[INNE] Proszę o analizę logów i błędów (VW PASSAT AJM 1,9 TDI)
Witam
Pasek kumpla ma problemy z ABSem i łapie notlaufa.Dziś zrobiliśmy logi.
Prośba o pomoc w ich analizie.
Najpierw błędy:
te są robione tydzień temu:
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 038 906 019 AJ
Component: 1,9l R4 EDC G000SG 1060
Coding: 00002
Shop #: WSC 05311
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8D0 907 389 D
Component: ABS/ESP front D36
Coding: 04255
Shop #: WSC 44768
No fault code found.
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 0.7.0
Coding: 05000
Shop #: WSC 05311
1 Fault Found:
00792 - A/C Pressure Switch (F129)
35-00 - -
Address 15 -------------------------------------------------------
Controller: 6Q0 909 605 B
Component: 05 AIRBAG VW5 0003
Coding: 12341
Shop #: WSC 05311
Address 17 -------------------------------------------------------
Controller: 3B0 920 822 A
Component: B5-KOMBIINSTR. VDO V25
Coding: 05145
Shop #: WSC 70858
IMMO-IDENTNR: VWZ7Z0Y2269014
3 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
01176 - Key
07-10 - Signal to Low - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00004
Shop #: WSC 44768
2 Faults Found:
01044 - Control Module Incorrectly Coded
35-00 - -
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 3C Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 05311
1 Fault Found:
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
Address 56 -------------------------------------------------------
Controller: 1J0 035 152 E
Component: Radio GRO 0001
Coding: 00001
Shop #: WSC 05311
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End -------------------------------------------------------
błędy zostały skasowane.
te robione dziś, niektóre powróciły:
Coding: 00002
Shop #: WSC 05311
3 Faults Found:
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-00 - -
P1570 - 35-00 - -
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 35-10 - - - Intermittent
Readiness: N/A
Coding: 04255
Shop #: WSC 44768
2 Faults Found:
18264 - Throttle Potentiometer (G69): Error Message from ECU
P1856 - 35-10 - - - Intermittent
00532 - Supply Voltage B+
Coding: 05000
Shop #: WSC 05311
1 Fault Found:
Coding: 12341
Shop #: WSC 05311
Coding: 05145
Shop #: WSC 70858
2 Faults Found:
01176 - Key
Coding: 00004
Shop #: WSC 44768
1 Fault Found:
35-00 - -
Coding: 04097
Shop #: WSC 05311
1 Fault Found:
35-00 - -
Coding: 00001
Shop #: WSC 05311
1 Fault Found:
LOGI:
Próba statyczna
BS:
000
003
gupy normalne:
000
001
003
004
007
013
Próba dynamiczna:
000
001
004
010
011
błedy byly juz przerabiane :szukaj:
termostat do wymiany
przycinaja sie kierownice [sprawdzcie tez podcisnienia i uklad dolotowy]
gdzie 008 dynamiczne ?
zrobimy wrzucimy
i chyba 011 BS jeszcze :?:
zrobimy wrzucimy
mozna tez i 011 BS ... :wink4:
jest
008 DYN:
i 011BS:
Nic nie widze zlego w tych logach..
cz w 011 BS obroty powinny wzrosnąć ?? :mysli:
Tak ... w PD jest inaczej niz w VP...
ok
