moskal 4 Opublikowano 8 Grudnia 2010 Udostępnij Opublikowano 8 Grudnia 2010 Siema , przeanalizuje mi ktoś błędy ??? Pacjent to S4 B5 z 1998r. z tego co widze to nie ma sie czym przejmować :kox: VCDS Version: Release 10.6.0 Data version: 20100630 Tuesday,07,December,2010,20:59:41:46862 Chassis Type: 8D - Audi A4 B5 Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77 Mileage: 199560km/124000miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 078-907-551-AZA.lbl Part No: 8D0 907 551 C Component: 2.7l V6/5VT G 0002 Coding: 05711 Shop #: WSC 07777 VCID: 2A5000F6BAA53F4C 4 Faults Found 18057 - Powertrain Data Bus: Missing Message from ABS Controller P1649 - 35-00 - - 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent 17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground P1454 - 35-00 - - 17947 - Clutch Pedal Switch (F36): Implausible Signal P1539 - 35-10 - - - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl Part No: 8E0 614 111 A Component: ABS/EDS 5.3 QUATTRO D00 Shop #: BB 24334 VCID: 1C3CD62EE0F1D1FC 2 Faults Found 00283 - ABS Wheel Speed Sensor; Front Left (G47) 30-00 - Open or Short to Plus 01201 - ABS Valves Supply Voltage 35-00 - - ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl Part No: 8D0 820 043 M Component: A4 KLIMAAUTOMAT D57 Coding: 00043 Shop #: WSC 06335 VCID: 2A5000F6BAA53F4C 2 Faults Found 00792 - A/C Pressure Switch (F129) 31-00 - Open or Short to Ground 01273 - Fresh Air Blower (V2) 17-10 - Control Difference - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8D0-959-655-AI7.lbl Part No: 8D0 959 655 L Component: Airbag 7 Audi 0503 Coding: 00106 Shop #: WSC 06342 VCID: 3F8641A25127AAE4 2 Faults Found 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent 01217 - Side Airbag Igniter; Driver Side (N199) 32-10 - Resistance too High - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8D0-919-xxx-17.lbl Part No: 8D0 919 880 P Component: B5-KOMBIINSTR. VDO D08 Coding: 04162 Shop #: WSC 00227 VCID: 3F8641A25127AAE4 Part No: IMMO Component: IDENTNR: AUZ7Z0W0586066 IMMO-IDENTNR: AUZ7Z0W0586066 No fault code found. ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8L0 862 257 G Component: ZV-Pumpe, DWA, Funk D08 Coding: 13130 Shop #: WSC 06342 VCID: 39722FBA4F0384D4 8 Faults Found 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 00956 - Key 2 09-00 - Adaptation Limit Surpassed ------------------------------------------------------------------------------- Address 37: Navigation Labels: None Part No: 8D0 035 192 Component: Navigation 0001 Coding: 00000 Shop #: WSC 06435 VCID: E0C422DE0C19351C 3 Faults Found 00854 - Radio Display Output in dash Panel insert 49-00 - No Communications 00862 - Antenna for GPS Navigation (R50/R52) 36-00 - Open Circuit 01311 - Information Data Bus 49-00 - No Communications ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-173.lbl Part No: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00102 Shop #: WSC 06342 VCID: E0C422DE0C19351C No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl Part No: 4B0 907 357 Component: LEUCHTWEITEREGLER D000 Coding: 00004 Shop #: WSC 06342 VCID: E5CA33CA133B5034 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: None Part No: 8D0 035 192 Component: Radio 0001 Coding: 00207 Shop #: WSC 06435 VCID: E0C422DE0C19351C 2 Faults Found 00856 - Radio Antenna 36-10 - Open Circuit - Intermittent 00854 - Radio Display Output in dash Panel insert 49-00 - No Communications Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
