jordan233 Opublikowano 14 Maja 2008 Opublikowano 14 Maja 2008 Witam Co to za błąd ?? Dodam iż miałem wyładowane aku,ale podładowałem na 3 godzinki i taki błąd powstał,nie mam go w spisie błędów Vaga. Control Module Part Number: 4A0 953 234 Component and/or Version: IMMO AUZ9Z0S6442588 D76 Software Coding: 00000 Work Shop Code: WSC 06335 1 Fault Found: 01176 - Key 07-10 - Signal to Low - Intermittent
mcm Opublikowano 14 Maja 2008 Opublikowano 14 Maja 2008 01176 - Key Faulty: Signal too Low Possible Causes * Low voltage in key-battery * Bad connections between immo reader coil and immo control module Possible Solutions * Replace key-battery * If more than one key acts like this, check / clean the connector between immo reader coil and immo control module, the contacts tend to oxidize * There is also another known issue with the wiring between reader coil and immo module, they are known to be too short so there is a 'longer' wiring (8D0-972-275) available [br]Dopisany: 14 Maj 2008, 21:43 _________________________________________________najpierw wykasuj błąd jak się pojawi to kombinuj dalej czyli: słaba bateria w kluczyku złe połączenie między immo w kluczyku a czytnikiem immo wymień baterię w kluczyku lub sprawdź połączenia immo
jordan233 Opublikowano 14 Maja 2008 Autor Opublikowano 14 Maja 2008 N 01176 - Key Faulty: Signal too Low Possible Causes * Low voltage in key-battery * Bad connections between immo reader coil and immo control module Possible Solutions * Replace key-battery * If more than one key acts like this, check / clean the connector between immo reader coil and immo control module, the contacts tend to oxidize * There is also another known issue with the wiring between reader coil and immo module, they are known to be too short so there is a 'longer' wiring (8D0-972-275) available [br]Dopisany: 14 Maj 2008, 21:43 _________________________________________________najpierw wykasuj błąd jak się pojawi to kombinuj dalej czyli: słaba bateria w kluczyku złe połączenie między immo w kluczyku a czytnikiem immo wymień baterię w kluczyku lub sprawdź połączenia immo Nigdy nie miałem problemów z IMOBILAJZEREM,dopóki nie odłączyłem akumulatora na kilka godzin,bo zmieniałem moduł przepustnicy,i podładowałem aku na 3 godzinki,załóżyłem i odpalił,potem podłączyłem Vaga i pokazało mi błąd imo,jak w opisie powyżej,wykasowałem błąd,i jest na razie ok,zobacze jutro,jak pojeżdze chwile,co Vag pokaże,chciałbym żeby to się skończyło na bateryjce.
mcm Opublikowano 14 Maja 2008 Opublikowano 14 Maja 2008 skasuj może to błąd chwilowy po odłączeniu aku
baskecior Opublikowano 23 Maja 2008 Opublikowano 23 Maja 2008 01176 - Key Faulty: Signal too Low Possible Causes * Low voltage in key-battery * Bad connections between immo reader coil and immo control module Possible Solutions * Replace key-battery * If more than one key acts like this, check / clean the connector between immo reader coil and immo control module, the contacts tend to oxidize * There is also another known issue with the wiring between reader coil and immo module, they are known to be too short so there is a 'longer' wiring (8D0-972-275) available [br]Dopisany: 14 Maj 2008, 21:43 _________________________________________________najpierw wykasuj błąd jak się pojawi to kombinuj dalej czyli: słaba bateria w kluczyku złe połączenie między immo w kluczyku a czytnikiem immo wymień baterię w kluczyku lub sprawdź połączenia immo Skąd masz te informacje ? Jakaś serwisówka Audi , czy z innego forum ? Pytam, bo bateria w kluczyku nie ma nic wspólnego z immo - to jest transponder zasilany polem elektrycznym cewki w obudowie kolumny przy stacyjce. Sam borykam się ostatnio właśnie z podobnym problemem i zastanawiam się czy zacząć od wyczyszczenia połaczeń, czy jak radzi mój dobry znajomek - udac się do ASO po nową cewkę ...
baskecior Opublikowano 23 Maja 2008 Opublikowano 23 Maja 2008 Piękne dzięki :th: Z opisu wynika aby obciąć złączkę i połączyć wszystko bezpośrednio - lutując ? Rozumiem , że bez demontażu kierownicy nie ma szans ? (pytam o twoja wersję z dogięciem końcówek i sprayem) ?
