Kodowanie radia z USA na Europe w A4 B8
MultiPanda69
Witam.
Posiadam Audi A4 B8 (z USA), czy wie ktoś może gdzie zmienic kodowanie radia (przez Vag) z USA na Europe.
Żeby radio wyszukiwało stacje co 0.1 MHz?
Pozdrawiam :hi:
Tak też wyszukuje, ale chcę zmienić kodowanie żeby wyszukiwało co 0.1 - czyli nieparzyste oraz parzyste częstotliwości. Brakuje mi trójki ;(
Kolego tego nie przekodujesz VAGiem... z mojej wiedzy wynika, że radio jest do wymiany... :kwasny:
" I found this, but its for the Nav plus..I need something like this but for Symphony II..some1 help me out!!!
To turn off Navigation system acceptance screen:
This modification also turns off the key in ignition chime. It can be performed on cars with the standard radio just for this reason. On those cars it will not change the radio settings or effect the AM portion of the radio like it does on the cars with the navigation radio.
1) start VAG-COM
2) click: “select control module” button
3) in Direct Entry box type: 17
4) click: RECODE 07
5) In the Software Coding box should be a number (mine was 0007231). The second digit after the three 0s (2 in the above example) seems to be a region code.
1 - Europe
2 - USA
3 - Canada
4 - UK
In other words by changing the coding from 0007231 to 0007131 you'd get rid of the acceptance screen! So enter the number you want and click: DO IT.
6) click: close controller, go back
7) click: go back
One note: The Radio Issue:
Europe uses different specs for their radio compared to North America.
FM:
FM frequencies in Europe are spaced .1Mhz apart, compared to .2Mhz in North America. This causes no problems in using a Nav Plus in North America, it just means you can tune into some frequencies (such as 92.2) which don't exist here. Since it can tune into all the North American FM frequencies that do exist, it works fine "
ale u mnie to wygląda tak:
dodatkowo wrzucam screen z 56-Radio :
oraz 09 -Cent. Elec.:
Może ktoś coś podpowie/wymyśli?
Jesłi ma wbudowany odtwarzacz DVD to będzie problem z regionem w EU i tego juz nie przeskoczy
tez mi sie wydaje że radio fabryczne USA odpada w EU :gwizdanie:
Zgadza sie radio pewnie do wymiany...... nie wiem :confused4: w USA jest system Sirius a ten u nas EU nie dziala :(
Moze magicy w NAVISERWIS ogarnal temat zadzwon i popytaj czy taka usluge wykonuja :)
http://www.naviservice.com.pl/index.php?menu=5
Czy wiadomo jak dzisiaj wygląda sytuacja w tym temacie? Mam w B8 radio z kanady ze skokiem co 0.2 MHz. Jak do tego podejść i kto się tym zajmuje?
pozdro
pozdro
a jakie dokładnie masz RADIO ? bo duzo rzeczy zmieniło sie przez te pare lat :)
Dam znać niedługo, bo dopiero jutro odbieram auto.
Dzięki!
pozdro
Auto już w garażu:)
Jeśli chodzi o radio, to w karcie pojazdu mam dane takie jak poniżej.
8DY
P
RAO
Radio "HIGH" America
7D5
P
CDW
DVD player
7QA
L
CDR
Without CD/DVD for navigation
7T6
P
NAV
Navigation system (MID)
8DY
P
RAO
PND
G
Navigation system plus incl. MMI for NAR
QH1
P
SPR
Voice control
QV8
L
TVE
Satellite radio reception NAR
pozdrawiam,
Klimak
Edytowane przez Klimak
Podpinam się pod temat. Co jestem w stanie zrobić vagiem 12.12 z radiem z USA w a4 b8 10.2010
Radio/nawigacja:
- Satellite radio reception NAR Speaker (active)
- Voice control
- Electric interface for external use DVD player
- Mobile phone preparation
- Radio "HIGH" America
MMI
- sterownik: 8T1 035 664 C
- software version: HNav_US_P0114_D1
Radio
- sterownik 4G0 035 082
VCDS-em nic nie zrobisz  :hi:
Jakby co zapraszam na przeróbke Systemu Nawigacyjnego oraz RADIA  bez lutowania itd
Przeróbka tylko u kogoś kto zna temat [emoji6]
Wysłane z mojego SM-G920F przy użyciu Tapatalka
