Prośba o analizę, opis błędów
Witam,
podczas jazdy nie odczuwam nic wielce niepokojącego jednak na VAG wyskoczyły błędy. Proszę o pomoc i wytlumaczenie:
Chassis Type: 8E (8E - Audi A4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E54A010294 Mileage: 256490km/159375miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JT
Component: 1,9l R4 EDC G000SG 1572
Coding: 00002
Shop #: WSC 63251
VCID: 72EB3C433E5AFA8E927-4A3A
WAUZZZ8E54A010294 AUZ6Z0C0124691
1 Fault Found:
17994 - Engine Mount Solenoid Valves (N144/N145)
P1586 - 35-10 - Short to Plus - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04255
Shop #: WSC 06435
VCID: E5C1D71F7F949D36875-5000
1 Fault Found:
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
VCID: 6DD12F3F276425764F5-5072
2 Faults Found:
01172 - Temperature Sensor; Driver's Heated Seat (G59)
30-00 - Open or Short to Plus
01171 - Temperature Sensor; Passenger Side Heated Seat (G60)
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63251
VCID: 3467FA5B04CEB4BE40B-4A3A
No fault code found.
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 3000
Coding: 0010602
Shop #: WSC 63251 000 00000
VCID: 3663C05342B2A6AE7EF-5000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 00042
Shop #: WSC 63251
VCID: 3E73D8733A826EEEA6F-4A9C
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 K
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 00100
Shop #: WSC 00922
VCID: 2C57E23BDCFEEC7E18B-5072
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
VCID: EBD5A1279970AB46D11-5072
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BD
Component: Komfortgerát TBF 1411
Coding: 06986
Shop #: WSC 63251
VCID: 74E73A5B444EF4BE80B-4A3A
Subsystem 1 - Part No: 8E1959801B
Component: Tőrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802B
Component: Tőrsteuer.BF BRM 0003
8 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01561 - Rear Left Door
61-10 - Won't De-Safe - Intermittent
01332 - Door Control Module; Passenger Side (J387)
80-00 - Single-Wire Operation
End ---------------------------------------------------------------------
silnik - chyba elektroniczna poduszka silnika nawala
hamulce - sprawdź czy sie światło stop zapala - bo jakiś błąd czujnika
siedzenia - czujniki temp podgrzewania coś nawalają - hmm trzeba pewnie zerknąć pod fotel, bo może coś sie wypieło
lewe tylnie drzwi - jeżeli błąd jest dalej to wiązka między słupkiem a drzwiami do sprawdzenia - dodatkowa blokada zamka/ryglowanie
i to samo przednie prawe - błędy łączności CAN
dziękuję! :hi: podgrzewane siedzenia mnie nie dziwią bo akurat mam odpięte, gorzej z resztą...
