Czajson Opublikowano 14 Sierpnia 2019 Opublikowano 14 Sierpnia 2019 VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77 Address 01 ------------------------------------------------------- Controller: 8E0 909 518 AQ Component: 1.8L R4/5VT G 0020 Coding: 0011501 Shop #: WSC 06335 Nie ma błędów . Readiness: 0100 0101 Address 08 ------------------------------------------------------- Controller: 8E0 820 043 BL Component: A4 Klimaautomat 3233 Coding: 00000 Shop #: WSC 00000 5 Znalezione: 00601 - Potentiometer On Positioning Motor for Central Flap (G112) 30-00 - Open or Short to B+ 00601 - Potentiometer On Positioning Motor for Central Flap (G112) 09-00 - Adaptation Limit Surpassed 00604 - Potentiometer Positioning Motor for Air Flow Flap (G113) 30-00 - Open or Short to B+ 00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143) 30-00 - Open or Short to B+ 00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143) 09-00 - Adaptation Limit Surpassed Address 09 ------------------------------------------------------- Controller: 8E0 907 279 N Component: int. Lastmodul ECE 0907 Coding: 11101 Shop #: WSC 00493 Nie ma błędów . Skipping Address 15-Airbags Address 16 ------------------------------------------------------- Controller: 8E0 953 549 Q Component: Lenksáulenmodul 0801 Coding: 04042 Shop #: WSC 06335 1 Błąd Zapis.: 01330 - Central Control Module for Central Convenience (J393) 49-10 - No Communications - Intermittent Address 17 ------------------------------------------------------- Controller: 8E0 920 931 S Component: KOMBI+WFS 3 H10 0200 Coding: 0006118 Shop #: WSC 73249 Nie ma błędów . Address 37 ------------------------------------------------------- Controller: 8E0 035 192 S Component: J0503 RNS-LOW 0200 Coding: 0012217 Shop #: WSC 06335 Nie ma błędów . Address 45 ------------------------------------------------------- Controller: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 1 Błąd Zapis.: 01463 - Alarm triggered by Sensor for anti-theft alarm System 43-00 - Closed Address 46 ------------------------------------------------------- Controller: 8E0 959 433 CQ Component: Komfortgerát T3B 4336 Coding: 07018 Shop #: WSC 06335 10 Znalezione: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 00932 - Electric Window Motor: Drivers Side (V147) 62-10 - No or Incorrect Adjustment - Intermittent 01331 - Door Control Module: Driver Side (J386) 49-10 - No Communications - Intermittent 01332 - Door Control Module: Passenger Side (J387) 49-10 - No Communications - Intermittent 01333 - Door Control Module: Rear Left (J388) 49-10 - No Communications - Intermittent 00935 - Electric Window Motor: Rear Right (V27) 53-10 - Supply Voltage Too Low - Intermittent 01334 - Door Control Module: Rear Right (J398) 49-10 - No Communications - Intermittent Address 56 ------------------------------------------------------- Controller: 8E0 035 192 S Component: J0503 RNS-LOW 0200 Coding: 0012217 Shop #: WSC 06335 Nie ma błędów . Address 76 ------------------------------------------------------- Controller: 8E0 919 283 D Component: Parkhilfe 4-Kan H06 0010 Coding: 0010014 Shop #: WSC 00493 1 Błąd Zapis.: 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication - Intermittent Address 77 ------------------------------------------------------- Controller: 8P0 862 335 Q Component: FSE_255x BT H26 0350 Coding: 0011891 Shop #: WSC 06335 Nie ma błędów . End ------------------------------------------------------- Proszę o interpretację powyższych błedów. CZY TO COŚ POWAŻNEGO?
