Kilka błędów do analizy
Witam, przedstawiam kilka logów z dzisiejszej diagnozy może ktoś coś podpowie...
Chassis Type: 8E - Audi A4 B6
Address 01 -------------------------------------------------------
Controller: 8E0 907 401 D
Component: 2.5L V6 TDI G000SG 0007
Coding: 02015
Shop #: WSC 63251
00005059 130 106LC150_1.V79268198284
1 Fault Found:
01375 - Valves for Engine Mounting: Stage 1
38-10 - Output won't Switch or Short to B+ - Intermittent
Address 37 -------------------------------------------------------
Controller: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0008
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AF
Component: Komfortgerát T03 0316
Coding: 06976
Shop #: WSC 05311
2 Faults Found:
01561 - Left Rear Door
61-00 - Won't De-Safe
01562 - Right Rear Door
61-10 - Won't De-Safe - Intermittent
Address 56 -------------------------------------------------------
Controller: 8E0 035 195 C
Component: symphony II NP2 0151
Coding: 00011
Shop #: WSC 51314
1 Fault Found:
00-00 - -
Address 76 -------------------------------------------------------
Controller: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D07
Coding: 00114
Shop #: WSC 63251
2 Faults Found:
01545 - Sensor for Parking Aid: Rear Left (G203)
31-00 - Open or Short to Ground
01546 - Sensor for Parking Aid: Rear Mid-Left (G204)
błedy wracaja po kasowaniu ?
Address 01,37,56,76 te błędy powracają przy kasowaniu.
Przy 76 pewnie do wymiany czujniki parkowania
