Kontrolka świec żarowych - Audi A4 B5 1.9 TDI (AFN) Avant 1997r. (Quattro)
Chwilę po uruchomieniu silnika zaczyna mrugać kontrolka świec żarowych i tak mruga cały czas. Silnik pracuje normalnie, przyspiesza itp. ...
Pożyczyłem kabelek, załączam logi. Pomoże mi ktoś je ogarnąć?
Mileage: 114670km-71252mi   Repair Order:
Chassis Type: 8D - Audi A4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
   Mileage: 114670km/71252miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 028 906 021 GL
   Component: 1,9l R4 EDC  G00SG  1415
   Coding: 00003
   Shop #: WSC 06325
   VCID: 5FCD45F7DDC847E6CD9-4A9C
3 Faults Found:
00575 - Intake Manifold Pressure
            17-10 - Control Difference - Intermittent
00519 - Intake Manifold Pressure Sensor (G71)
            28-00 - Short to Plus
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-00 -
Readiness: N/A
Address 03: ABS Brakes        Labels: 8E0-614-111-EDS.lbl
   Part No: 8E0 614 111 M
   Component: ABS/EDS 5.3 QUATTRO D11
   Shop #: BB 24302
   VCID: 285F1E2BC806C05EFC3-5072
No fault code found.
Address 08: Auto HVAC        Labels: 8L0-820-043-2D.lbl
   Part No: 8L0 820 043 B
   Component: A4 KLIMAVOLLAUTOMAT_D73
   Coding: 04143
   Shop #: WSC 06325
   VCID: 275D1D17C518CF26F59-2598
5 Faults Found:
00779 - Outside Air Temp Sensor (G17)
            30-00 - Open or Short to Plus
00603 - Footwell/defroster Flap Positioning Motor (V85)
            41-10 - Blocked or No Voltage - Intermittent
00792 - A/C Pressure Switch (F129)
            31-00 - Open or Short to Ground
01273 - Fresh Air Blower (V2)
01206 - Signal for Duration of Ignition Off Time
            27-10 - Implausible Signal - Intermittent
Address 15: Airbags        Labels: 8D0-959-655-AI7.lbl
   Part No: 8D0 959 655 C
   Component: Airbag 7 Audi      DE2
   Coding: 00102
   Shop #: WSC 64327
   VCID: 3663C05312B2A6AE7EF-5000
9 Faults Found:
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
65535 - Internal Control Module Memory Error
            00-10 - - - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
            32-10 - Resistance Too High - Intermittent
01221 - Crash Sensor Side Airbag; Driver Side (G179)
            36-10 - Open Circuit - Intermittent
            44-10 - Short Circuit - Intermittent
            33-10 - Resistance Too Low - Intermittent
01217 - Side Airbag Igniter; Driver Side (N199)
01218 - Side Airbag Igniter; Passenger Side (N200)
            37-10 - Faulty - Intermittent
Address 17: Instruments        Labels: 8D0-919-0xx-17.lbl
   Part No: 8D0 919 034 E
   Component: B5-KOMBIINSTRUMENT__D12
   Coding: 00140
   Shop #: WSC 00186
   VCID: 2B55E127D9F0EB46111-5000
Address 25: Immobilizer        Labels: 4A0-953-234.lbl
   Part No: 4A0 953 234 F
   Component: IMMO AUZ9Z0V1093670 D77
   Coding: 00000
   Shop #: WSC 42960
   VCID: 2541171FBF14DD36C75-50E6
1 Fault Found:
01176 - Key
Address 35: Centr. Locks        Labels: 8D0-862-257.lbl
   Part No: 8LO 862 257
   Component: ZV-Pumpe, DWA, Funk
   Coding: 10184
   Shop #: WSC 65535
   VCID: 112953CF5B9CA1960BD-4DD6
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
            35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
            35-00 - -
01374 - Alarm triggered by Terminal 15
            35-00 - -
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
01369 - Alarm triggered by Hood Switch
            35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 - -
01373 - Alarm triggered by Radio Ground Contact
            35-00 - -
End
Wszystkie swiatla stopu masz i dzialaja?
Pokasowałeś te wszystkie błędy ?? Jak nie to pokasuj i zobacz co nie udało się skasować . Trochę  nazbierało się tego i nie wiadomo co może być przyczyną .
Nowe logi po skasowaniu i przejechaniu się kawałek:
   Mileage: 114840km/71358miles
   Coding: 00003
   Shop #: WSC 06325
   VCID: 5FCD45F7DDC847E6CD9-4A3A
Readiness: N/A
   Shop #: BB 24302
   Coding: 04143
   Shop #: WSC 06325
   VCID: 275D1D17C518CF26F59-2580
2 Faults Found:
   Coding: 00102
   Shop #: WSC 64327
   VCID: 3663C05312B2A6AE7EF-5072
9 Faults Found:
   Coding: 00140
   Shop #: WSC 00186
   Coding: 00000
   Shop #: WSC 42960
   VCID: 2541171FBF14DD36C75-5072
1 Fault Found:
01176 - Key
   Coding: 10184
   Shop #: WSC 65535
8 Faults Found:
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
End
Wszystkie światła stop są, ostatnio wymieniałem nawet żarówki (dwóżarnikowe) gdyż jedna się przepaliła
