[B5 ADP] dziwne kody bledow... o co tu chodzi??
Witam dzis wpadl do mnie kole i przyniusl zlacze VAG podpielismy moje autko i wyskoczyly dziwne bledy, usunelismy je i przejechalem sie autkiem po czym znow podpielismy auto i bledy juz nie wyskoczyly :blink:... szukalem co one oznaczaja i znalazlem ale nie kumam tego :shocked: ....
oto co mi wyskoczylo na kompie po podpieciu auta:
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 557 B
Component: 1,6L R4/2V MOTR HS D08
Coding: 04001
Shop #: WSC 00000
8 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17736 - Knock-Control: Cylinder 4: Regulation Limit Exceeded
P1328 - 35-10 - - - Intermittent
17733 - Knock-Control: Cylinder 1: Regulation Limit Exceeded
P1325 - 35-10 - - - Intermittent
17735 - Knock-Control: Cylinder 3: Regulation Limit Exceeded
P1327 - 35-10 - - - Intermittent
17734 - Knock-Control: Cylinder 2: Regulation Limit Exceeded
P1326 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16507 - Throttle Position Sensor (G69): Signal too High
P0123 - 35-10 - - - Intermittent
16711 - Knock Sensor 1 (G61): Signal too Low
P0327 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 D
Component: ABS BOSCH 5 7402
Coding: 0265108005
Shop #: BB 37402
No fault code found.
Address 15 -------------------------------------------------------
Controller: 8A0 959 655 C
Component: Airbag V AUDI D00
Coding: 01022
Shop #: WSC 06334
1 Fault Found:
00595 - Crash Data Stored
35-00 - -
Address 17 -------------------------------------------------------
Controller: 8D0 919 033 C
Component: B5_KOMBIINSTRUMENT D07
Coding: 00142
Shop #: WSC 03075
Address 25 -------------------------------------------------------
Controller: 4A0 953 234
Component: IMMO AUZ9Z0T2690424 D77
Coding: 00000
Shop #: WSC 27821
End -------------------------------------------------------
moze ktos mi powiedziec o co tu chodzi bo ja tego nie kumam..:(
  • 8 miesięcy temu...
widac ze auto po strzale i nie dokladnie poskladane :wallbash:
