specyfikacja samochodu
Witam, jak w temacie. Czy po specyfikacji samochodu mozna odczytac czy ma podgrzewane lusterka ?
Dane samochodu
Marka: A Kod kraju: BEL
Rok modelowy: 2001 Opis: A4 Sal. TDI1.9 I4 96 M5S Region: 202
Typ handlowy: 8E20N4 Data produkcji: 2001-03-13 Nr partnera: 01503
MKB: AWX Data wydania samochodu: 2001-04-02 Leasing:
GKB: FEC Nr homologacji typu:
Kolor wyposażenia
Typ Kod barwny Nr lakieru (nr KD lakieru) Opis
z zewnątrz (nadwozie/dach) F5/F5 LX7Z Dolphin Grey, metallic/Dolphin Grey, metallic
wewnątrz LA black/black/black-black/light grey
Numery PR
Nr Pochodzenie Grupa Opis
0CS L AED
vehicle class
differentiation 8E0
0F3 L KRS
fuel system for diesel
engine
0G1 L GES gearshift lever
0GE L AGM
emissions concept EU
3
0JH L GKV
weight category front
axle weight range 8
0LU L SIZ
special plates/stickers/
safety certificates for
Belgium
0ST L SAU
labels/plates in
German and French
0TD L ZFM
front and rear floor
mats
0VH E BTA
information kit in
Dutch
0W1 L AKZ
label for central
electric Germanspeaking
countries
0YH L GKH
weight category rear
axle weight range 8
1BA L DAE
standard
suspension/shock
absorption
1C1 L FRO
antifreeze up to -25
degree celsius
tolerance up to -30
degree C
1D0 L AHV
without towing
1EX L TYP
special identification
plate for EC
1G3 E RER
alloy spare wheel with
original equipment
tires
1KD L BAH disc brakes, rear
1LB L BAV disc brakes, front
1N1 L LEN power steering
1PA L ABR standard wheel bolts
1S7 L BOW
tool kit and aluminum
jack
1SA L TWU
without additional
engine guard
1T3 L VBK
First aid kit with
warning triangle
1VG L TWL
installation parts for
four-cylinder engine
1W0 L KBX
without
refrigerator/glove
compartment cooling
system
Numery PR
1WG L GFW
transmission shaft w/
88mm in diameter
1X0 L ATA front wheel drive
1YA L GFH
without transmission
shafts f. rear axle
1Z1 L KRM
increase in initial
standard fuel filling by
4 liters
2A5 L UEA
delivery equipment
(transit coating) with
thin seat cover
2G0 L EBB
without insert for the
filling up of fuel
2K1 L SFS reinforced bumpers
2PG L LRA steering wheel
2T0 L DAT
without double-sized
standard (DIN)
2V1 L FRI dust and pollen filter
2WA L ZBR without additional tires
2Z0 E TYZ
deletion of model
designation
3B0 L ZKV
without additional
child seat anchor
3C1 L SHM
static lap belt, center
rear
3CA L TRW without partition
3FA L DEI
without roof insert
(standard roof)
3L1 L SIE
manual height
adjustment for left
front seat
3NZ E HIS
rear seat bench unsplit,
backrest split folding
3Q1 L KOH rear headrests
3S0 L DAR
without roof rails/roof
load rack
3X0 L DLS
without load-through
provision
3Y0 L SSR
without roll-up sun
screen
4E0 L SDH
tailgate/trunk lid
unlocking from
outside
4A0 L SIH without seat heater
4GH L WSS
windshield tinted with
windshield sunshield
4K4 L TKV
radio remote
controlled central
locking operated from
inside and separate
trunk release
4KC L SSH
side and rear windows
tinted
4L2 L IRS
dipping breakaway
inside rear view mirror
4N0 L INT standard dashboard
4P2 L PBH
rear floor panel
module, type 3
4R5 L FEH
power windows with
comfort operation
andcircuit breaker,
mechanical window
regulators rear
4UE L AIB
airbag f. driver a. front
seat passenger
Numery PR
4W0 L KBO
without cassette and
CD storage unit
4X3 L SAB
side airbag front with
curtain airbag
4ZE L ZIE black moldings
5C0 L KSA
without special body
measures
5D1 L TRF
carrier frequency
433.92 MHz
5K1 L LAC
paint preservative
(wax)
5MA L EIH decorative inserts
5RU L ASR
outer right rear view
mirror: convex (large
viewing field)
5SL L ASL
outer left rear view
mirror: non-spherical
6M0 L GPS
without tie down
straps/luggage net
6PA L HBV
