A4 B8 avant '09 3,0 TDI Capa manual Sline by stefano
Witam. Na wstępie chciałem się przywitać :D
To moje A4.
audI A4 B8 3,0 TDI 2009 capa MANUAL
kod    opis
E4J    S line
7D3    CD changer
4UF    Driver's and front passenger air bag with front passenger air bag deactivation
6XE    Exterior mirrors: electrically foldable and electrically adjustable/heated
5SL    Left exterior mirror: aspherical
6TS    Right exterior mirror: aspherical, large viewing field
1KW    Disc brakes, rear
J0Z    Battery 520 A (110 Ah)
1LA    Disc brakes, front
1AT    Electronic stabilization program (ESP)
1BE    Sports suspension/shock absorption
3FU    Big roof system
5TG    Decorative aluminum inserts, dulling
7X4    Park distance control, front and rear
F0A    No special purpose vehicle, standard equipment
8GU    Alternator 140 A
0G1    Gearshift lever
0YK    Weight range 10 installation control only, no requirement forecast
0JH    Weight category front axle weight range 8
T41    6-cylinder diesel engine 3.0 L unit 059.D
3NZ    Rear seat bench unsplit, backrest split folding
8BP    Bi-functional headlight with gas discharge lamp
U2A    Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
X0A    National sales program Germany
1N7    Dynamic steering
2PU    Leather trimmed multi-function sports steering wheel
8Q3    Automatic headlight-range adjustment dynamic (self-adjusting while driving)
9Q4    Multi-function display/on-board computerwith check control
8Z5    Not hot country
D50    6-cyl. turbo dies. eng. 3.0 l/176 kW 24VV6 TDI, common rail Base engine is T41/TE1/TF1/TH1
7Q2    Navigation system with color screen
C8S    Alloy wheels 8J x 18
7K6    Flat tire indicator
4X3    Side air bag front with curtain air bag
2K7    Reinforced bumpers
3L3    Manual height adjustment for front seats
4KC    Side and rear windows in heat-insulatingglass
3Y4    Roll-up sun screen for rear side windows
4K4    Radio remote controlled central locking
5D7    Carrier frequency 868 MHz without panic button
1SA    Without additional front underbody guard
7MB    Emission standard EU 4 plus - już nie DPF OUT :D :D
Q1D    Sports front seats
4GF    Windshield in heat-insulating glass
W marcu wleciał wydeszek i nowe hamulce z tyłu ?
Do tego Sotf 99 i ozonowanie wnętrza ?
Niezły egzemplarz. Plus za 3.0tdi w manuału.
Pokaż zdjęcia środka i opisz  jakie plany.
cykne fotki jak poodkurzam.
Plany na 2020 :
- heble tył 356 mm z a8 d4 ( z przodu już jest 385 mm )
- fmic 600x300x76
- zawór listwy na 2000 bar.
Do tego korekta softu. Wtedy się zobaczy co dalej :D
Można by się pokusić o większe końcówki wydechu...bo te wyglądają słabo.. trochę za małe ;)
zostawiłem seryjne, tylko je prze polerowałem. Nie chciałem się afiszować z tym wydechem :grin:
Może w przyszłości wstawię jakieś większe.
Dzisiaj wyciągnąłem kolumnę.
3 tulejki w wahaczach do wymiany i jeden cały wahacz, bo ma wywalony sworzeń. Aż dziw bierze, że po 270000 km, 3 sworznie są w stanie bardzo dobrym ??
Wpada na pokład Eibach Prokit - 30, nowe osłony, odboje i amorki Sachsa. Wszystko pod zawieszenie 1BE.
Obyło się bez wymiany zwrotnic ???
Jutro wyciągam tył.
Edytowane przez stefano189
Ciekawe ile faktycznie niżej będzie na tym eibachu względem 1be.. teoretycznie  10 mm  roznicy? Bo 1be to już -20mm  czy się mylę...?
Tak, chyba masz rację.
1be to - 20 mm
Prokit to - 30 względem serii( czyli 1ba), więc powinno być 10mm niżej niż był dotychczas
1be to - 20 mm
Czekam na to jak wrzucisz bo szukam springów i wydaje mi się że to  zbyt mało siądzie jak dla mnie przy 1be .
Tył był 676mm wysokości, przód 680mm. Zobaczymy jak wyjdzie ?
Widzę mody pierwsza klasa życzę powodzenia:-) po sprężyny nie byłeś czasem w Knurowie wczoraj?
Tak. Takie ładne b8 miałeś, i sprzedałeś... Szkoda go ?
Czyli dobre przeczucie miałem:-)
Nie myślałem o sprzedaży ale się trafił godny następca B8 oczywiście też audi jak będzie lepsze sytuacja w Polsce zapraszam na spoty w Gliwicach
Graty doszły, można składać ?
Przy okazji mała przesyłka z bestseller ?
Auto po geometrii w DMCustoms
Siedzi jak złoto ?
660 mm z przodu
665 mm z tyłu
Dobrze siadlo
Zrobiłeś już ten tył 356mm? Robisz adapter pod jarzmo 330mm?
W sobotę bd mieć części ?
Ładnie siedzi na tym aibachu, tylko szkoda przedniego zderzaka. Na typowych parkingach zderzak raczej nie wejdzie nad kraweżnik :D
