stefano189 Opublikowano 13 Kwietnia 2020 Opublikowano 13 Kwietnia 2020 Witam. Na wstępie chciałem się przywitać To moje A4. audI A4 B8 3,0 TDI 2009 capa MANUAL kod opis E4J S line 7D3 CD changer 4UF Driver's and front passenger air bag with front passenger air bag deactivation 6XE Exterior mirrors: electrically foldable and electrically adjustable/heated 5SL Left exterior mirror: aspherical 6TS Right exterior mirror: aspherical, large viewing field 1KW Disc brakes, rear J0Z Battery 520 A (110 Ah) 1LA Disc brakes, front 1AT Electronic stabilization program (ESP) 1BE Sports suspension/shock absorption 3FU Big roof system 5TG Decorative aluminum inserts, dulling 7X4 Park distance control, front and rear F0A No special purpose vehicle, standard equipment 8GU Alternator 140 A 0G1 Gearshift lever 0YK Weight range 10 installation control only, no requirement forecast 0JH Weight category front axle weight range 8 T41 6-cylinder diesel engine 3.0 L unit 059.D 3NZ Rear seat bench unsplit, backrest split folding 8BP Bi-functional headlight with gas discharge lamp U2A Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer X0A National sales program Germany 1N7 Dynamic steering 2PU Leather trimmed multi-function sports steering wheel 8Q3 Automatic headlight-range adjustment dynamic (self-adjusting while driving) 9Q4 Multi-function display/on-board computerwith check control 8Z5 Not hot country D50 6-cyl. turbo dies. eng. 3.0 l/176 kW 24VV6 TDI, common rail Base engine is T41/TE1/TF1/TH1 7Q2 Navigation system with color screen C8S Alloy wheels 8J x 18 7K6 Flat tire indicator 4X3 Side air bag front with curtain air bag 2K7 Reinforced bumpers 3L3 Manual height adjustment for front seats 4KC Side and rear windows in heat-insulatingglass 3Y4 Roll-up sun screen for rear side windows 4K4 Radio remote controlled central locking 5D7 Carrier frequency 868 MHz without panic button 1SA Without additional front underbody guard 7MB Emission standard EU 4 plus - już nie DPF OUT Q1D Sports front seats 4GF Windshield in heat-insulating glass
stefano189 Opublikowano 13 Kwietnia 2020 Autor Opublikowano 13 Kwietnia 2020 W marcu wleciał wydeszek i nowe hamulce z tyłu ? Do tego Sotf 99 i ozonowanie wnętrza ? 1
wielik Opublikowano 13 Kwietnia 2020 Opublikowano 13 Kwietnia 2020 Niezły egzemplarz. Plus za 3.0tdi w manuału. Pokaż zdjęcia środka i opisz jakie plany. Pozdrawiam
stefano189 Opublikowano 13 Kwietnia 2020 Autor Opublikowano 13 Kwietnia 2020 cykne fotki jak poodkurzam. Plany na 2020 : - heble tył 356 mm z a8 d4 ( z przodu już jest 385 mm ) - fmic 600x300x76 - zawór listwy na 2000 bar. Do tego korekta softu. Wtedy się zobaczy co dalej
Pablo_89 Opublikowano 14 Kwietnia 2020 Opublikowano 14 Kwietnia 2020 Można by się pokusić o większe końcówki wydechu...bo te wyglądają słabo.. trochę za małe
stefano189 Opublikowano 14 Kwietnia 2020 Autor Opublikowano 14 Kwietnia 2020 1 godzinę temu, Pablo_89 napisał: Można by się pokusić o większe końcówki wydechu...bo te wyglądają słabo.. trochę za małe zostawiłem seryjne, tylko je prze polerowałem. Nie chciałem się afiszować z tym wydechem Może w przyszłości wstawię jakieś większe.
