[B6 AVB] Prośba o analizę logów
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 JP
Component: 1,9l R4 EDC 0000SG 1569
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E23A314715 AUZ6Z0B0403412
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04155
Shop #: WSC 06435
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
01809 - Actuating Motor for Temperature Flap: Left (V158)
41-10 - Blocked or No Voltage - Intermittent
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 C
Component: int. Lastmodul RDW 0606
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00002
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 K
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 00000
Shop #: WSC 25700
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to B+
27-10 - Implausible Signal - Intermittent
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AR
Component: Komfortgerát T85 1310
Coding: 06976
Shop #: WSC 63351
1 Fault Found:
01559 - Drivers Door
59-10 - Can't Unlock - Intermittent
End -------------------------------------------------------
to nie logi.... tylko bledy ...
poszukaj na forum sa opisane ...
