devey Opublikowano 17 Lutego 2016 Opublikowano 17 Lutego 2016 (edytowane) Witam, Odświeżam temat, tym razem z pełnym skanem błędów oraz uściślającym opisem. Może ktoś coś? VAG-COM Version: Release 311.2-NChassis Type: 8E - Audi A4 B6Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76Address 01 ------------------------------------------------------- Controller: 038 906 019 CG Component: 1,9l R4 EDC G000SG 1366 Coding: 00002 Shop #: WSC 63351 WAUZZZ8EZ1A067394 AUZ6Z0A00903542 Faults Found:17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus P1586 - 35-10 - - - Intermittent18071 - Control Circuit for PD Injectors: Short to Plus P1663 - 35-00 - -Readiness: N/AAddress 03 ------------------------------------------------------- Controller: 8E0 614 517 Component: ABS/ESP front D1320 Coding: 04255 Shop #: WSC 767083 Faults Found:18265 - Load Signal: Error Message from ECU P1857 - 35-10 - - - Intermittent01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30 35-10 - - - Intermittent01206 - Signal for Duration of Ignition: OFF 27-10 - Implausible Signal - IntermittentAddress 08 ------------------------------------------------------- Controller: 8E0 820 043 A Component: A4 Klimaautomat 0708 Coding: 00000 Shop #: WSC 63351No fault code found.Address 09 ------------------------------------------------------- Controller: 8E0 907 279 B Component: int. Lastmodul RDW 1412 Coding: 00001 Shop #: WSC 63351No fault code found.Address 15 ------------------------------------------------------- Controller: 8E0 959 655 Component: Airbag 8.4E 5001 Coding: 0010602 Shop #: WSC 767081 Fault Found:01222 - Crash Sensor Side Airbag: Passenger Side (G180) 011 - Open Circuit - IntermittentAddress 16 ------------------------------------------------------- Controller: 8E0 953 549 J Component: Lenksáulenmodul 0204 Coding: 00041 Shop #: WSC 63351No fault code found.Address 17 ------------------------------------------------------- Controller: 8E0 920 900 E Component: KOMBI+WEGFAHRS. RB4 D13 Coding: 00000 Shop #: WSC 00001 WAUZZZ8EZ1A067394 AUZ6Z0A00903541 Fault Found:01304 - Radio 49-00 - No CommunicationsAddress 46 ------------------------------------------------------- Controller: 8E0 959 433 J Component: Komfortgerát T85 0112 Coding: 06720 Shop #: WSC 633513 Faults Found:01811 - Supply Voltage for Door Controller: Drivers Side (J386) 37-00 - Faulty01331 - Door Control Module: Driver Side (J386) 80-00 - Single-Wire Operation01560 - Passenger Door 61-10 - Won't De-Safe - IntermittentAddress 76 ------------------------------------------------------- Controller: 8Z0 919 283 A Component: Parkingsyst. A4 RDW D06 Coding: 00104 Shop #: WSC 63351No fault code found.End ------------------------------------------------------- Jak pisałem wcześniej, problem polega na tym, że losowo zapala mi się kontrolka ESp a chwilę później gaśnie silnik... Zauważyłem, że w tym czasie nie ma przerwy w działaniu kontrolek na desce (nie gasną), nie przerywa działania nawiewu, światła też nie gasną... Problem występuje losowo, czasami 20 razy w ciągu 30 min, czasami raz w miesiącu... Edytowane 17 Lutego 2016 przez devey
Dev Opublikowano 17 Lutego 2016 Opublikowano 17 Lutego 2016 Sprawdz wszystkie przekazniki, jeden z nich bedzie nieprawidlowo docisniety.
devey Opublikowano 20 Lutego 2016 Autor Opublikowano 20 Lutego 2016 (edytowane) Zrobiłem jak zaleciłeś Dev. Dodatkowo poczyściłem benzyną ekstrakcyjna bo były zaśniedziałe. Po akcji świeci się cały czas ESP i pokazuje błąd 01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30 35-10 - - - Intermittent ale to pewnie dlatego, że na czas czyszczenia odłączyłem akumulator. Czytałem, że ten błąd powinien sam zniknąć po wykonaniu 'jazdy testowej' lub można zrobić kalibrację komputerem. Pytanie czy czekać, aż sam zniknie (ile trzeba przejechać aż sie zaadoptuje?) czy kalibrować wg instrukcji z internetów? Edit: Przechwaliłem dzień przed zachodem słońca...Przejechałem dziś ok 300 km i było dobrze. Później na odcinku ok 1km sytuacja się powtórzyła z 5 razy ;/ Z czego 3 razy zgasł na światłach, raz w czasie jazdy i raz nie zgasł... Edytowane 20 Lutego 2016 przez devey