stefano189 Opublikowano 14 Kwietnia 2020 Autor Opublikowano 14 Kwietnia 2020 (edytowane) Dzisiaj wyciągnąłem kolumnę. 3 tulejki w wahaczach do wymiany i jeden cały wahacz, bo ma wywalony sworzeń. Aż dziw bierze, że po 270000 km, 3 sworznie są w stanie bardzo dobrym ?? Wpada na pokład Eibach Prokit - 30, nowe osłony, odboje i amorki Sachsa. Wszystko pod zawieszenie 1BE. Obyło się bez wymiany zwrotnic ??? Jutro wyciągam tył. Edytowane 14 Kwietnia 2020 przez stefano189
wielik Opublikowano 14 Kwietnia 2020 Opublikowano 14 Kwietnia 2020 Ciekawe ile faktycznie niżej będzie na tym eibachu względem 1be.. teoretycznie 10 mm roznicy? Bo 1be to już -20mm czy się mylę...?
stefano189 Opublikowano 14 Kwietnia 2020 Autor Opublikowano 14 Kwietnia 2020 Tak, chyba masz rację. 1be to - 20 mm Prokit to - 30 względem serii( czyli 1ba), więc powinno być 10mm niżej niż był dotychczas
wielik Opublikowano 14 Kwietnia 2020 Opublikowano 14 Kwietnia 2020 2 minuty temu, stefano189 napisał: Tak, chyba masz rację. 1be to - 20 mm Prokit to - 30 względem serii( czyli 1ba), więc powinno być 10mm niżej niż był dotychczas Czekam na to jak wrzucisz bo szukam springów i wydaje mi się że to zbyt mało siądzie jak dla mnie przy 1be .
stefano189 Opublikowano 14 Kwietnia 2020 Autor Opublikowano 14 Kwietnia 2020 32 minuty temu, wielik napisał: Czekam na to jak wrzucisz bo szukam springów i wydaje mi się że to zbyt mało siądzie jak dla mnie przy 1be . Tył był 676mm wysokości, przód 680mm. Zobaczymy jak wyjdzie ?
egon47 Opublikowano 15 Kwietnia 2020 Opublikowano 15 Kwietnia 2020 Widzę mody pierwsza klasa życzę powodzenia:-) po sprężyny nie byłeś czasem w Knurowie wczoraj?
stefano189 Opublikowano 15 Kwietnia 2020 Autor Opublikowano 15 Kwietnia 2020 35 minut temu, egon47 napisał: Widzę mody pierwsza klasa życzę powodzenia:-) po sprężyny nie byłeś czasem w Knurowie wczoraj? Tak. Takie ładne b8 miałeś, i sprzedałeś... Szkoda go ?
egon47 Opublikowano 15 Kwietnia 2020 Opublikowano 15 Kwietnia 2020 Czyli dobre przeczucie miałem:-) Nie myślałem o sprzedaży ale się trafił godny następca B8 oczywiście też audi jak będzie lepsze sytuacja w Polsce zapraszam na spoty w Gliwicach
stefano189 Opublikowano 15 Kwietnia 2020 Autor Opublikowano 15 Kwietnia 2020 Graty doszły, można składać ? Przy okazji mała przesyłka z bestseller ? 1
stefano189 Opublikowano 5 Maja 2020 Autor Opublikowano 5 Maja 2020 Auto po geometrii w DMCustoms Siedzi jak złoto ? 660 mm z przodu 665 mm z tyłu 2
Wandej Opublikowano 6 Maja 2020 Opublikowano 6 Maja 2020 Zrobiłeś już ten tył 356mm? Robisz adapter pod jarzmo 330mm?
stefano189 Opublikowano 6 Maja 2020 Autor Opublikowano 6 Maja 2020 30 minut temu, Wandej napisał: Zrobiłeś już ten tył 356mm? Robisz adapter pod jarzmo 330mm? W sobotę bd mieć części ?
Kristofpro Opublikowano 7 Maja 2020 Opublikowano 7 Maja 2020 Ładnie siedzi na tym aibachu, tylko szkoda przedniego zderzaka. Na typowych parkingach zderzak raczej nie wejdzie nad kraweżnik
