A6 C5 1.9TDI bledy po swapie silnika
WItam.
Jakis czas temu w A6 C5 przelozylem silnik i skrzyni auto na manual z AKN na AFN ze sterowaniem ECU z AVG i mam pare bledow ktorych nie moge sie pozbyc. Z tego co wywnioskowalem to walniety jest czujnik poziomu oleju w misce i prawy czujnik PDC ale nie wiem co z reszta bledow. Dodam ze ASR ciagle swieci na zegarach. Z gory dzieki i pozdrawiam.
VAG-COM Version: Release  311.2-N
Control Module Part Number: 4B0 919 283   P
  Component and/or Version: parkingsystem A6 RDW D18
           Software Coding: 01116
            Work Shop Code: WSC 02325
1 Fault Found:
01548 - Sensor for Parking Aid: Rear Right (G206)
        30-00 - Open or Short to B+
Control Module Part Number: 4B0 920 932 K
  Component and/or Version: C5-KOMBIINSTR. VDO D12
           Software Coding: 00060
            Work Shop Code: WSC 00186
           Additional Info: WAUZZZ4BZ1N069838     AUZ7Z0Y1621691
3 Faults Found:
01177 - Engine Control Unit
        49-00 - No Communications
01314 - Engine Control Module
        49-10 - No Communications - Intermittent
00562 - Sensor for Oil Level/Temperature (G266)
Control Module Part Number: 038 906 012 BT
  Component and/or Version: 1,9l R4 EDC 0000SG  2805
           Software Coding: 00002
            Work Shop Code: WSC 06335
3 Faults Found:
19561 - Valve for Intake Manifold Flap (N239): Open or Short to Ground
        P3105 - 35-10 - - - Intermittent
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
        P1636 - 35-10 - - - Intermittent
16955 - Brake Switch (F): Implausible Signal
        P0571 - 35-00 - -
Control Module Part Number: 3B0 614 111
  Component and/or Version: ABS/ASR 5.3 FRONT   D00
           Software Coding: 00012
1 Fault Found:
18257 - Please check DTC Memory of Transmission Controller
        P1849 - 35-00 - -
Control Module Part Number: 4B0 927 156 DK
  Component and/or Version: AG5 01V 2.5lTDI RdW 3132
           Software Coding: 00003
            Work Shop Code: WSC 00000
5 Faults Found:
18249 - Engine Control Module / Transmission Control Module Incompatible
        P1841 - 35-00 - -
18155 - Transmission Solenoid Power Relay: Open or Short to Ground
        P1747 - 35-00 - -
18258 - Powertrain Data Bus: Missing Message from ECU
        P1850 - 35-10 - - - Intermittent
17090 - Transmission Range Sensor (F125): Implausible Signal
        P0706 - 35-00 - -
18158 - Supply Voltage too Low
        P1750 - 35-00 - -
Dnia 15.03.2017 o 17:16, dani270 napisał:
WItam.
1 Fault Found:
3 Faults Found:
3 Faults Found:
        P0571 - 35-00 - -
1 Fault Found:
        P1849 - 35-00 - -
5 Faults Found:
        P1841 - 35-00 - -
        P1747 - 35-00 - -
        P0706 - 35-00 - -
        P1750 - 35-00 - -
Po pierwsze to odepnij kompa od skrzyni automatycznej bo już ci nie jest potrzebny, potem vagiem przekoduj sterownik abs na manual i 4 cylindry tak samo licznik wtedy jeszcze raz zrób skan, czujnik parkowania nie ma nic do tego swapa
