Reggi Opublikowano 13 Lutego 2012 Opublikowano 13 Lutego 2012 Witam. Problem z moim autem został opisany w temacie http://www.a4-klub.pl/smf/index.php?topic=243502.0 Proszę o analizę logów. Błędy jakie były po podpięciu kompa: Błędy . VAG-COM Version: Release 311.2-N Control Module Part Number: 4B0 907 557 C Component and/or Version: 1.8L R4/5VT MOTR HS D02 Software Coding: 04002 Work Shop Code: WSC 00777 5 Faults Found: 17967 - Throttle Valve Control part (J338): Fault in basic settings P1559 - 35-00 - - 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal P0116 - 35-10 - - - Intermittent 00561 - Mixture Adaptation 15-00 - Adaptation Limit (Add) Not Reached 00561 - Mixture Adaptation 12-00 - Adaptation Limit (Mul) Exceeded 17973 - Throttle Actuator (J338): Lower Stop not Reached P1565 - 35-00 - - wraca VAG-COM Version: Release 311.2-N Control Module Part Number: 4B0 907 557 C Component and/or Version: 1.8L R4/5VT MOTR HS D02 Software Coding: 04002 Work Shop Code: WSC 00777 1 Fault Found: 17967 - Throttle Valve Control part (J338): Fault in basic settings P1559 - 35-00 - -
