wenc0ne Opublikowano 8 Lutego 2023 Opublikowano 8 Lutego 2023 Witam. Posiadam a4 b8 2009r 2.0 tfsi quattro. Prześwietliłem auto przez vcds i wyskoczyło mi kilka błędów. Najbardziej martwią mnie te odnośnie ABS. Mógłby ktoś tutaj z grona fachowców pokierować co i jak? Wytłumaczyć co musze wymienić, co naprawić aby usunąć wszystkie niżej wymienione błędy? Address 01: Engine (MA---CAEB) Labels:| 06H-907-115-CAB.clb Part No SW: 8K2 907 115 N HW: 8K2 907 115 D Component: 2.0l R4/4V TF H14 0001 Revision: E1H14--- CVN: D1730ACD Coding: 0104010A180F0160 Shop #: WSC 02145 785 00200 ASAM Dataset: EV_ECM20TFS8K2907115N A01003 ROD: EV_ECM20TFS8K2907115M.rod VCID: 3A7B87EFBD5F905D4D-806E VINID: 9D196358721B1097801430C1203D0E27D2 4 Faults Found: 4815 - Please Check Fault Codes in Control Module for ABS Brakes U1017 00 [175] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 254865 km Date: 2023.02.08 Time: 11:58:07 Engine RPM: 1467.50 /min Normed load value: 10.2 % Vehicle speed: 58 km/h Coolant temperature: 79 °C Intake air temperature: 23 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 14.088 V Unlearning counter according OBD: 40 4698 - Function Restriction due to Faults in Other Modules U1113 00 [047] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Mileage: 254865 km Date: 2023.02.08 Time: 11:58:02 Engine RPM: 1594.50 /min Normed load value: 29.4 % Vehicle speed: 64 km/h Coolant temperature: 78 °C Intake air temperature: 18 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 13.994 V Unlearning counter according OBD: 40 4699 - Function Restriction due to Faults in Other Modules U1113 00 [047] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 Mileage: 254865 km Date: 2023.02.08 Time: 11:58:02 Engine RPM: 1597.00 /min Normed load value: 29.4 % Vehicle speed: 64 km/h Coolant temperature: 78 °C Intake air temperature: 18 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 13.994 V Unlearning counter according OBD: 40 2644 - Brake Switch (F) P0571 00 [175] - Implausible Signal MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 254864 km Date: 2023.02.08 Time: 11:17:55 Engine RPM: 794.50 /min Normed load value: 10.6 % Vehicle speed: 0 km/h Coolant temperature: 84 °C Intake air temperature: 42 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 13.381 V Unlearning counter according OBD: 40 Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 AF HW: 8K0 907 379 AF Component: ESP8 quattro H04 0210 Revision: -------- Serial number: -------------- Coding: 070500 Shop #: WSC 02391 823 56573 VCID: 7DF14CF3E4F1676528-8028 2 Faults Found: 01435 - Brake Pressure Sensor 1 (G201) 008 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 11101000 Fault Priority: 2 Fault Frequency: 2 Reset counter: 87 Mileage: 254865 km Time Indication: 0 Date: 2023.02.08 Time: 11:58:03 Freeze Frame: Hex Value: 0x4000 Hex Value: 0x4006 Hex Value: 0x1235 Hex Value: 0x31AD Hex Value: 0x00FF 00473 - Control Module for Elect. Park/Hand Brake (J540) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 87 Mileage: 254865 km Time Indication: 0 Date: 2023.02.08 Time: 11:58:03 Freeze Frame: Hex Value: 0x4000 Hex Value: 0x4306 Hex Value: 0x122E Hex Value: 0x02AD Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 F HW: 8K0 907 064 F Component: BCM2 1.1 H80 0145 Revision: 00002001 Coding: 0B0100 Shop #: WSC 02399 823 56573 VCID: 3365AACB923561158E-8066 Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A Component: FBSAUDIB8 IDG H37 0060 Serial number: 0508000083594002 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H36 0041 Serial number: 0208000104050001 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb Part No SW: 8T0 035 729 P HW: 4E0 035 729 A Component: Interfacebox H43 5150 Revision: 00000000 Serial number: 340LT087517640 Coding: 0000012 Shop #: WSC 00012 123 00123 VCID: 4683E31F31A7E4BD39-8012 Subsystem 1 - Part No: 8T0 919 609 A Component: E0380 BedienteilH08 0100 Subsystem 2 - Serial number: 00000000206750 Subsystem 3 - Serial number: 0102.12.080000000100010363˙ Subsystem 4 - Serial number: 010363˙ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC Component: KLIMA 3 ZONEN H06 0150 Revision: C1000000 Serial number: 01041220080677 Coding: 64002000 Shop #: WSC 02391 823 56573 VCID: 72EB6FCFADAF281D45-8026 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 D HW: 8K0 907 063 D Component: BCM1 1.0 H22 0253 Revision: 05022001 Serial number: 00000000287193 Coding: 