Proszę o analizę logów 1.9 TDI AFN
Proszę o analize logów 003 i 011
http://vaglog.pl/log_229125.html
http://vaglog.pl/log_229124.html
oraz jeśli można to
VAG-COM Version: Release 311.2-N
1o9lo0m-n6r12p-o9ko4x-kkjahh-568f
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 AH
Component: 1,9l R4 EDC G300SG 2827
Coding: 00002
Shop #: WSC 00081
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
Address 08 -------------------------------------------------------
Controller: 8 ö8 D0 ö
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 900 H
Component: KOMBI+WEGFAHRS. M73 D16
Coding: 00140
Shop #: WSC 02801
Ident.-Nr. Wegfahrs.:AUZ5Z0Y8224284
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D12
Coding: 13163
Shop #: WSC 00081
6 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06325
End -------------------------------------------------------
Auto czasami przyspiesza tak jak powinno a czasami jest mułem. Z góry dziękuje za pomoc :)
Przepływomierz nie domaga ale zdało by sie zlogować jeszcze gr 8 dynamiczne dla potwierdzenia.Podmień przepływkę jak masz od kogoś i ponownie zloguj
Po za tym nie ten dział do wrzucenia logów
Postaram się zlogować gr nr 8 a z przepływką będzie cieżko bo nie mam od kogo podmienić :mellow:
Jestem nowy na forum, zastanawiałem się własnie do którego działu wrzucić ten post bo widziałem pytania o logi tutaj jak i tam z tym że tutaj jest większe prawdopodobieństwo że mi ktoś pomoże :)
