1.8T avj+ ,prośba o ocene logów
Witam, prosze o ocene logów AVJ po lekkich modach.
002 + 033
032
003+020
115+118
2 Znalezione:
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
            P0301 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03     -------------------------------------------------------
   Controller: 8E0 614 517 A
   Component: ABS/ESP allrad      D620
   Coding: 04275
   Shop #: WSC 00638
Nie ma błędów :) .
Address 08     -------------------------------------------------------
   Controller: 8E0 820 043 A
   Component:   A4 Klimaautomat   1012
   Coding: 00000
   Shop #: WSC 63351
3 Znalezione:
01172 - Temperature Sensor: Driver's Heated Seat (G59)
            30-00 - Open or Short to B+
01171 - Temperature Sensor: Passenger Side Heated Seat (G60)
01794 - Control Module Incorrect Chassis (VIN) Number
            35-00 - -
Address 09     -------------------------------------------------------
   Controller: 8E0 907 279 E
   Component: int. Lastmodul  RDW 0305
   Coding: 00001
   Shop #: WSC 00000
2 Znalezione:
01494 - Bulb for Parking Lamps: Left (M1)
            57-00 - Electric Circuit Failure
00985 - Right Tail Light (M2)
Skipping Address 15-Airbags
Address 16     -------------------------------------------------------
   Controller: 8E0 953 549 N
   Component: Lenksáulenmodul     0911
   Coding: 01042
   Shop #: WSC 00638
Nie ma błędów :) .
Address 17     -------------------------------------------------------
   Controller: 8E0 920 900 F
   Component: KOMBI+WEGFAHRS. RB4 D10
   Coding: 01170
   Shop #: WSC 00000
   WAUZZZ8EZ1A018624     AUZ6Z0Y0039210
Nie ma błędów :) .
Address 46     -------------------------------------------------------
   Controller: 8E0 959 433 L
   Component: Komfortgerát T03    0112
   Coding: 06720
   Shop #: WSC 63351
1 Błąd Zapis.:
01559 - Drivers Door
            61-00 - Won't De-Safe
Address 55     -------------------------------------------------------
   Controller: 4B0 907 357 C
   Component: dynamische LWR       D05
   Coding: 00060
   Shop #: WSC 63351
Nie ma błędów :) .
End   -------------------------------------------------------
Edytowane przez Tamek141
ktoś coś ?
Witam, samochód jest po programie. Turbo trochę późno wstaję - chyba,że po programie jest tak ok. Dodatkowo kiedy świece był wymieniane ?
Podejrzewam że logi zrobiono bez kasowania błedów.  Grupa 032 jest po dłuższej jeździe na LPG, pozostałe logi były robione na Pb. Jeśli tak było to LPG jest do lekkiego podregulowania.
Oczywiście program robiony, auto nieoficjalnie ma moc ~210/220ps
Auto jeżdżone na ten moment tylko Pb98 bo gaz po prostu nie działa, dziś stoi u gazownika do przeróbek który poinformował mnie że padł sterownik i du*a. Bede jeździł dalej na 98 dopóki nie załatwi sterownika.
Kiedy świece nie wiem, mam go od miesiąca, spróbuje sie dowiedzieć choć sprzedający nic o świecach nie wspominał że były wymieniane, stąd może być błąd 1cyl?
Racja, nie skasowałem błędów wgl wyleciało mi to z głowy(1 raz to robiłem) :) Pozdrawiam
Wątpię że to auto ma 190km sądząc po przepływie.
Na poprzedniej turbinie wydmuchało 196 na nowej nie hamowane. Czyli coś z przepływką nie tak ?
Dowiem sie od was coś więcej ? :))
A co chcesz wiedzieć więcej? Zrób log 002+033 kasując wcześniej błędy. Na Pb.
Udało sie coś takiego: 25564667_695894553947605_1725644809_n.pn
Fajne.
Na jakim turbo? No i przepływ na pewno jest większy:)
K03/k04 jeszcze z zapasem :) zdecydowanie ;)
