Szpunar200 Opublikowano 15 Kwietnia 2019 Opublikowano 15 Kwietnia 2019 (edytowane) Witam Zeskanowalem auto programem bluetooth i wyskoczylo mi coś takiego. Pogrubilem to co mnie ciekawi. Mode $06 report generated by Torque for Android================================================VIN samochodu:WAUZZZ8K9CA078862Producent:AudiID kalibracji pojazdu:8K2907115AF 0002Test report:------------------MID:$01 TID:$83- O2 Bank 1 Sensor 1Max: 1,99882 Min: 0,3499Test result value: 1,13094PASS----MID:$01 TID:$84- O2 Bank 1 Sensor 1Max: 0,06997 Min: -0,06997Test result value: 0,00061PASS----MID:$02 TID:$81- O2 Bank 1 Sensor 2Max: 0,6549V Min: 0VTest result value: 0,64514VPASS----MID:$02 TID:$82- O2 Bank 1 Sensor 2Max: 1,26002V Min: 0,6549VTest result value: 0,66466VPASS----MID:$02 TID:$83- O2 Bank 1 Sensor 2Max: 0,25352V Min: 0VTest result value: 0VPASS----MID:$21 TID:$84- Catalyst Monitor Bank 1Max: 1,99882 Min: 0,20304Test result value: 0,49971PASS----MID:$35 TID:$80- Max: -7,62° Min: -23,62°Test result value: -15,16°PASS----MID:$35 TID:$81- Max: -7,62° Min: -23,62°Test result value: -15,16°PASS----MID:$3d TID:$80- EVAP Monitor (0.020")Test incomplete or dependant test failed--MID:$3d TID:$88- EVAP Monitor (0.020")Max: 65 535 Min: 3Test result value: 5PASS----MID:$41 TID:$85- O2 Heater Monitor Bank 1 - Sensor 1Max: 1 239,90002°C Min: 754,90002°CTest result value: 819,40002°CPASS----MID:$42 TID:$81- O2 Heater Monitor Bank 1 - Sensor 2Max: 1 638Ohm Min: 0OhmTest result value: 138OhmPASS----MID:$a2 TID:$0bEWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 DataMax: 65 535Count Min: 0CountTest result value: 2CountPASS----MID:$a2 TID:$0cMisfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 DataMax: 65 535Count Min: 0CountTest result value: 0CountPASS----MID:$a3 TID:$0bEWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 DataMax: 65 535Count Min: 0CountTest result value: 3CountPASS----MID:$a3 TID:$0cMisfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 DataMax: 65 535Count Min: 0CountTest result value: 0CountPASS----MID:$a4 TID:$0bEWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 DataMax: 65 535Count Min: 0CountTest result value: 1CountPASS----MID:$a4 TID:$0cMisfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 DataMax: 65 535Count Min: 0CountTest result value: 0CountPASS----MID:$a5 TID:$0bEWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 DataMax: 65 535Count Min: 0CountTest result value: 4CountPASS----MID:$a5 TID:$0cMisfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 DataMax: 65 535Count Min: 0CountTest result value: 0CountPASS---- Edytowane 15 Kwietnia 2019 przez Szpunar200
MarcinOslo Opublikowano 15 Kwietnia 2019 Opublikowano 15 Kwietnia 2019 Z tego czegos nie da sie nic wywnioskowac ..
kixi4 Opublikowano 15 Kwietnia 2019 Opublikowano 15 Kwietnia 2019 Dokladnie, te chinskie obd2 to tragedia, niby odczytuje, ale zmienia niekiedy nr bledow.. a tlumaczenie bledow nijak ma sie do faktycznego kodu bledu sterownika..
