Prośba o sprawdzenie logów
Witam Panowie:hi:
Podłączyłem swoją B8 pod VCDS i takie błędy mi wyskoczyły:
Thursday,28,November,2013,12:11:16:46862VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 8T0
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 69 72
VIN: WAUZZZ8K1AA157150   Mileage: 177210km/110113miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
[b]05-Acc/Start Auth. -- Status: Malfunction 001[/b]0
08-Auto HVAC -- Status: OK 0000
[b]09-Cent. Elect. -- Status: Malfunction 0010[/b]
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
[b]19-CAN Gateway -- Status: Malfunction 0010[/b]
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
  Part No SW: 03L 906 022 NN    HW: 03L 906 019 AL
  Component: R4 2,0L EDC   H25 9096
  Revision: 25H25---
  Coding: 12194012243403080000
  Shop #: WSC 48895 143 87273
  ASAM Dataset: EV_ECM20TDI03L906022NN A02011
  ROD: EV_ECM20TDI03L906022NN.rod
  VCID: 7EF8FCA616AD63EC
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
  Part No SW: 8K0 907 379 BB    HW: 8K0 907 379 BB
  Component: ESP8 front    H04 0020
  Revision: --------    Serial number: --------------
  Coding: 168504
  Shop #: WSC 39560 150 86117
  VCID: 7AF0F0B60A854FCC
[b]Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb[/b]
[b]   Part No SW: 8K0 907 064 DQ    HW: 8K0 907 064 DQ[/b]
[b]   Component: BCM2 1.1      H02 0328  [/b]
[b]   Revision: 00002001    [/b]
[b]   Coding: 072200[/b]
[b]   Shop #: WSC 06335 000 00000[/b]
[b]   VCID: 82000856E255870C[/b]
[b]   Part No SW: 8T0 959 754 K    HW: 8T0 959 754 K[/b]
[b]   Component: FBSAUDIB8 IDG  H40 0070 [/b]
[b]   Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D[/b]
[b]   Component: J764 ELV MLB  H37 0042 [/b]
[b]4 Faults Found [/b]
[b]03286 - Sensor for Contact with Door Handle; Front Right [/b]
[b]            008 - Implausible Signal - Intermittent[/b]
[b]             Freeze Frame:[/b]
[b]                    Fault Status: 00101000[/b]
[b]                    Fault Priority: 2[/b]
[b]                    Fault Frequency: 31[/b]
[b]                    Reset counter: 210[/b]
[b]                    Mileage: 176523 km[/b]
[b]                    Time Indication: 0[/b]
[b]                    Date: 2013.10.11[/b]
[b]                    Time: 14:13:12[/b]
[b]            007 - Short to Ground[/b]
[b]                    Fault Status: 01100111[/b]
[b]                    Fault Frequency: 7[/b]
[b]                    Reset counter: 173[/b]
[b]                    Mileage: 177212 km[/b]
[b]                    Date: 2013.11.12[/b]
[b]                    Time: 11:37:13[/b]
[b]            011 - Open Circuit - Intermittent[/b]
[b]                    Fault Status: 00101011[/b]
[b]                    Fault Frequency: 2[/b]
[b]                    Mileage: 176488 km[/b]
[b]                    Date: 2013.10.06[/b]
[b]                    Time: 19:56:33[/b]
[b]00955 - Key 1 [/b]
[b]            002 - Lower Limit Exceeded - Intermittent[/b]
[b]                    Fault Status: 00100010[/b]
[b]                    Fault Priority: 3[/b]
[b]                    Fault Frequency: 1[/b]
[b]                    Reset counter: 213[/b]
[b]                    Date: 2013.11.21[/b]
[b]                    Time: 11:56:38[/b]
Address 08: Auto HVAC (J255)       Labels: Redir Fail!
