflektor główny z lampą wyładowczą, ruch prawostronny Montaż indywidualny FC0 Bez montażu indywidualnego Zestawy wskaźników U2A Zest.wskaź.ze wskaz.w KM/H, zeg.ster.falami rad. obrotomierzem i licznikiem przebiegu okresowego Tablica przyrządów 4N0 Tablica przyrządów standardowa Bezpieczne lusterko wewnętrzne 4L2 lusterko wewnętrzne ściemniane Kształty nadwozia K8D Variant/Avant Wykładzina podłogowa 6SS Wykładzina podłogowa Schowek na kasety / płyty CD 4W0 bez wnęki na kasety/CD lodówka 1W0 Bez chłodziarki/chłodzenia podręcznego schowka ZAGLOWKI na TYLNYCH siedzeniach 3Q6 Zagłówki tył (3 szt.) Ilość napełnienia zbiornika paliwa 1Z0 Pierwsze seryjne napełnienie paliwem Układy paliwowe 0F2 układ paliwowy silnika benzynowego Czynności dotyczące nadwozia 5C0 Bez szczególnych czynności dotyczących nadwozia wspornik tablicy rej.z przodu 6W5 wspornik tablicy rej.z przodu Powłoka konserwacyjna lakieru / zaczep transportowy 5K1 lakier konserwowany woskiem Pakiet oświetlenia QQ0 Bez dodatkowego oświetlenia (oświetlenie wewnątrz) Przyporządkowanie układu kierowniczego L0L wersja z kierownicą z lewej strony Układ kierowniczy 1N1 Układ wspomagania kierowania Podparcie odcinka lędźwiowego w oparciach 7P0 bez regulacji odcinka lędźwiowego w oparciu kierownice 1MR kierownica (skora) Montaż głośników 9VD głośnik aktywny Regulacja zasięgu reflektorów 8Q3 automatyczna regulacja świateł Środkowy podłokietnik 6E3 Środkowy podłokietnik przód Wersje FM0 Wersja wyposażenia podstawowego Wyświetlacz wielofunkcyjny / komputer samochodowy 9Q4 wyświetlacz wielofunkcyjny/komputer pokładowy z Check Control Chłodzenie silnika 8Z5 Nie kraj o gorącym klimacie Specyfikacja silnika D2T 4-cylindrowy silnik benzynowy 2,0 l/110 KW (16V) FSI, warstwowa Silnik podstawowy: T58/T17 System nawigacji 7Q9 system nawigacji tylne swiatło przeciwmgłowe 8TC tylne światło przeciwmgielne. Moduł platformowy, podłoga z tyłu 4P2 Tylny moduł podłogi, wersja 3 Audi Sport/ Quattro GmbH FQ0 Koła serii Koła CB1 Obręcze ze stopów lekkich 7J x 16 Alu-4, ET 42 Osłona przeciwuderzeniowa VR0 Bez osłony przeciwuderzeniowej Radioodbiorniki 8UD Radio "Concert" kontrola ciśnienia w ogumieniu 7K0 Bez układu kontroli ciśnienia w oponach opony H6U Opony 205/55 R16 91W Dostawcy opon V0A Opony bez określonej marki Koło zapasowe / zestaw do naprawy opon 1G3 Pełnowymiarowe koło zapasowe, stop metali lekkich P15 leather-covered steering wheel, 4-spoke PER spare wheel with full-size tyre, alloy, 15"/16" PNH navigation system (BNS 4.1) PSV seat heating for front seats PX4 xenon plus Boczna poduszka bezpieczeństwa 4X3 boczna pod.bezp. z przodu i pod.bezp.głowy Gałka dźwigni zmiany biegów / uchwyt 6Q2 gałka zmiany biegów - skóra Odbiór osobisty / sterowanie specjalne A00 Nie odbiór osobisty Specjalne naklejki / tabliczki 2KR Naklejki/tabliczki, angielsko-niemieckie Mechanizm zamykania pokrywy tylnej/ pokrywy z tyłu 4E0 odblokowanie tylnej pokrywy z zewnątrz Zderzaki VJ1 zderzak wzmocniony Układ kontroli pasów bezpieczeństwa 9P0 bez zamka przyciskowego ze stykiem ostrzegawczym Pasy bezpieczeństwa, tył, środek 3C7 Autom.3-punkt.pas bezp.na środkowe tylne siedzenie Mankiet / osłona dźwigni zmiany biegów 6R2 mieszek dźwigni biegów skórzany tapicerka siedzisk N3A Obicia siedzeń z materiału Ustawienie siedzenia 3L3 ręczna regulacja wysokości przedniego fotela ogrzewanie siedzeń 4A3 ogrzewanie przednich siedzeń regulowane oddzielnie Certyfikaty bezpieczeństwa 0LW Ze specjalnymi tabliczkami/naklejkami certyfikaty bezpieczeństwa dla Niemiec System obsługi głosowej/sterowanie głosem QH0 bez sterowania głosowego Szyby bok i tył 4KC szyby boczne i tylna ze szkla z ochroną termiczną Roleta przeciwsłoneczna na tylną/boczną szybę 3Y0 bez rolety przesiwsłonecznej wtyczka 7B2 12 Volt-gniazdo wtykowe w bagażniku Rozwój, produkcja seryjna/przedseryjna FA0 Rozwój - produkcja seryjna układ mycia reflektorów 8X1 układ mycia reflektorów Włączanie pracy okresowej wycieraczek/ czujnik deszczu i światła 8N4 przełącznik wycieraczek z 4 stopniową reg. Blokowanie drzwi i pokryw 4K4 centralny zamek sterowany pilotem Kraj kontroli typu/kraje ze specjalnymi wymaganiami B01 Kraj kontroli typu Niemcy Częstotliwość zdalnego sterowania radiowego 5D1 Częstotliwość nośna 433,92 do 434,42 Mhz Zabezpieczenie transportowe NT0 Zabezpieczenie transportowe (wersja 1) Odbiór TV / cyfrowy odbiór radia QV0 bez odbioru TV/cyfrowy odbiór radiowy Części wbudowane silnika (napęd) 1VG Części wbudowane dla 4-cyl.silnika Zabezpieczenie zespołu napędowego 1SA bez dodatkowej dolnej osłony podwozia Tabliczka typu 1EX Specjalna tabliczka typu dla WE Symbol typu 2Z0 Oznaczenie modelu, brak Apteczka/trójkąt ostrzegawczy 1T3 Apteczka z trójkątem ostrzegawczym Przednie siedzenia Q1A Przednie siedzenia standardowe Telefon / Telematik 9W0 bez instalacji do telefonu samochodowego szyba czołowa 4GH szyba czołowa termicznie izolowana z ciemnym pasem Dodatkowe opony (zimowe) 2WA Bez dodatkowych opon dywaniki podłogowe 0TC Dywaniki z przodu listwy ozdobne 4ZE listwy ozdobne czarne Dodatkowe mocowanie fotelika dla dziecka 3B0 Bez dodatkowego mocowania fotelika dla dziecka ogrzewanie dodatkowe 9M0 bez ogrzewania postojowego. Edytowane 17 Września 2018 przez luk330
