SIDNEY85 Opublikowano 19 Maja 2009 Opublikowano 19 Maja 2009 Witam panowie od wczoraj szykam tematu ktory moglby mi pomoc ale nie znalazlem odpowiedzi. Problem polega na tym ze samoczynnie wlancza mi sie centralny zamek tz otwiera sie co chwile tak jak ja bym naciskal otwieranie drzwi na panelu, i zapalaja sie swiatla, z kluczyka wogole samochod nie reaguje. Jak otwieram drzwi z kluczyka to otwiera tylko kierowce, a jak zamykam to wszytkie zamki, sprawdzilem model konfortu jest suchy. Podpiolem Vag i oto jakie bledy uzyskalem: Control Module Part Number: 4B0 962 258 H Component and/or Version: Central Lock/Alarm D32 Software Coding: 04814 Work Shop Code: WSC 02325 11 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01557 - Contact Switch in Locking Cyl: Driver Side: Open (F241) 29-10 - Short to Ground - Intermittent 00955 - Key 1 09-10 - Adaptation Limit Surpassed - Intermittent 01561 - Left Rear Door 59-10 - Can't Unlock - Intermittent 01559 - Drivers Door 60-00 - Won't Safe 01561 - Left Rear Door 61-10 - Won't De-Safe - Intermittent 01134 - Alarm Horn (H12) 49-10 - No Communications - Intermittent --------------------------------------------------------------------------- Tuesday, 19 May 2009, 14:54:18 VAG-COM Version: Release 409.1-US Control Module Part Number: 4B0 962 258 H Component and/or Version: Central Lock/Alarm D32 Software Coding: 04814 Work Shop Code: WSC 02325 11 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01557 - Contact Switch in Locking Cyl: Driver Side: Open (F241) 29-10 - Short to Ground - Intermittent 00955 - Key 1 09-10 - Adaptation Limit Surpassed - Intermittent 01561 - Left Rear Door 59-10 - Can't Unlock - Intermittent 01559 - Drivers Door 60-00 - Won't Safe 01561 - Left Rear Door 61-10 - Won't De-Safe - Intermittent 01134 - Alarm Horn (H12) 49-10 - No Communications - Intermittent --------------------------------------------------------------------------- Tuesday, 19 May 2009, 14:56:56 VAG-COM Version: Release 409.1-US Control Module Part Number: 4B0 962 258 H Component and/or Version: Central Lock/Alarm D32 Software Coding: 04814 Work Shop Code: WSC 02325 11 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01557 - Contact Switch in Locking Cyl: Driver Side: Open (F241) 29-10 - Short to Ground - Intermittent 00955 - Key 1 09-10 - Adaptation Limit Surpassed - Intermittent 01561 - Left Rear Door 59-10 - Can't Unlock - Intermittent 01559 - Drivers Door 60-00 - Won't Safe 01561 - Left Rear Door 61-10 - Won't De-Safe - Intermittent 01134 - Alarm Horn (H12) 49-10 - No Communications - Intermittent --------------------------------------------------------------------------- Tuesday, 19 May 2009, 14:58:07 VAG-COM Version: Release 409.1-US Control Module Part Number: 4B0 962 258 H Component and/or Version: Central Lock/Alarm D32 Software Coding: 04814 Work Shop Code: WSC 02325 11 Faults Found: 01366 - Opened Due to Crash Signal 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01557 - Contact Switch in Locking Cyl: Driver Side: Open (F241) 29-10 - Short to Ground - Intermittent 00955 - Key 1 09-10 - Adaptation Limit Surpassed - Intermittent 01561 - Left Rear Door 59-10 - Can't Unlock - Intermittent 01559 - Drivers Door 60-00 - Won't Safe 01561 - Left Rear Door 61-10 - Won't De-Safe - Intermittent 01134 - Alarm Horn (H12) 49-10 - No Communications - Intermittent --------------------------------------------------------------------------- Juz w grudniu przestal mi dzialac jeden z kluczykow, to uzywalem 2 a teraz zaden nie dziala i wszystko szaleje, czy padl modol konfortu czy jest jakis sposob sprawdzenia go i jezeli padl to ile kosztuje nowy ??? Z gory dziekuje wszytkim za odpowiedz.
Sztomel Opublikowano 20 Maja 2009 Opublikowano 20 Maja 2009 wszystko wskazuje, że źródło usterki leży w zamku drzwi kierowcy i aby zobaczyć co się tam dzieje - a z pewnością będą tam albo zerwane luty od mikrostyków albo uszkodzony mechanizm sterujący mikrostykami czego przykładem są m.in. błędy : 01366 - Opened Due to Crash Signal35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01557 - Contact Switch in Locking Cyl: Driver Side: Open (F241) 29-10 - Short to Ground - Intermittent 00955 - Key 1 09-10 - Adaptation Limit Surpassed - Intermittent 01561 - Left Rear Door 59-10 - Can't Unlock - Intermittent 01559 - Drivers Door 60-00 - Won't Safe 01561 - Left Rear Door 61-10 - Won't De-Safe - Intermittent 01134 - Alarm Horn (H12) 49-10 - No Communications - Intermittent ponadto widać, że brak jest połączenia z syreną alarmu, rozkodował się klucz i dlatego ten pierwszy Ci nie działał a ponadto uruchomił sygnał alarmu (bez syreny) : świadczy o tym ten błąd - 00955 - Key 1 09-10 - Adaptation Limit Surpassed - Intermittent i prawdopodobnie ktoś bawił się przyciskami pilota centralnego zamka będąc poza zasięgiem czujników w samochodzie i spowodował jego rozkodowanie. Cóż mogę poradzić w tej sprawie - rozbierz sam bok drzwi i dostań się do zamka, wymontuj go i rozbierz i zwróć uwagę na pęknięte luty, przerwy w połączeniach elektrycznych, zwróć uwagę czy przekręcanie zamka w pozycję otwarty/zamknięty powoduje sprawne wsuwanie i wysuwanie bolców mikroprzełączników, jeśli sam nie czujesz się na siłach to zleć to dobremu elektromechanikowi.