26001011013CAF010000000300003D0D0F1C120800010161000000 Shop #: WSC 02391 823 56573 VCID: 306FA5C763235A0DF3-8064 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 090109 H06 0070 Serial number: SWF09010095700 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 10348000 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA Component: E1 - LDS H07 0080 Serial number: 00000000000112080877 Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B Component: HOMELINK H01 0010 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 8T1 035 110 C HW: 8T1 035 110 C Component: MP3-Changer H43 0390 Revision: 00043003 Serial number: AUZ5ZBH8696090 Shop #: WSC 00000 000 00000 VCID: 2A5BB7AF85FF20DD3D-807E No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl Part No SW: 4E0 910 593 M HW: 4E0 035 593 F Component: SDAR SIRIUS H07 0160 Serial number: AUZ4Z7H0482283 Coding: 0000100 Shop #: WSC 02145 785 00200 VCID: 3169A0C3A8295305FC-8064 1 Fault Found: 02635 - Tuner Not Enabled/Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 87 Mileage: 254864 km Time Indication: 0 Date: 2023.02.08 Time: 11:31:53 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb Part No SW: 8K0 919 475 F HW: 8K0 919 475 Component: PARKHILFE 4K H06 0040 Revision: 11001001 Serial number: 40140900806107 Coding: 200003 Shop #: WSC 02391 823 56573 VCID: 3C7781F7BF6BAE6D5F-8068 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8K0-959-655.clb Part No SW: 8K0 959 655 F HW: 8K0 959 655 F Component: AirbagVW-AU10 H27 0410 Serial number: 0039KD14P1MC Coding: 303836354230303030304A55304C384B3053 Shop #: WSC 02135 785 00200 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_A02.rod VCID: 408FF507DB83CA8D03-8014 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B Component: BF-Gewichtss. H01 0030 Serial number: 5810000R08000039WZ Crash sensor for side airbag: driver side: Serial number: 6334MSME43242B649 Front Passenger's Side Airbag Crash Sensor: Serial number: 6344MSME4842093BF Rear Side Airbag Crash Sensor (on driver's side): Serial number: 6352QSME6F16150CN Passenger side rear thorax airbag crash sensor: Serial number: 6362QSME3C17443EQ Crash sensor for front airbag: driver side: Serial number: 63732SME59193018Z Crash sensor for front airbag: front passenger side: Serial number: 63832SME4B150636- No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H13 0013 Revision: -------- Serial number: 90304HJD0002S Coding: 000036 Shop #: WSC 02391 823 56573 VCID: 3D718CF3A471A76568-8068 Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 980 A HW: 8K0 920 980 A Component: KOMBIINSTR. H18 0224 Revision: 00000000 Serial number: 9E13461D8 Coding: 0F1D090002000008010100 Shop #: WSC 02391 823 56573 VCID: 306FA5C763235A0DF3-8064 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 P HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0095 Revision: EB500046 Serial number: 4600E08C108169 Coding: 000303 Shop #: WSC 02391 823 56573 VCID: 4E93DB3F19D72CFD81-801A Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H04 0150 Serial number: 18059859261108 1 Fault Found: 03041 - Energy Management Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 6 Reset counter: 120 Mileage: 254636 km Time Indication: 0 Date: 2008.05.27 Time: 00:29:00 ------------------------------------------------------------------------------- Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H15 0850 Revision: 00000000 Coding: 020000 Shop #: WSC 02391 823 56573 VCID: 2B55B2AB4A0539D5C6-807E No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb Part No SW: 8K0 959 760 HW: 8K0 959 760 Component: MEM-FS H05 0043 Revision: AA000000 Serial number: 00001001194653 Coding: 00581300000000000000 Shop #: WSC 02391 823 56573 VCID: 77FD5EDBC6CD4D3572-8022 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 Q HW: 4E0 919 887 M Component: MNS ECE H52 2050 Revision: 00000000 Serial number: 341LS087522084 Shop #: WSC 03106 444 85904 VCID: 3C7781F77F6BAE6D5F-8068 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8K0 959 793 D HW: 8K0 959 793 D Component: TSG FA H11 0250 Revision: Serial number: 0000008211452 Coding: 011C03204E00410001 Shop #: WSC 02391 823 56573 VCID: 4189F003D889C3850C-8014 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 F HW: 8K0 907 064 F Component: BCM2 1.1 H80 0145 Revision: 00002001 Serial number: 0116574160 Coding: 0106063A007A444400B001 Shop #: WSC 02391 823 56573 VCID: 3365AACB923561158E-8066 Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719 Component: GTO BF H06 0040 Serial number: 00000000000000108766 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591 Component: J245 PS034 H06 0037 4 Faults Found: 01518 - Bulb for Back-Up Lights; Left (M16) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 87 Mileage: 254864 km Time Indication: 0 Date: 2023.02.08 Time: 11:32:23 01519 - Bulb for Back-Up Lights; Right (M17) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 87 Mileage: 254864 km Time Indication: 0 Date: 2023.02.08 Time: 11:32:23 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 87 Mileage: 254865 km Time Indication: 0 Date: 2023.02.08 Time: 12:01:57 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 87 Mileage: 254865 km Time Indication: 0 Date: 2023.02.08 Time: 12:03:14 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels:. 8T0-035-223-ASM.clb Part No SW: 8T0 035 223 AD HW: 8T0 035 223 G Component: DSP STD H08 0300 Revision: S2600000 Coding: 020101 Shop #: WSC 02391 823 56573 VCID: 70EF65C7A3A31A0DB3-8024 1 Fault Found: 02247 - Subwoofer (R148/R157) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 87 Mileage: 254865 km Time Indication: 0 Date: 2023.02.08 Time: 12:03:17 Freeze Frame: Voltage: 11.90 V Temperature: 35.0°C Bin. Bits: 00000011 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8K0 959 792 D HW: 8K0 959 792 D Component: TSG BF H11 0250 Revision: Serial number: 0000008213300 Coding: 011C03204E00410001 Shop #: WSC 02391 823 56573 VCID: 408FF507D383CA8D03-8014 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 F HW: 8K0 907 801 F Component: EPB Audi B8 H06 0070 Revision: 00000003 Serial number: 10000000151845 Shop #: WSC 00000 000 00000 VCID: 326BAFCF6D2F681D85-8066 1 Fault Found: 01316 - ABS Control Module 013 - Check DTC Memory - MIL ON Freeze Frame: Fault Status: 11101101 Fault Priority: 4 Fault Frequency: 31 Reset counter: 87 Mileage: 254530 km Time Indication: 0 Date: 2023.02.01 Time: 11:52:34 Freeze Frame: Voltage: 14.50 V Count: 62 Speed: 70.0 km/h Hex Value: 0x0260 Hex Value: 0x0004 Hex Value: 0x0101 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8K0-907-357.clb Part No: 8K5 907 357 Component: Dynamische LWR H01 0010 Revision: 00000001 Serial number: Coding: 0000004 Shop #: WSC 02145 785 00200 VCID: 77FD5EDB06CD4D3572-8022 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4F0 035 541 N Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 379L2087564138 Coding: 0000001 Shop #: WSC 02145 785 00200 VCID: 3169A0C3A8295305FC-8064 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HL H10 0251 Revision: Serial number: 0000100597513 Coding: 010C03204000210001 Shop #: WSC 02391 823 56573 VCID: 4487F917C79BD6AD27-8010 1 Fault Found: 02115 - Locking Unit for Central Locking 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 72 Mileage: 254531 km Time Indication: 0 Date: 2023.02.01 Time: 10:33:23 ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A Component: SDS 3501 US H46 0630 Revision: 00000000 Serial number: 00000811280360 Shop #: WSC 12336 024 394758 VCID: 3467A9D7573B662D97-8060 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 B HW: 4L0 907 441 A Component: J772__Rearview 0070 Revision: --H12--- Serial number: 525PA8-J8Y92AM Coding: 1000006 Shop #: WSC 02145 785 00200 VCID: 377D9EDB464D8D35B2-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 N HW: 8K0 959 795 C Component: TSG HR H10 0251 Revision: Serial number: 0000100597308 Coding: 010C03204000210001 Shop #: WSC 02391 823 56573 VCID: 4487F917C79BD6AD27-8010 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4F0 910 336 H HW: 4E0 862 335 Component: Handyvorb2 H20 1130 Revision: 00000000 Serial number: 00000005074901 Coding: 0010900 Shop #: WSC 02145 785 00200 VCID: 285F4DA79BF312CD2B-807C No fault code found. End-------------------------(Elapsed Time: 04:23)-------------------------- Z góry dziękuje za pomoc i wyrozumiałość.
Muskel1 Opublikowano 8 Lutego 2023 Opublikowano 8 Lutego 2023 (edytowane) Albo czujnik stopu, jak nie to pompa ABS do wymiany. Edytowane 8 Lutego 2023 przez Muskel1
wenc0ne Opublikowano 8 Lutego 2023 Autor Opublikowano 8 Lutego 2023 Cześć. Czujnik stop wymieniłem w sobotę. Dzisiaj skasowałem błędy i narazie spokoj z tym abs. Powiedz mi czy znasz się na czytaniu błędów? Mógłbyś mi pomóc z resztą?
Muskel1 Opublikowano 8 Lutego 2023 Opublikowano 8 Lutego 2023 Wklej w Google bo w sieci jest wystarczająco dużo informacji na ten temat
