Kody błędów
Witam mam kilka błędów w swoim audiku i nie wiem od czego one są ktoś pomoże ?
16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90304HEI00058
Coding: 000015
Shop #: WSC 06335 000 00000
VCID: 3D71DF7FA48475F6BF5-8068
Component: E221 - MFL H02 0003
No fault code found.
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 900 C HW: 8K0 920 900 C
Component: KOMBIINSTR. H15 0221
Revision: 00200000 Serial number: 7VL250H58
Coding: 0F01100002000008000000
Shop #: WSC 06335 123 12345
VCID: 2A5BE423450AF24EEA7-807F
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G0842281FE
Coding: 000303
VCID: 4683B093F152362EEEF-8013
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 39
Reset counter: 72
Mileage: 220426 km
Time Indication: 0
Date: 2015.11.27
Time: 13:50:00
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007183796
Coding: 011C02204100410001
VCID: 3F8DA577AE8867E6AD9-806A
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Part No SW: 8K0 907 064 M HW: 8K0 907 064 M
Component: BCM2 1.1 H70 0134
Revision: 00002001 Serial number: 0111817350
Coding: 0100062020390040032002
VCID: 3A7BD463B5AA42CE9A7-806F
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007186531
VCID: 3E73D873A9826EEEA6F-806B
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 112
Reset counter: 89
Mileage: 220540 km
Time Indication: 0
Date: 2015.11.29
Time: 00:13:01
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 00000000131815
Shop #: WSC 00000 000 00000
VCID: 306FF64B63D6889E243-8065
Address 55: Xenon Range
Cannot be rea che
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 C HW: 8T1 035 186 C
Component: Concert3 H01 0210
Revision: 00000003 Serial number: AUZ5Z6H1063502
Coding: 050004800402050D811B070002
VCID: 377DCD5786B85FA6659-8062
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
2 Faults Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 102
Mileage: 219026 km
Time Indication: 0
Date: 2015.11.13
Time: 12:48:33
03157 - Functionality limited due to Communications Disruption
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 89
Mileage: 225629 km
Time Indication: 0
Date: 2016.01.17
Time: 14:27:27
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000001
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007199987
Coding: 010C02204000210001
VCID: FF0D65776E0827E66D9-80AA
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 A HW: 8K0 907 383 A
Component: Anhaenger H06 0040
Revision: 1A001001 Serial number: 00000110899472
Coding: 0100000000000000
VCID: 326BFC436DDABA8E527-8067
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007206270
VCID: FEF3987369022EEE66F-80AB
End ---------------------------------------------------------------------
Były kasowane ale znowu to samo
Akumulator cos słaby jest :wink: spradz w GATEWAY i bloki pomiarowe 18 ,19,20
sprawdz wtyke AUXA w podłokietniku
  • 4 lata później...
Witam. Po scanie wyszedł mi błąd 02095 błąd ochrony komponentu. Po skasowaniu jak narazie się nie pokazał, ale pojawił się nowy który po skasowaniu pojawia się ponownie od razu 03138 Input Aux In 011 Open Circuit. Ktoś miał z tym problem?
Podepnę się bo mam ten sam błąd. Aux jest podpięty pod mmi więc nie wiem dlaczego opis błędu to otwarty obieg. Aux mi nie działa. Zastanawiam się czy mmi nie jest uszkodzona.
  • 7 miesięcy temu...
Ja nie mam mmi i mam ten sam błąd w AUX, ktoś go rozwiązał?