  Part No SW: 8T1 820 043 AH    HW: 8T1 820 043 AH
  Component: KLIMA 1 ZONE  H08 0171
  Revision: A1000000    Serial number: 01240320101285
  Coding: 34300000
  VCID: 77F6E982399752A4
[b]Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb[/b]
[b]   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P[/b]
[b]   Component: BCM1 1.0      H29 0380  [/b]
[b]   Revision: 10029001    Serial number: 00000000627363[/b]
[b]   Coding: 260050914034AF000001000300001D0D0F1C270806010101000000[/b]
[b]   Shop #: WSC 39560 150 86117[/b]
[b]   VCID: 3C7C36AE4031B1FC[/b]
[b]   Part No SW: 8K1 955 119 A    HW: 8T1 955 119 [/b]
[b]   Component: WWS 180310  H06 0070 [/b]
[b]   Coding: 00FD11[/b]
[b]   Part No SW: 8K0 955 559     HW: 8K0 955 559 [/b]
[b]   Component: RLS  H04 0003 [/b]
[b]   Coding: 025028[/b]
[b]   Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL[/b]
[b]   Component: E1 - LDS  H08 0090 [/b]
[b]1 Fault Found [/b]
[b]00978 - Lamp for Low Beam; Left (M29) [/b]
[b]            012 - Electrical Fault in Circuit - Intermittent[/b]
[b]                    Fault Status: 00101100[/b]
[b]                    Reset counter: 212[/b]
[b]                    Mileage: 176571 km[/b]
[b]                    Date: 2013.11.11[/b]
[b]                    Time: 16:43:00[/b]
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
  Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
  Component: PARKHILFE 4K  H06 0070
  Revision: 11001001    Serial number: 51241008302373
  Coding: 010003
  VCID: 4796594209F7E224
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
  Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
  Component: AirbagVW-AU10 H41 0610
  Serial number: 003GKD0DUWVT
  Coding: 30343435363030303030554A304C384B3053
  ASAM Dataset: EV_AirbaECUVWAUDI010 003010
  ROD: EV_AirbaECUVWAUDI010_AU48.rod
  VCID: 448C4E4E38C1C93C
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
  Part No SW: 8K0 953 568 F    HW: 8K0 953 568 F
  Component: Lenks.Modul   H16 0014
  Revision: --------    Serial number: 90304JCO0009M
  Coding: 000017
  VCID: 3D7A3BAA5B2BB8F4
  Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
  Part No SW: 8K0 920 930 D    HW: 8K0 920 930 D
  Component: KOMBIINSTR.   H20 0255
  Revision: 00300000    Serial number: CIY62ER3A
  Coding: 0F04100002000008000000
  VCID: 2E580CE6864D536C
[b]Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb[/b]
[b]   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K[/b]
[b]   Component: GW-BEM 4CAN-M H09 0117  [/b]
[b]   Revision: EC000056    Serial number: 5600E103148277[/b]
[b]   Coding: 00CF07[/b]
[b]   VCID: 830E0D52FD4F8E04[/b]
[b]   Part No SW: 8X0 915 181     HW: 8X0 915 181 [/b]
[b]   Component: J367-BDM  H07 0140 [/b]
[b]03041 - Energy Management Active [/b]
[b]            000 -  -  - Intermittent[/b]
[b]                    Fault Status: 00100000[/b]
[b]                    Fault Priority: 7[/b]
[b]                    Date: 2013.10.22[/b]
[b]                    Time: 20:46:00[/b]
[b]                    Bin. Bits:    00000[/b]
[b]                    Voltage: 12.20 V[/b]
[b]                    Count: 17[/b]
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
  Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
  Component: TSG FA        H11 0306
  Revision:             Serial number: 0000010361278
  Coding: 011C12204000410001
  VCID: 458A534A33FBF034
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
  Revision: 00002001    Serial number: 0128283477
  Coding: 01000E20203904410120023680000000
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
  Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
  Component: TSG BF        H11 0306
  Revision:             Serial number: 0000010359892
Address 53: Parking Brake (J540)       Labels: 8K0-907-801.clb
  Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
  Component: EPB Audi B8   H09 0100
  Revision: 00000003    Serial number: 10000000475756
  Shop #: WSC 00000 000 00000
  VCID: 346C1E8E686179BC
Address 55: Xenon Range        Labels: 8K0-907-357.clb
  Part No: 8K5 907 357 A
  Component: Dynamische LWR  H01 0010
  Revision: 00000001    Serial number:
  Coding: 0000004
  Shop #: WSC 06334 000 00000
  VCID: 38742ABE74099DDC
Address 56: Radio (R)       Labels: None
  Part No SW: 4F0 035 053 K    HW: 4F0 035 053
  Component: Radio U Basic H45 0074
  Revision: AB001007    Serial number: 341CP0A7719401
  Coding: 010003020100000001
  VCID: 254AF3CAD3BB1034
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
  Part No SW: 8T1 035 666 J    HW: 8T1 035 666 E
  Component: H-BN-EU       H47 0174
  Revision: --------    Serial number: 483CY0A7605544
  Coding: 01010001000681ED01002B1E000000030001
  VCID: 4182475A27D3DC14
  Part No: 8R0 060 884 J
  Component: EUR 2010  1005
  Part No SW: 4F0 919 604     HW: 4F0 919 604
  Component: DU7 High  H43 0306
  Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
  Component: E0380 Bedient  H08 0100
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
  Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
  Component: TSG HL        H10 0306
  Revision:             Serial number: 0000103224174
  Coding: 010C12204000210001
  VCID: 4280485622D5C70C
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
  Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
  Component: Anhaenger     H07 0070
  Revision: 1A001001    Serial number: 00000133427982
  Coding: 0100000000000000
  VCID: 366824867E1D6BAC
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
  Component: TSG HR        H10 0306
  Revision:             Serial number: 0000103224177
End   ---------------------------------------------------------------------
Co może być przyczyną tych błędów? Kasowanie nic nie daje, pojawiają się od razu.
Z góry dzięki za odpowiedź.
Pozdro
czujnik klamki do wymiany z prawej strony :wink: dlatego sa bledy w 05
W MCE O9 masz bład zarowki z przodu (pewnie spalona)
dokladnie... czujnik klamki i swiatlo krotkie - blad
Dzięki za pomoc.
Ale o co chodzi dokładnie z tym czujnikiem klamki? Na klamkach mam jakieś takie małe kwadraciki, ale to wygląda jak zwykła zaślepka, nie można tego wcisnąć, ani nic. Domyślam się, że chodzi o ten system Keylessngo, bo mogę silnik odpalić bez kluczyka w stacyjce. Te czujniki w drzwiach, to są zbliżeniowe, czy powinny być jakieś przyciskowe?
Światło krótkie? Hmmm, ale mijania swieca dobrze, zarnik nie jest spalony
Dzięki za pomoc
chodzi o te czujniki zblizeniow do keylessgo - prawy przod
w Bixie to wszystko jedno :decayed: - nie masz spalonego lewego xenona?:wink:
Aha, czyli sa zblizeniowe. Taki czujnik drogi jest?
A co do swiatel, to sprawdzalem, i wszystkie swiatla przednie dzialaja
Wysłane z mojego GT-I9100 za pomocą Tapatalk 4
a moze miales spalona zarowke wczesniej i blad pozostal?
00978 - Ross-Tech Wiki
kodowales cos ostatnio? :decayed:
jakie zarniki masz u siebie? ori?
nie mam pojecia ile te czujniki kosztuja... ale mysle ze w granicach 150zl/szt
temat sensorow opisany na a5oc :) widac dosc znany i byla na te sensory akcja od rocznika 2009 i wymieniali je w serwisie
Advanced key entry problem - A5_OC
Dziwna sprawa. Przed momentem, jak wracalem do domu wyskoczyl mi blad spalonej zarowki. Nie zdazylem sie zorientowac o jaka zarowke chodzi. Wylaczylem zaplon, wlaczylem i blad juz zniknal
---------- Post dopisany at 19:16 ---------- Poprzedni post napisany at 19:08 ----------
Moze faktycznie cos tam w koste nie styka.
A powiedzcie mi jeszcze panowie, czy ten blad zwiazany z tymi czujnikami od drzwi moze miec cos wspolnego z systemem start/stop? Czasem ten system dziala, a czasem na Fis pokazuje sie info przekreslony ten symbol A ze strzalka
---------- Post dopisany at 19:30 ---------- Poprzedni post napisany at 19:16 ----------
Panowie,
a ten czujnik klamki ma jakiś numer seryjny?
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb   Part No SW: 8K0 907 064 DQ    HW: 8K0 907 064 DQ
  Revision: 00002001
  Coding: 072200
4 Faults Found
            Freeze Frame:
                   Fault Priority: 2
                   Fault Frequency: 31
                   Reset counter: 210
                   Mileage: 176523 km
                   Time Indication: 0
                   Date: 2013.10.11
                   Time: 14:13:12
            Freeze Frame:
                   Fault Priority: 2
                   Fault Frequency: 7
                   Reset counter: 173
                   Mileage: 177212 km
                   Time Indication: 0
                   Date: 2013.11.12
                   Time: 11:37:13
            Freeze Frame:
                   Fault Priority: 2
                   Fault Frequency: 2
                   Reset counter: 210
                   Mileage: 176488 km
                   Time Indication: 0
                   Date: 2013.10.06
                   Time: 19:56:33
00955 - Key 1
            Freeze Frame:
                   Fault Priority: 3
                   Fault Frequency: 1
                   Reset counter: 213
                   Mileage: 177212 km
                   Time Indication: 0
                   Date: 2013.11.21
                   Time: 11:56:38
Tak patrzę na ten błąd, i nie wiem, czy ten numer jest gdzieś tu zawarty?
---------- Post dopisany at 19:35 ---------- Poprzedni post napisany at 19:30 ----------
Znalazłem taki temat;
http://a4-klub.pl/audi-a4-b8-127/czujnik-klamki-drzwi-a4-b8-285603/
a w nim informacje z numerem: 4g8927753
U mnie będzie ten sam numer, czy to po VINie trzeba sprawdzić?
M29 to zarowka swiatła mijania :wink: zapal swiatła i sprawdz
Swiatla swieca, mam bixa, mijania i dlugie normalnie swieca. Ale wystapil mi ten blad przepalenia zarowki, ale jak wylaczylem i wlaczylem zaplon, to blad zniknal
