Prośba o analizę logów Seat Ibiza
Witam kolegów,
Koleżanka podjechała dzisiaj do mnie, żeby przeskanował jej auto, bo ma jakiś problem z ABS/ESP
Takie błędy wyszły:
Wednesday,05,February,2014,14:23:04:46862VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ5R052339   Mileage: 63650km/39550miles
Address 01: Engine        Labels: 036-906-034-APE.lbl
  Part No: 036 906 034 DG
  Component:  MARELLI 4MV        5953
  Coding: 00071
  Shop #: WSC 06402
  VCID: 5AB09036AA456FCC
  VSSZZZ6LZ5R052339     SEZ7Z0D2638268
1 Fault Found
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
           P0118 - 35-10 -  -  - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS.lbl
  Part No SW: 6Q0 907 379 R    HW: 6Q0 907 379 R
  Component: ABS 8.0 front   H03 0001
  Coding: 0000005
  Shop #: WSC 06403 785 00200
  VCID: 4C9C666E1091017C
1 Fault Found
16347 - Control Module - EEPROM Error
           014 - Defective
Address 08: Auto HVAC        Labels: None
  Part No: 6L0 820 043 B
  Component: CLIMAtronic PQ24    0201
  Shop #: WSC 00000 000 00000
  VCID: 254AF3CAD3BB1034
2 Faults Found
01271 - Positioning Motor for Temperature Flap (V68)
           000 -  -  - Intermittent
00457 - Control Module for Network (J519)
           013 - Check DTC Memory
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
  Part No: 6Q1 937 049 D
  Component: 0000 BN-SG.         1S34
  Coding: 16524
  Shop #: WSC 06402
  VCID: 3C7C36AE4031B1FC
1 Fault Found
01598 - Drive Battery Voltage
           07-10 - Signal too Low - Intermittent
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
  Part No: 6Q0 909 605 AD
  Component: 03 AIRBAG VW5       0010
  Coding: 12339
  Shop #: WSC 06401
  VCID: 79F2EFBA0F8344D4
1 Fault Found
00532 - Supply Voltage B+
Address 17: Instruments        Labels: 6L0-920-xx0-17.lbl
  Part No: 6L0 920 820 H
  Component: KOMBI+WEGFAHRSP VDO V13
  Coding: 00145
  Shop #: WSC 00000
  VCID: 2F6611E281475A64
1 Fault Found
00779 - Outside Air Temp Sensor (G17)
           30-00 - Open or Short to Plus
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
  Part No: 6N0 909 901
  Component: 0061 GATEWAY CAN    1S34
  Coding: 00014
  Shop #: WSC 06402
  VCID: F0E4529EDCF9859C
No fault code found.
Address 44: Steering Assist        Labels: 6Q0-423-156.lbl
  Part No: 6Q0 423 156 AB
  Component: LenkhilfeTRW        V270
  Coding: 10121
  Shop #: WSC 06402
  VCID: 6FE6D1E241C71A64
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
  Part No: 6Q0 959 433 E
  Component: JA Komfortgerát     0002
  Coding: 00258
  Shop #: WSC 06402
  VCID: 3D7A3BAA5B2BB8F4
  Part No: 6Q2959802C
  Component: JA Tőrsteuer.FS KLO 0202
  Part No: 6Q2959801C
  Component: JA Tőrsteuer.BF KLO 0202
  Part No: 6Q0959811A
  Component: JA Tőrsteuer.HL KLO 0203
  Part No: 6Q0959812A
  Component: JA Tőrsteuer.HR KLO 0203
1 Fault Found
00928 - Locking Module for Central Locking; Front Driver Side (F220)
           27-10 - Implausible Signal - Intermittent
End   ---------------------------------------------------------------------
Głównie chodzi mi o ten błąd:
  Coding: 0000005
1 Fault Found
           014 - Defective
Z góry dzięki za pomoc
Cos nie halo z softem w sterowniku ABS... albo z samym sterownikiem
