Proszę o analizę błędów A4B6
Cześć!
Proszę o analizę błędów, autko kupiłem dwa miesiące temu i dopiero je poznaję. Co do "usterek" nie działa oświetlenie drzwi tył prawa strona, oraz bardzo sporadycznie zapala się ESP - po zgaszeniu i odpaleniu wszystko jest ok.
Pozdrawiam i dziękuje
VAG-COM Version: Release 303.1
Chassis Type: 8E - B6 Audi A4
Scan: 01,02,03,08,09,15,16,17,36,37,45,46,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 JQ
Component: G000SG 1570
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E03A154088 AUZ6Z0B0213847
0 Faults Found:
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 00000
1 Faults Found:
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 H
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
0 Faults Found:
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
0 Faults Found:
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 02042
Shop #: WSC 00000
1 Faults Found:
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
Address 17 -------------------------------------------------------
Controller: 8E0 920 900 K
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 02010
Shop #: WSC 00000
1 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BC
Component: Komfortgerát T3B 1110
Coding: 08010
Shop #: WSC 63351
5 Faults Found:
01134 - Alarm Horn (H12)
49-00 - No Communications
01616 - Signal Wire to Interior Monitor
01403 - Glass-Break Sensors: Rear
01561 - Left Rear Door
61-00 - Won't De-Safe
01562 - Right Rear Door
End -------------------------------------------------------
No co. Cofnięty licznik i uszkodzony włącznik stopu.
Cofnięty licznik?? uszkodzony czujnik stopu niby ok - tylko, że sprawdzam stop co jakiś czas i wszystko działa. Od dłuższego czasu nie załączyła mi się kontrolka ESP bo sprawdził bym w tym momencie.
