[ALL B7] Audi A4 S-line
Oto moja dziecinka ponizej pare fotek od dealera zanim ja nabylem
Odkad posiadam ta czerwona diablice nie obylo sie w modyfikacji wygladu , oczywiscie przyciemniono szyby no i ostatnio wymienilem kola z 17 na 19 (repliki z RS4)
Wewnatrz z kolei wymienilem Audio Symphony na 7calowy odtwarzacz Pionieer`a (AVH-P6000DVD) posiadajacy dodatkowo iPod Adapter i Bluetooth
Na ponizszy obrazek mozna kliknac aby zobaczyc krotki klip
oraz zdjecie dla leniwych
No i nieco specyfikacji , wybaczcie ze po angielsku ale zaoszczedzi mi to wiele czasu :slina:
2008 Audi A4 4dr Sdn CVT 2.0T FrontTrak 4dr Sdn CVT 2.0T FrontTrak Sedan
ADDITIONAL OPTIONS
PREMIUM PKG -inc: leather seating surfaces, 17" x 7.5" 5-spoke cast alloy wheels, P235/45HR17 all-season tires (N/A w/WQB S-Line Sport Pkg or PQE Titanium Pkg)
Mechanical
* 2.0L DOHC TFSI 16-valve I4 turbo charged engine
* Multitronic automatic continuously variable transmission w/dynamic regulation program (DRP)
* FrontTrak front wheel drive system
* 80-amp/hr battery
* Electronic stability program (ESP) w/anti-slip regulation (ASR)
* 4-link double wishbone front suspension
* Independent trapezoidal link rear suspension
* Front/rear stabilizer bars
* P215/55HR16 all-season tires
* 16" x 7" 7-spoke cast alloy wheels
* Full-size spare tire w/matching alloy wheel
* Pwr servotronic speed-sensitive steering
* Pwr vented front & solid rear disc brakes w/disc wiping feature
* 4-wheel anti-lock brake system (ABS) w/electronic brake force distribution (EBD) for rear brakes
* Brake Assist
* Tool kit located in spare wheel well
Exterior
* Glass tilt/slide sunroof-inc: sunshade
* Chrome trim-inc: exterior side windows
* S line grille
* 2-way ellipsoid halogen projector headlights w/variable focus reflectors
* (2) front fog lights
* (1) rear fog light
* S line lower side door trim
* S line trunklid w/integrated spoiler
* Auto-Blink feature blinks turn signal (3) times when lever shortly pushed up/down
* Dual body-color pwr mirrors w/defog (RH convex)
* Variable-intermittent windshield wipers w/heated washer nozzles
Interior
* Cloth front bucket seats-inc: 12-way pwr driver seat, 4-way pwr lumbar, active head restraints
* 60/40 split-folding rear seat-inc: individual locks/adjustable head restraints
* Full center console-inc: aux pwr outlets, front/rear ashtrays, (2) integrated cupholders w/spring-loaded size adjustment, fold down height adjustable front center armrest w/storage
* Fold down rear center armrest-inc: dual cup holder
* Front/rear floor mats w/snap-in mechanism
* 4-spoke multi-function leather-wrapped tilt/telescopic steering wheel w/shift paddles
* Basic driver info center-inc: outside temp display, miles to empty fuel
* Backlit instrumentation w/auto brightness control-inc: electric speedometer, tachometer, fuel gauge, coolant temp gauges, digital clock w/date
* Digital trip odometer w/service interval indicator
* Tire pressure monitoring system
* CAN network-inc: (3) fully functional circuits (infotainment, comfort, powertrain)
* Pwr windows-inc: retained accessory pwr, pinch protection, front/rear 1-touch up/down, 2-stage button mechanism, illuminated driver lockout switch for rear windows
* Remote keyless entry-inc: extended range, rolling code, selective unlock, trunk release, panic feature, alarm system
* Pwr central locking system-inc: trunk/fuel filler door, selective unlocking, auto window opening/closing, driver/front passenger door master control, rear master control in center console, auto locks when vehicle reaches 8 MPH, auto unlocks when key out of ignition
* Cruise control
* Fuel filler door remote release
* Trunk remote release w/"soft touch" open feature
* Anti-theft vehicle alarm system-inc: driver theft-deterrent light, backup battery, ultrasonic interior monitoring, immobilizer, key fob, backup horn, tilt sensor, auto-on when vehicle locked
* Theft-deterrent AM/FM stereo-inc: in-dash 6-disc CD changer, MP3 capability, radio data system (RDS), graduated audio level adjustment (GALA)
* 10-speaker sound system-inc: (2) speakers per front/rear door, subwoofer, centerfill speaker
* Satellite radio preparation
* Roof-mounted antenna
* Dual zone automatic climate control-inc: (7) temp sensors, sun/pressure sensor
* Rear window defogger w/timer
* Aluminum interior beltline trim
* Front seatback map net pockets
* (4) assist handles w/slow retraction feature
* Dual illuminated visor vanity mirrors
* 3rd sunvisor above rearview mirror
* Interior lighting w/courtesy delay & fade-in/fade-out feature
* Illuminated rear cargo area, glove box, lighter & ashtray
* Leather-wrapped shift knob & hand brake handle
* (4) cargo area tie-down points w/luggage net
* Storage tray under driver/front passenger seats
* Auxiliary pwr outlet in trunk
EPA Fuel Economy & Specification
* Passenger Volume (ft3) : 90.1
* Base Curb Weight (lbs) : 3428
* EPA Fuel Economy Est - City (MPG) : 21
* EPA Fuel Economy Est - Hwy (MPG) : 30
* Wt Distributing Hitch - Max Trailer Wt. (lbs)
* Wt Distributing Hitch - Max Tongue Wt. (lbs)
* Engine Order Code
* Engine Type : Gas I4
* Displacement : 2.0L/121
* Fuel System : FSI
* SAE Net Horsepower @ RPM : 200 @ 5100-6000
* SAE Net Torque @ RPM : 207 @ 1800-5000
* Trans Order Code
* Trans Type : 1
* Trans Description Cont. : CVT Automatic w/OD
* Trans Description Cont. Again
* First Gear Ratio (:1) : 2.38
* Second Gear Ratio (:1) : 1.51
* Third Gear Ratio (:1) : 1.08
* Fourth Gear Rato (:1) : 0.84
* Fifth Gear Ratio (:1) : 0.67
* Sixth Gear Ratio (:1) : 0.54
* Clutch Size (in)
* Maximum Alternator Capacity (amps) : 120
* Total Cooling System Capacity (qts) : 9.5
* Suspension Type - Front : 4-Link
* Suspension Type - Rear : Trapezoidal Link
* Suspension Type - Front (Cont.) : w/Stabilizer Bar
* Suspension Type - Rear (Cont.) : w/Stabilizer Bar
* Front Tire Order Code
* Rear Tire Order Code
* Spare Tire Order Code
* Front Tire Size : P215/55R16
* Rear Tire Size : P215/55R16
* Spare Tire Size : P215/55R16
* Front Wheel Size (in) : 16 x 7.0
* Rear Wheel Size (in) : 16 x 7.0
* Spare Wheel Size (in) : 17 x 7.5
* Front Wheel Material : Alloy
* Rear Wheel Material : Alloy
* Spare Wheel Material : Alloy
* Steering Type : Servotronic Speed-Sensitive
* Steering Ratio (:1), Overall : 16.3
* Turning Diameter - Curb to Curb (ft) : 36.4
* Brake Type : Pwr
* Brake ABS System : 4-Wheel
* Disc - Front : Yes
* Disc - Rear : Yes
* Front Brake Rotor Diam x Thickness (in) : 12.6 x 1.18
* Rear Brake Rotor Diam x Thickness (in) : 11.3 x 0.47
* Drum - Rear : No
* Rear Drum Diam x Width (in)
* Fuel Tank Capacity, Approx (gal) : 18.5
* Front Head Room (in) : 38.4
* Front Leg Room (in) : 41.3
* Front Shoulder Room (in) : 55.1
* Second Head Room (in) : 37.2
* Second Leg Room (in) : 34.3
* Second Shoulder Room (in) : 53.4
* Wheelbase (in) : 104.3
* Length, Overall (in) : 180.6
* Width, Max w/o mirrors (in) : 69.8
* Height, Overall (in) : 56.2
* Tread Width, Front (in) : 59.9
* Tread Width, Rear (in) : 59.9
* Min Ground Clearance (in) : 4.2
* Liftover Height (in) : 28.6
* Trunk Volume (ft3) : 13.4
* Seventh Gear Ratio (:1) : 0.38
Safety
* Brake Assist
* Driver/front passenger next generation frontal airbags w/dual-threshold deployment determined by seat buckle switches
* Driver/front passenger seat-mounted side-impact airbags
* Sideguard front/rear inflatable curtain airbags
* Front 3-point seat belts-inc: height adjustment, auto pretensioners, belt force limiters
* (3) rear 3-point seat belts w/auto pretensioners
* Front/rear passenger seat belts w/automatic locking retractor (ALR)
* Rear seat lower anchorage & upper tether child seat provisions (LATCH)
* Impact protection-inc: reinforced high strength steel/aluminum crossmembers, reinforced bumpers, rigid occupant cell, side intrusion beams
* Child safety rear door locks
* Crash sensor system-inc: central unlocking, interior lighting on, hazard warning lights on, engine & fuel pump shut off
:mysli: :mysli: ładniutka , ładniutka - felunek robi swoje :good:
Opis po angielsku zwala z nóg, ale się Audi rozpisało :)
Geratki - ładna sztuka.
jak dla mnie kolorek tez wporzadku:)
Brakuje tylko Quattro :decayed:
Fajnie że zewnętrzny S-lina bo niestety wewnetrznego brak :gwizdanie:
Ogólnie bardzo fajna audika , graty zakupu :good:
