[B5 AVG] Proszę o analizę błędów
Witam
Proszę o analizę błędów jakie mi wyskoczyły
Control Module Part Number: 038 906 012 AH
Component and/or Version: 1,9l R4 EDC 0000SG 2827
Software Coding: 00002
Work Shop Code: WSC 06325
2 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 AH
Component: 1,9l R4 EDC 0000SG 2827
Coding: 00002
Shop #: WSC 06325
2 Faults Found:
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 M
Component: A4 KLIMAAUTOMAT D56
Coding: 00043
Shop #: WSC 06325
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 900
Component: KOMBI+WEGFAHRS. M73 D13
Coding: 04040
Shop #: WSC 00000
Ident.-Nr. Wegfahrs.:AUZ5Z0XN095056
1 Fault Found:
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 C
Component: ZV-Pumpe D12
Coding: 00001
Shop #: WSC 06325
1 Fault Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
Address 56 -------------------------------------------------------
Controller: 4B0 035 186
Component: Radio 0001
Coding: 00205
Shop #: WSC 06313
1 Fault Found:
00854 - Radio Display Output in dash Panel insert
49-00 - No Communications
End -------------------------------------------------------
wszystko bylo ...
:szukaj:
