Montaż kierownicy z A4 B7 do A4 B5 FL
Witam mistrzów jak wygląda sprawa montażu tej kierownicy i uruchomieniu multifunkcji jest szansa ??
i co dalej
dość ciekawy zabieg, powodzonka ;)
i co dalej
cos takiego znalazłem
AudiSRS.com :: Making Multi function steering wheel controls work on B5 RS4
Adaption for the Nav Plus:
NOTE! Not all of these settings are available on the C-Navi. Only adaption channel 1, 2, 3 and 4 are available.
You will also have to check several settings for the operation of the Nav Plus. Connect VagCom and go to Module 37, Navigation. You use the "Adaption - 10" function of VAGCom to do this.
Below are the settings for the different adaption channels:
Channel Function Number Comment
1 Tires in mm 1935 195/65 R15
1910 205/60 R15
1930 205/55 R16
1930 225/45 R17
1937 255/35 R18
1895 185/65 R15
1935 195/65 R15
1930 205/55 R16
1930 225/45 R17
1940 225/40 R18
2 Rotational pulse 8 For cars that use the GALA signal
45 For cars that use ABS signal
3 Diagnostic 0 Leave disabled. It's a way to check functions of the Nav Plus.
4 Cluster colour 0 Monochrome (red)
1 Colour (note, may work better for cars with red displays as well.)
5 Land Identification (D-Navi) 0 Europe
1 USA/Canada, but I haven't seen this do anything.
6 TMC Coding (D-Navi) 0 This will disable TMC. Use 0 if you do not have a TMC on your unit to prevent a startup error being displayed when you turn on your Nav Plus. Traffic button will be disabled.
1 Sets TMC to use radio source. (Useless in N.A.)
2 Sets TMC to use telephone source. (Useless in N.A.)
3 Sets TMC to use radio and telephone source. (Useless in N.A.)
7 Option Coding: (see note below) (D-Navi) 0 No options.
1 Logbook installed.
2 Multi-Function Wheel installed (CANbus based).
4 TV Tuner installed. (B version)
8 Voice Command Module installed.
Note that for adaption channel 7, you add these functions to come up with the number. For example if you have a TV tuner and multifunction wheel, you'd enter 6 (2+4=6). Voice recognition and Logbook would be 9 (1+8=9)
---------- Post dopisany at 20:50 ---------- Poprzedni post napisany at 20:49 ----------
chyba działa ten opis, bo po tym wysypały sie foty swapów
AudiSRS.com :: RS4 B7 Flat Bottom Steering Being Fited 2 B5 RS4!Help Please
---------- Post dopisany at 20:54 ---------- Poprzedni post napisany at 20:50 ----------
New style B7/TT-S flat bottom wheel in a B5 help
---------- Post dopisany at 20:55 ---------- Poprzedni post napisany at 20:54 ----------
How to replace B5 S4 steering wheel with RS4 Steering wheel (thanks to TeddyBGame And LI S4) BWW - AudiWorld Forums
tu niestety foty wygasły:thumbdown:
mam licznik vdo d12 z zegarkiem cyfrowym i radiowym , rns-e i bluetooth,brakuje sterowania i sds :D ,tutah gosciu ma wszystko w 8l0
---------- Post dopisany 30-11-2012 at 18:23 ---------- Poprzedni post napisany 29-11-2012 at 20:56 ----------
i jak panowie ??
Ale poduszka wam nie zadziała przy takiej zamianie.:wink:
sid zamontował ale przyciski nie działają, mu chyba dam se spokój,mam apetyt na BeX-a w Quattro tam pójdzie bez problemu
szkoda;/
Kiera z RS4 B7 nie bedzie hulać w zadnym B5 , B6 , B7 ONLY RS4 :wink: wiem to ze swojego doswiadczenia .