plastic hand brake
lever handle
6Q1 L SAG
plastic gearshift
knob/handle
6R1 L SHV
leatherette gearshift
boot
6SS L KBB
luggage compartment
floor covering
6U0 L ZTD
without additional
seals outside
6V1 L HEB rear trim panel (ECE)
6W5 L KZV
front license plate
bracket
6XC L ASE
outer rear view
mirrors: powered
7A0 L CDW
without CD
changer/CD player
7AL E EDW
anti-theft alarm
system, passenger
compartment control,
backup horn and
towing protection
7B0 L STD without socket
7CA L AKF
without label for radio
remote control
7K0 L RDK
without tire pressure
warning light
7M0 L EIL
plastic scuff plates in
door apertures
7P0 L LOR
without lumbar
support in front and
rear seats
7Q0 L NAV
without navigation
device
7QA L CDR without CD ROM
7X0 L EPH
without park distance
control
8GU L GEN alternator 140A
8JH L HSW
ellipsoidal headlight
for driving on the right
8K0 L FLS
without special low
beam mode
8KA L KUE
w/o catalytic converter
warning light
8N4 L SWS
windshield wiper
intermittent control
Numery PR
with potentiometer
(four speeds)
8Q1 L LWR
headlight-range
adjustment
8RX E LSE passive speakers
8T0 L GRA
without cruise control
system (CCS)
8TC L NEL
rear fog light for
8X0 L SWR
without headlight
washer system
8YU L RAO
radio preparation for
commercial goods
8Z5 L MKU
engine cooling system,
type 1
9AK L HKA
"Climatronic" with
impact pressure
control free of cfc
9M0 L ZUH
without
auxiliary/parking
heater
9NX L FAS
without electronic
logbook
9P0 L SGK
without seat belt
warning light
9Q3 L MFA
multi-function
indicator, without onboard
computer and
check control
9T0 L BWD
without heated washer
nozzles
9W0 L VTV
w/o car phone
preparation/installation
6E3 E MAS center armrest front
A00 L SAH no self-collection
A8S I AUS standard equipment
B0A L BLB
component parts set
without countryspecific
design
requirement
B99 L TPL type approval EC
C01 E COC
operating permit,
alteration 1
C1W L RAD
forged alloy wheels 7J
x 15 type 1, offset 39
D3E L MOT
4-cyl. turbo diesel
engine 1.9 L/96 kW
TDI with pump-jet
injection system, EU
3base engine is T9J
E0A L AAU no special edition
F0A L FZS
no special purpose
vehicle, standard
equipment
FA0 L SVO
control of standard
production
FC0 L IND
without customized
installation
FM0 L MDS
basic equipment
variant
G0C I GSP
5-speed manual
transmission
H6S L REI tires 195/65 R 15 V
J0R L BAT battery 380 A (80 Ah)
K8B I KAR notchback
L0L L LEA left-hand drive vehicle
Numery PR
N3A L SIB fabric seat covering
Q1A L VOS standard front seats
QE0 L ALG
without tray areas
package/box
QH0 L SPR without voice control
QQ0 L LCP
without add. lights
(interior lighting)
QV0 L TVE
w/o TV
reception/digital radio
reception
SA3 E SNR
Control number for inhouse
control of
assembly
T9J I GMO
4-cylinder diesel
engine 1.9 L unit
038.K
U1A L INS
instrument insert with
km/h
speedometer,clock,
tachometer and trip
odometer
V0A L REL
tires w/o specification
of tire brand
VB0 L ADR
without automatic
distance control
VC0 L GRT
w/o remote-controlled
garage door opener
VR0 L RAM
without impact
protection measures
X2A G
national sales program
Belgium
Tak można, ja mam podgrzewane a kod mam 6XD.
ja mam tylko 6XC a mozna jakos samemu zalozyc
A jesteś pewny że nie masz? Jeśli nie to zobacz jaką masz instalacje w lustrach. Możliwe że kable są tylko trzeba włożyć grzane szkła.
gdy wlacze szybe to lusterka nie grzeja. w sobote wyjme jeden wklad i zobcze czy sa jakies wolne kable
dziekie wielkie kupie w srode jeden wklad i sprawdze wszystko
Fajna strona jest na necie, wpisujesz wszystkie kody jakie masz na naklejce w książce serwisowej klikasz tłumacz i za chwile już wiesz co jaki kod oznacza (polecam) :wink:
